-12 offset
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoRoams, Sep 28, 2020.
  1. Sep 28, 2020 at 9:14 AM
    TacoRoams
    TacoRoams [OP] Well-Known Member
    David
    Whittier, CA
    2019 White Tacoma TRD Off-Road
    Will I rub with -12 offset? My current tire set up is 285/70R17, talk to the guy where I am going to buy my wheels and he said he does not recommend -12 because I might have rubbing issues. My truck has a 2 inch level kit, what do you guys think?
  2. Sep 28, 2020 at 9:15 AM
    Myles G
    Myles G Well-Known Member
    Myles
    Probably just do a CMC
    TacoRoams[OP] likes this.
  3. Sep 28, 2020 at 9:16 AM
    TacoRoams
    David
    Whittier, CA
    not sure what that means can you explain?
  4. Sep 28, 2020 at 9:22 AM
    Myles G
    Myles
    Cab mount chop
    cost anywhere from 200-300$
    Moves the cab mount back a little to prevent rubbing against the cab. Also if you have a shop do it have them trim the front of the fender maybe a inch.
  5. Sep 28, 2020 at 9:29 AM
    TacoRoams
    David
    Whittier, CA
    not sure if I wanna do all that, so I should just get the 0 offset?
  6. Sep 28, 2020 at 9:51 AM
    Russtty
    Russtty Well-Known Member
    Ontario
    2020 Cement TRD sport DCSB 6MT
    BakFlip MX4 Fuel Vector 17x8.5 -6ET 265/70R17 KO2 TRD Pro Grill OV tune - pending
    As a reference point, I have 265/70R17 on a -6ET.
    I am seeing some rubbing on the stock mud flaps on the front going over curbs while turning. Not even full lock. I still need to try giving them a trim.
  7. Sep 28, 2020 at 10:12 AM
    TacoRoams
    David
    Whittier, CA
    yeah probably not gonna go with the -12
  8. Sep 28, 2020 at 10:17 AM
    ClintS
    ClintS Well-Known Member
    San Diego
    2019 Tacoma TRD Off Road
    285/70R-17 KO2 tires on 4.75 backspace (6 offset) wheels with a 2" lift. Minutely trimmed to avoid any rubbing even when off-roading.
    Go with your wheel guy's recommendation and make sure he will swap out wheels if what is recommended does not work to your satisfaction.
  9. Sep 28, 2020 at 10:18 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I run -12 285/70/17. I did the CMC, so I can't say for sure you'll rub there, but I still rub a little in reverse at times. Cut a little plastic up front as well.
    5100s with 888 coils.
