120k mi on original transmission fluid - what now?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by slyguy47, Dec 21, 2024.
  1. Mar 8, 2025 at 4:01 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    The reason why shops hate doing trans fluid changes is because most people wait until they have an issue and then go and try and change the fluid thinking it will solve issues . Instead of solving issues it causes more . But on the other hand if your tranny is in good shape , and you have 200 k miles do a drain and refill and you will be fine. Cleaning the gunk on the bottom of the pan is always a a good idea
    Remember…. A trans does not produce any combustion residue . So the fluid ( unless you heat it up bad)
    Should stay good for a long while . But you do get clutch material floating in the fluid which is why it’s not a bad idea to change it
    blnewt and Micbt25 like this.
  2. Mar 8, 2025 at 7:36 PM
    wdunnlee
    wdunnlee Well-Known Member
    Will
    Tidewater VA
    2010 Timberland Mica 4x4
    Mine was at 150k with a drain and refill done at 70k. I had a dealer do a full flush, costed me a pretty penny but shifts so much better now. No problems whatsoever.
  3. Mar 8, 2025 at 8:21 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Toyota/Lexus recommends an ATF flush in their non-hybrid automatics every 60K if your driving qualifys you for special operating conditions, aka severe duty driving - towing, off-roading, commercial use, etc … ATF accumulates moisture and other contaminants. The idea behind a flush or drain/refill is to eliminate such contaminated fluid as the source of transmission failure. It is cheap insurance. The only time you dont want to replace dirty fluid it is when it is contaminated with clutch material to such an extent that removing that dirty fluid will cause the transmission to slip. This can happen in high mileage transmissions. So, it is a good idea to drop the pan to look for metal pieces on the magnets. You can also get the ATF fluid analyzed.
  4. Mar 8, 2025 at 8:34 PM
    nglescobar1992
    nglescobar1992 Well-Known Member
    boogers
    2019 tacoma
    oem
    I tried talking to my local dealership to do it and told me no, I was at 60k miles
  5. Mar 13, 2025 at 6:54 AM
    slyguy47
    slyguy47 [OP] Nerd
    Jacksonville, FL
    15 AC TRD OR V6 4WD 5AT
    Now that it's been about 4 days, the transmission maybe seems to shift a little smoother, but unless it's placebo the improvement is marginal. I still notice some infrequent "shuttering" between gears (happened maybe 2 times in the last 4 days) but that might just be due to my driving style? If anything, it doesn't feel any worse than it was, which is good. I'll continue to pay attention to how she shifts and I'm aiming to do a drain and fill in about 24k mi (at 150k mi). I think some Lubeguard Platinum may also be good to add unless it's not recommended for any reason?
  6. Mar 14, 2025 at 3:20 AM
    TruckGuy63
    Gilbert
    New York
    I would leave it alone for a little while now . These transmissions are very stout. The programming may be weird but the mechanical stuff is good ( vey old design ) but good.
    Flori-duh Taco likes this.
  7. Mar 14, 2025 at 3:30 AM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    I need to get around to doing this too. I’m at 145k and I’m pretty sure the fluid was done at some point in the past by the last owner. My truck isn’t driven hard so hopefully I’m good
  8. Mar 14, 2025 at 8:06 AM
    Rougarou680
    Rougarou680 Swamp Lurker
    Lousyana
    2006 Tacoma 4.0 Prerunner, 2013 & 2014 Tacoma 4WD 4.0L
    Leveling kit, hydro dipped rims & skid plate on 2013, 6” pro comp lift & color matched rims on 2006.
    Last time I let dealer change transmission fluid they shorted me 3 quarts, & that’s even after taking it back once for shifting problems. I’ll use local transmission guru from now on.
  9. Mar 14, 2025 at 11:58 AM
    wdunnlee
    Will
    Tidewater VA
    Yikes, sounds like your dealership needs better employees. My post wasn’t advocating for the stealership it was simply to say I had mine flushed and it improved shifting.
  10. Mar 14, 2025 at 2:50 PM
    Rougarou680
    Lousyana
    I was told they fired that employee.
  11. Mar 18, 2025 at 9:15 PM
    Taco1219
    Taco1219 Member
    2012 Black Prerunner Axs Cab Tacoma
    I’ve had this question for a while, I have a used 2012 taco. Looking on carfax care I don’t see any history of a tranny flush or fluid change. She is at 230K miles, my question is do I keep riding it or get it drained even though it could potentially be its first time being drained?
  12. Mar 18, 2025 at 9:46 PM
    blnewt
    blnewt Well-Known Member
    Brad
    2015 Gray metallic Double Cab V6 4x4 SR5
    Did a full 12qt maxlife flush w/ new AT filter and gasket at 190k miles on a 2015 Tundra that didn't have any prior AT service according to a very detailed Carfax (Tundra was serviced every 5k miles for it's 9 yrs prior to my taking the keys). AT shifts great w/ solid up and down shifts at the proper shift points. I wouldn't do a pressure flush, but a regular flush through the cooling lines w/ a gravity fill is easy and shouldn't create loose debris that a pressure flush could.
  13. Mar 19, 2025 at 6:12 AM
    Taco1219
    Taco1219 Member
    You would do a drain and fill or a complete flush?
  14. Mar 19, 2025 at 7:25 AM
    blnewt
    Brad
    At the minimum I'd do a pan drop & clean, new filter/gasket (WIX is a good one at rockauto.com) and a drain & fill, then do drain & fills ever 30k thereafter if you don't want to flush the full amount at once.
    Taco1219[QUOTED] likes this.
  15. Mar 21, 2025 at 7:58 AM
    #35
    blnewt
    Brad
    lol, what special way was I referring to? Nothing complicated or special here, about as simple as it gets IMO.
    ridefreak likes this.
