12 volt power wire to bed???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brutalguyracing, Nov 29, 2009.
  1. Nov 29, 2009 at 2:27 PM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    how do i get a power wire from inside back seat in dc 09 to truck bed or gtrailer hitch area and ideas on how to do this would be app.
    thanks....
  2. Nov 29, 2009 at 2:35 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    I did this a couple of months ago. I put an Add a Link Fuse from an unused circuit in my fuse block. Ran the wire down the side and through the rubber grommet that is under the carpet, under the drivers seat. Then just chased the wire back to where i wanted it. I used the frame for a ground and all was good. Any questions just PM me and I will give you a step by step. It is really easy to do.
  3. Nov 29, 2009 at 8:15 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Is there any reason why it has to be from the back seat? Much easier to run it from underneath the hood from the main fuse box.
  4. Nov 29, 2009 at 10:59 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    i have 4ga wire already from battery to backseat for an amp........now i wana add some power to bed
  5. Nov 30, 2009 at 3:11 PM
    Fortech
    CANADA
    If you look at the floor of the cab from underneath, there are several rubber plugs that can be removed to gain access to inside the cab.
    Choose the plug location that best suits you needs. Run wire from your power source to the rubber plug by routing underneath the carpet. Then:
    1. Pierce a small hole through the center of the rubber cap for your power wire. Make sure the hole is smaller than the diameter of the wire to ensure the rubber will seal around the insulation of the wire preventing moisture from entering the cab.
    2. Feed wire through rubber plug
    3. Replace plug
    4. Run wire along frame rail until you get to your entry point in the bed
  6. Nov 30, 2009 at 6:42 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    thanks man im gonna try that tomm. ill post some pics this weekend of all my mods
