1200 rpm
Discussion in 'New Members' started by Pjajr77, Dec 25, 2018.
  1. Dec 25, 2018 at 3:46 PM
    Pjajr77
    Pjajr77 [OP] Member
    James
    2001 & 2014 Tacomas
    Lifted 2 inches
    2001 Tacoma Prerunner Auto V6.
    High idle in park and neutral.
    I changed the IAC valve, cleanes throttle body, and changed TPR sensor, and checked for vacuum leaks. And it still idles high in park.
    No engine light has came on ever.
    What is my next step? Only has 72,000 miles.
    MJ-12 likes this.
  2. Dec 25, 2018 at 3:49 PM
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
  3. Dec 25, 2018 at 3:52 PM
    Pjajr77
    Pjajr77 [OP] Member
    James
    2001 & 2014 Tacomas
    Lifted 2 inches
    They best way I knew how, far from a mechanic. After engine got to temp, I sprayed carb clean around connections and on hoses and listened for changes in engine.
    gilligoon likes this.
  4. Dec 25, 2018 at 4:02 PM
    Pjajr77
    Pjajr77 [OP] Member
    James
    2001 & 2014 Tacomas
    Lifted 2 inches
    Yes, I've tried to disconnect the battery. I first brought my truck to the dealership for other maintenance. I asked them to check why high in park. They told me it was the IAC valve and wanted to charge me $ 550 dollars. So I told them NO, and I changed it myself, but still high rpm. But other than that truck runs awesome, no stalls or anything, I just don't understand
  5. Dec 25, 2018 at 4:31 PM
    MJ-12
    MJ-12 Well-Known Member
    Tee
    Houston, Texas
    2018 Limited 4x4 Mag Grey
    Stock
  6. Dec 25, 2018 at 6:01 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
    Taco critter and Pjajr77[OP] like this.
