12 mpg???????????????????????
Discussion in 'Technical Chat' started by huntertodd, Sep 11, 2009.
  1. Sep 11, 2009 at 9:38 PM
    huntertodd
    huntertodd [OP] Well-Known Member
    HunterTodd
    Greenville, North Carolin
    98 3.4 V6 Automatic ext cab 4x4 tacoma
    1" spacers 32"s cold air intake, bored out cylinders, billet grill,black bull bar, black rear bumper, Black windows, Custom made and programed edge tunnerchip, white skid plates, uws toolbox, surf rod rack camo seat covers, double den touchscreen, flowmaster 40 series, 2 15" orion XTR pros, Autotecck 3,000 watt amp, gps, fender flares, drop in bed liner, clear front bumper lights,
    :confused:i have a 3.4 V6 auto and am getting terrible milage the rucks got 137K miles, 15" rims with 31x10.50s,cold air intake,flowmaster 40, bored out cylinders,custom programing,327 gears,synthetic oil, and a few more minor mods but shoulnt it be getting better milage than this??????:confused:
  2. Sep 11, 2009 at 9:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Define "Custom Programming".
  3. Sep 11, 2009 at 9:51 PM
    huntertodd
    HunterTodd
    up graded computer with diffrent shift point
  4. Sep 11, 2009 at 9:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What kind of programmer? Did you adjust the fuel trim?
  5. Sep 11, 2009 at 9:56 PM
    huntertodd
    HunterTodd
    adjusted nothin with the fuel just changed the shift points to a slight bit lower RPM but not so low that its in too high of a gear to get it going
  6. Sep 11, 2009 at 10:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok. Is your truck a 4x4, Ext Cab, Also..How much did you bore the engine, and what pistons were used?
  7. Sep 11, 2009 at 10:06 PM
    huntertodd
    HunterTodd
    now that i couldnot tell u but 10K ago it was gettin 19-22 on the road then it just dropped?
  8. Sep 11, 2009 at 10:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What year is your truck?
  9. Sep 11, 2009 at 10:09 PM
    huntertodd
    HunterTodd
  10. Sep 11, 2009 at 10:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Without knowing the programmer used, or anything else, its a shot in the dark, but it could be your MAF, IAC, or O2/AF sensor.
  11. Sep 11, 2009 at 10:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Maybe your gears. 3:27 gears sound too low for the Tacoma if its 4x4
  12. Sep 11, 2009 at 10:14 PM
    huntertodd
    HunterTodd
    yea a do a lot of hard pullin that i honestly shoulnt do with it and i know its very hard on it but still it gettin that bad of millage with no trailor on the highway running 55 but i think its the sensior but i need the low end power thats y i put 327 gears in it
  13. Sep 11, 2009 at 10:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    3:27 arent giving you power....You should be running 3:73's or higher. I think your pulling a gear that made for a car, and not a truck.
  14. Sep 11, 2009 at 10:21 PM
    huntertodd
    HunterTodd
    so what would u recomend switching them out to?
  15. Sep 11, 2009 at 10:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    At least 3:73's...Personally, 4:10's would be best.
  16. Sep 11, 2009 at 10:33 PM
    huntertodd
    HunterTodd
    ok man thanks one more question when my truck is in park and i but my foot on the brake and put it in drive it really seems like it kanda slams into drive and reverse hard and when it does it makes a cling type noise????
  17. Sep 11, 2009 at 10:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Could be a bad U joint
  18. Sep 11, 2009 at 10:41 PM
    huntertodd
    HunterTodd
    but u dont think its anything serious??
  19. Sep 11, 2009 at 10:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It should be replaced, if thats what it is. You could loose you drive shaft while driving.....
  20. Sep 11, 2009 at 10:44 PM
    huntertodd
    HunterTodd
    yea well u know how when any truck is in park and off u can roll it about 2-4 inches before the gear grabs and stops it for example sittin in the yard gettin behing it when the trucks off and just pushing it u can hear somethin click-tick
