12ton shop press
Discussion in '1st Gen. Tacomas (1995-2004)' started by shankyjones, Nov 25, 2024.
  1. Nov 25, 2024 at 10:03 PM
    shankyjones
    shankyjones [OP] Well-Known Member
    Richard
    Marina CA
    2003 Brown Tacoma Prerunner V6 3.4L TRD
    To y'all in the know
    Will it press in and out the bearings and hubs on my 2003 Tacoma prerunner 2wd 3.3L automatic?
  2. Nov 25, 2024 at 10:40 PM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    Seems I read in some thread it takes at least a 20 ton.
    shankyjones[OP] likes this.
  3. Nov 25, 2024 at 10:41 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Even a 20 ton is pushing it
  4. Nov 25, 2024 at 11:09 PM
    Kleenax
    Ray
    Michigan
    Yep, agreed. 50-ton air/hydraulic if can find one used. Too damn expensive new! Unless you have a business where you’d use it a lot. One hellova nutcracker for Christmas time!
  5. Nov 26, 2024 at 12:16 PM
    shankyjones
    Richard
    Marina CA
    Good people
    I went back and watched the Timmy the toolman video on how to press in and out the bearings and hubs. Timmy used a 12ton shop press so it can be done. Just make sure you have the necessary press sleeves and misc plates and materials.
  6. Nov 26, 2024 at 1:18 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I am pretty sure Timmy used a 20 ton from HF. Either way- get at least that. The 12ton wont do the front bearings, and if you're rear bearings are on their way out, the front aren't far behind.
  7. Nov 26, 2024 at 1:31 PM
    shankyjones
    Richard
    Marina CA
    You are correct Andy01. I went back and reviewed the transcript of the video and indeed it was a 20ton HF press. My hearing ain't too good.
