12 inch wide wheels
Discussion in 'Wheels & Tires' started by evanbennett, Aug 22, 2018.
  1. Aug 22, 2018 at 7:56 AM
    evanbennett
    evanbennett [OP] Member
    Evan
    MD
    2007 Access Cab
    3” inch leveling kit Straight pipe dual exhaust KN Cold Air Intake 33”x12.50” MTs 18”x12” wheels obnoxiously loud and stupid wide
    I just ordered a set of 18x12 inch wheels -44 offset and will be running them on 3 inch level kit with 33x12.50s.
    I'm concerned with the weight of these wider wheels being too heard on the ball joints as well as excessive rubbing with just the 3 inch lift.
    Feedback?
  2. Aug 22, 2018 at 7:58 AM
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
    Ohhhhhh BOI
    SPACERS AND WIDE WHEELS
    TrIgGeReD
    You’ll be fine though, you’re gonna rub like a MFer
  3. Aug 22, 2018 at 8:05 AM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Welcome to TW. Generally you want to ask these questions prior to your purchases, but lets see if we can help. You probably will rub. What weight are the wheels?
  4. Aug 22, 2018 at 8:15 AM
    evanbennett
    Evan
    MD
    2007 Access Cab
    Wheels weigh 36 lbs. I know they're gonna rub the fender but the offset of the wheels should be enough to clear the frame etc. Anyone cut any part off their fender / remove mud guard to keep from rubbing there?
    @Comatose
    Comatose likes this.
  5. Aug 22, 2018 at 8:21 AM
    Comatose
    Miguel
    San Diego, CA
    Not sure you are going to clear your cab mount. Youre wheels have a 4.75 backspacing which is close to ideal, but the fact that your tires are 12.5 wide is probably going to be what does you in there. As far as your rims are concerned, they are only about 8 lbs heavier than the stock 17" rims, so not a huge concern, but when you couple that with the weight of a 33x12.5 tire, you're going to have a noticeable difference. I wouldnt suspect you would blow through ball joints but you will have greater wear and tear.
  6. Aug 22, 2018 at 8:26 AM
    evanbennett
    Evan
    MD
    2007 Access Cab
    @Comatose I guess the only real thing I can do is wait and hope at this point. Hoping to have it done Labor Day Weekend. I'll post pics and see how everything lines up. Thanks for your feedback
  7. Aug 22, 2018 at 8:31 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Well, if you haven't mounted yet, you can return or resell the wheels. 12" wide wheel is extremely wide, especially for a 12.5" wide tire. Did you check the tire spec to see if it is in the tolerable range to mount to a wheel that wide? Usually the max width I'd recommend is 8", though many run 9" wide wheels.
  8. Aug 22, 2018 at 8:43 AM
    Comatose
    Miguel
    San Diego, CA
    Crap I didnt even think about that. Good call. I know of some Ford and Dodge guys who have run that exact setup but I think the approved top end of most 33x12.5s is around 11.
    OP what tires are you purchasing?
    crashnburn80[QUOTED] likes this.
  9. Nov 19, 2018 at 2:46 PM
    hmasonb34
    hmasonb34 Well-Known Member
    Heath
    Jax, Fl.
    98, ext cab and 2015 LB dbl cab 4x4 sport
    My 98 has 4 in.beefed blocks, QA1 up front, turbo. My 15 4x4 stock looking for lift and tires.
    Hey what ever happened to this thread.
    I am considering selling my 285/70/17's Ridge Grapplers with 17x9 Pro Comps.
    Wanting to go with 33/12.50/18's with 18x12 Whatevers (I haven't decided on which rim).
    A little concerned about rubbing as well and how much trimming will be needed. Maybe a cab mount chop if needed. If the Original poster could provide a update, that would be great.
    TIA. Heath
  10. Nov 19, 2018 at 3:27 PM
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    2023 Tacoma DCLB TRD SPORT 4x4
    - Gator ETX Soft Roll Up Tonneau - Clazzio black leather seats - Nitto Ridge Grappler 255 80 17 tires - Supreme Suspensions 2" and 1" lift
    I have 33 x 12.5 x 20. I had to remove my front air dam and front mud flaps. They would hit at full turn. Or sometimes when going over a bump. I think the trucks looks better without them.
  11. Jul 22, 2020 at 6:11 AM
    ldmsanchez
    ldmsanchez Member
    2017 Toyota tacoma
    4in.suspension lift
    Hey I have a 2017 Toyota Tacoma with a 4 in suspension lift. I was wondering if I would be able to clear 18x12 with a -44 offset on 33 tires with only plastic trimming? Or will this setup require me to do a cmc?
  12. Sep 1, 2020 at 2:59 PM
    evanbennett
    Evan
    MD
    2007 Access Cab
    I run 18x12 with -44 offset on 33s but with a 3 inch lift. My truck is also 2007. Had to do some minor trimming to the cab mount, but nothing serious. But I think with a 4 inch lift you should be perfectly fine.
