120v bed outlet not working.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by trgower13, Oct 25, 2022.
  1. Oct 25, 2022 at 5:19 PM
    trgower13
    trgower13 [OP] Member
    2016 TRD tacoma
    So the lights on the switch are on and working. But there’s no power to the outlet in the bed of the truck! I changed the 15a fuses. Any other thoughts?
  2. Oct 25, 2022 at 5:27 PM
    caribe makaira
    Caribbean, Puerto Rico
    There is no 15A fuse to the circuit...o_O
    SR-71A, blu92in99 and mtip like this.
  3. Oct 25, 2022 at 5:35 PM
    trgower13
    2016 TRD tacoma
    what is that? Please explain. Do I need to replace? What else does that control?
  4. Oct 25, 2022 at 5:36 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    That's an 80 amp fuse. It's only used for the inverter/120v AC in the bed.
    mtip and trgower13[QUOTED][OP] like this.
  5. Oct 25, 2022 at 5:38 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Either a fuse as described above or a disconnect in the wire. When I bought my truck, the switch didn’t work. Come to find they forgot to plug the switch in or got loose from the factory. Easy fix.
  6. Oct 25, 2022 at 5:39 PM
    caribe makaira
    Switch indication would not work if connector is off.
    blu92in99 likes this.
  7. Oct 25, 2022 at 5:40 PM
    LivinOnEdge
    Land of The Lost
    Doesn’t mean it’s not disconnected at the bed. However it’s more likely to be the fuse.
  8. Oct 25, 2022 at 5:40 PM
    trgower13
    2016 TRD tacoma
    Would switch indicator work if fuse was bad?? Do you think I should get the 80A?
  9. Oct 25, 2022 at 5:41 PM
    caribe makaira
    NO, you should get someone with more skills to test the 80A fuse...
  10. Oct 25, 2022 at 5:44 PM
    trgower13
    2016 TRD tacoma
    I guess I’ll take to shop and see. I don’t mess with electric.
  11. Oct 25, 2022 at 5:46 PM
    caribe makaira
    Yes and Maybe.
  12. Oct 25, 2022 at 5:48 PM
    LivinOnEdge
    Land of The Lost
    Disconnect battery and check the terminals at both the switch and bed side. Super easy fix if that’s the issue and you don’t need electrical knowledge. Just to save you a few bucks at the shop if they charge to look at it.
  13. Oct 25, 2022 at 5:49 PM
    caribe makaira
    OP, do you have and know how to use a DMM (Digital Multi Meter)?
  14. Oct 25, 2022 at 5:53 PM
    trgower13
    2016 TRD tacoma
    Yes and yes
  15. Oct 25, 2022 at 5:54 PM
    caribe makaira
    Do you know how to remove the floor console to access the inverter?
  16. Oct 25, 2022 at 5:56 PM
    trgower13
    2016 TRD tacoma
    No. I still have another year on the extended warranty. Maybe I’ll just have dealer fix it. If it’s covered. But I’m always afraid they will screw something else up lol.
  17. Oct 25, 2022 at 5:59 PM
    caribe makaira
    :thumbsup:
  18. Oct 25, 2022 at 6:00 PM
    trgower13
    2016 TRD tacoma
    I like trying to fix the issue myself and learn. But this may be a little out of my expertise.
  19. Oct 25, 2022 at 6:02 PM
    caribe makaira
  20. Oct 25, 2022 at 6:05 PM
    caribe makaira
    There are two connectors to the inverter, one provides 80A fused juice via a relay actuated by a switch. The other receives input from various systems and also provides the converted dc to ac. Having access to them you can test the fuse, relay and function of the inverter.
    trgower13[OP] likes this.
