120v power inverter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ttttrd, Oct 3, 2017.
  1. Oct 3, 2017 at 6:48 PM
    ttttrd
    ttttrd [OP] Member
    Central Washington
    14 Tacoma Dbl Cab TRD
    WeatherTech mats, LED lights for: bed, interior & exterior, Wet Okole heated seat covers, Gentex Auto-dimming mirror, Bloodwood custom gear shift knob, AVS hood Aeroskin, Fog light mod, Bed compartment combo locks
    See post below.......
    Anyone have any ideas as to why my 120v outlet in the bed will not power anything? I have never used it since I bought the truck in 2014. And, of course, the warranty has expired. With the truck running, both lights on the inverter switch light up momentarily, then go and stay off. No other symptoms. Maybe a fuse or relay, and where? Hoping it might be something simple to save a trip to the dealer. Thanks for any suggestions.
  2. Oct 4, 2017 at 5:14 AM
    Awsomeo67
    Awsomeo67 Well-Known Member
    08 reg cab long bed
    Have you tried plugging anything in it? They're only 400w so that won't run to big of things. I'd open the Manuel and start checking fuses
  3. Oct 4, 2017 at 5:29 AM
    Split|Circuit
    Split|Circuit Well-Known Member
    Valley of the Sun
    2017 TRD Off 4x4 DblCab, White, Blk/Org Int
    Bone Stock
    I would plug something small into it, like a nightlight or a small lamp. Have someone verify if it lights up when you push the button in the cab. If only momentarily it could mean the inverter is seeing a short-circuit on it's output and/or going into thermal or protective overload. I think the actual inverter itself is in the cab, so a 120VAC cable runs to the bed, I believe.
  4. Oct 5, 2017 at 1:31 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Have you done any mods to the truck?
  5. Oct 5, 2017 at 2:53 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    It's actually 400 watt max with the engine running, truck not moving. And 100 watts with truck in motion
  6. Oct 5, 2017 at 3:33 PM
    ttttrd
    ttttrd [OP] Member
    Central Washington
    Sorry, I wasn't very clear on my original post below. The inverter will not activate under any circumstances and the lights on the dash switch only remain on momentarily. I would think that one of the lights in the switch would remain on, if it was working as designed. And possibly hear the cooling fan of the inverter running? The receptacle in the truck bed has nothing plugged in to it while switch is depressed. I checked with both a DVOM and a small trouble light. The light didn't work and there is never any voltage available. Again, yesterday was the first time I've ever tried to use it since I bought the truck new.
  7. Oct 5, 2017 at 4:41 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    check the big ACDC relay.
  8. Oct 6, 2017 at 8:32 AM
    ttttrd
    ttttrd [OP] Member
    Central Washington
    Thanks for the ideas. Stand-by....
  9. Oct 6, 2017 at 11:36 AM
    weendoggy
    weendoggy Well-Known Member
    Aptos, CA
    2014 TRD ACOR 4x4
    Access Original Tonneau Cover; Toyota Side Tube Steps; Focal ISS690 front speakers; Clarion XC1410 mini amp; Gentex 453 rearview mirror with Homelink, Compass, Temp and Autodim; Prodigy P2 trailer brake controller, Heated Seats from www.cobraheat.com, BriteAss Fogs, Phillips Extreme LED H/L. Heated mirrors from @Up2NoGood. 5100 Bilstein all four corners.
    +1 I had the same symptom and that was the culprit.
  10. Oct 19, 2017 at 12:56 PM
    ttttrd
    ttttrd [OP] Member
    Central Washington
    Sorry, haven't had a chance to even think about this for several weeks now. All else tests ok, so I suspect the AC/DC relay is the problem. Where is it and is it clearly marked? I would probably have to test by substitution. Anyone have an idea how much they cost?
  11. Oct 24, 2019 at 5:26 AM
    orangeking0314
    orangeking0314 Member
    North Texas
    2020 White DCSB OR (2014 White TSS SR5 PreRunner sold)
    All Weather Floor Mats and bed cargo mat. LED interior and license plate light swap. Subaru tweeter upgrade & Kicker Upgrade OEM LED headlight swap
    I couldn't find the right post for this so I will ask it here. Do all 2nd gen Tacoma's come with a factory inverter between the two front seats? I'm thinking about installing the 110 v bed outlet and can't find anywhere if there is a inverter in my tacoma. I have a 2014 Tacoma Tss, Pre-runner, Sr5. 4-cylinder.
  12. Oct 24, 2019 at 5:43 AM
    Muddinfun
    Muddinfun Well-Known Member
    Only the TRD sport and TRD offroad came with the inverter. It's too much work and expense to install the factory inverter in a truck that didn't come with it. If you want an inverter, install an aftermarket inverter that does much more than 400 watts.
    PzTank and TnShooter like this.
  13. Oct 24, 2019 at 7:21 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Factory inverter also came in my 014 Limited. After converting it to run 400w all the time - I also added an inside outlet so you can use it in a dry environment. A very useful change.
    Muddinfun likes this.
  14. Oct 24, 2019 at 10:14 PM
    Muddinfun
    The 1 post wonder that bumped this 2 year old thread is most likely not coming back.
  15. Oct 24, 2019 at 10:36 PM
    caribe makaira
    Caribbean, Puerto Rico
    :anonymous:
  16. Nov 3, 2019 at 5:11 PM
    kjttaco
    kjttaco Well-Known Member
    Ken
    NJ
    2020 Black Limited
    What have you used the power outlet for? Seems like not much amperage to make coffee
  17. Nov 3, 2019 at 5:42 PM
    GREENBIRD56
    Casper / Tucson
    014 Taco 4Dr 4wd
    Used mine with a long extension cord and led trouble lights - retrieving a neighbor lady's car from an off road excursion. Personally I wouldn't go out of my way to miss a Javelina - but this rescue involved deep sand, cactus and other difficulties.
    Also worked to provide lighting while troubleshooting my son's garage electrical panel.
    kjttaco likes this.
  18. Nov 4, 2019 at 6:01 PM
    kjttaco
    Ken
    NJ
    2020 Black Limited
    I will have to get a led drop light..thanks
