12 point fasteners?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pontoon, Nov 21, 2016.
  1. Nov 21, 2016 at 11:46 PM
    pontoon
    pontoon [OP] Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    Does the 3.4L 2000 Tacoma TRD 4x4 have any 12 point fasteners? If so do you know what sizes by any chance?
  2. Nov 22, 2016 at 12:29 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Not from the factory but being it is a Toyota you might find anything
  3. Nov 22, 2016 at 12:38 AM
    pontoon
    Ok thanks. I read somewhere the axle nuts might be 12 point but I guess that's wrong.
  4. Nov 22, 2016 at 6:27 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    The ADD tube has a funky star pattern on them, its like an inverted torx bolt. Found that out when i broke a cv shaft off inside the tube, luckly one of my friends had them.
  5. Nov 22, 2016 at 8:44 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    The head bolts are 12 point, no?
  6. Nov 22, 2016 at 12:39 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Why do you need to know? Planning to stock up on tools you'll probably never need or something?
    If you have a specific project in mind, look up the how to's for that particular project, they'll tell you if you need special tools. Otherwise, I wouldn't worry about it.
  7. Nov 22, 2016 at 1:28 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    If your going to remove the heads you should have an idea what your getting into.
    I was going by what the average person might encounter
    Clutch timing belt etc
    If your heads are coming off you have enough time to round up a socket
  8. Nov 23, 2016 at 12:36 AM
    pontoon
    No I don't plan to take the heads off. I ordered a 12 point axle nut sized socket set, but I'll return it.
  9. Nov 23, 2016 at 12:40 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Not on my 2nd gen.
  10. Nov 23, 2016 at 1:02 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    They require an E14 external torx socket. I got rid of those pieces of shit when I did my manual hub conversion. They can be replaced with M12x1.25 bolts so you never have to deal with those bastards again:
