12V from engine bay into rear of cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kg5ie, Sep 6, 2014.
  1. Sep 6, 2014 at 1:28 PM
    kg5ie
    kg5ie [OP] Well-Known Member
    Bill
    Tx
    '14 PreRunner
    UltraGauge
    Greetings! New here and new to a Taco. Coming out of a Silverado, so be gentle.
    I am a HAM radio operator so I need to run a 12v line to the rear wall of a '14 Taco 4 door. From the batt down along frame rail to rear wall of cab. Question is how to get into the cab at the rear wall.
    I plan to mount the radio body in the storage box behind the rear seat, then run the remote head up to the center console.
    Any help on easy ways to get into the cab at the rear would be appreciated. Hate drilling holes in new metal but I will if I have to.
    73,
    Bill
  2. Sep 6, 2014 at 1:52 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    This is what I did to get my coax cable in to the cab and keep it all water tight.
    Take out the plastic behind the seats.
    Here is the grommet that I am going to use.
    I pulled out the grommet and used a sharp tool to poke a hole into it.
    I shoved my needle nose pliers through the hole.
    And grabbed a hold of the wire.
    Slide the grommet over the wire.
    Finally put the grommet back into the hole.
    Its water tight and you don't have to drill any holes in your truck.
  3. Sep 6, 2014 at 2:02 PM
    kg5ie
    Bill
    Tx
    '14 PreRunner
    UltraGauge
    Thanks for your quick reply and pics Derek. How hard was it to remove the "plastic" from the rear wall? ...I see you are back to the bare metal...
    Also, it appears yours in passenger side. Is there another on the drivers side? I would like to enter there...
    73,
    kg5ie
  4. Sep 6, 2014 at 2:17 PM
    DDD
    Derek
    Santa Clarita, CA
    Pretty easy to remove. A few screws and a few clips.
    There are rubber plugs on both sides of the cab and on the floor. There are many all over the cab.
  5. Sep 6, 2014 at 2:41 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Dont worry, that switch makes us all happy... i got rid of my 01 2500hd 4x4 last year for my 2013 taco.... soooooooo much happier.
    That stated, how many amps does the radio draw? do you need a direct from the battery line? Because there are a few always hot lines already inside the cab at the fuse panel you could pull off of with say an add a circuit.
  6. Sep 7, 2014 at 7:21 AM
    kg5ie
    Bill
    Tx
    '14 PreRunner
    UltraGauge
    Yaesu FTM-10R. I had it sitting in a box so I thought I would stick it in the truck. It draws 8.5 amps on high power, so I thought I would come straight off the battery.
  7. Sep 7, 2014 at 10:07 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    The Link in my SIG quote says it all. Welcome to Tacoma / Tacoma world !!
  8. Sep 7, 2014 at 10:25 AM
    nd4spdbh
    SoCal
    Yeah OK that's a good amount. Should be pretty easy to run a cable from the bat and back in the cab.
