12V front outlets....(and USB)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacobellingham, Jun 11, 2017.
  1. Jun 11, 2017 at 11:30 AM
    tacobellingham
    tacobellingham [OP] Well-Known Member
    Bellvue, CO
    2000 TRD OR, 2015 TRD OR
    better suspension....
    2015 Tacoma. I can't get any power from either of the front 12V outlets - doesn't matter whether I'm driving or stationary. Additionally, the adjacent USB port sometimes works and recognizes my phone...and sometimes doesn't. I've tried multiple cables and nothing seems to sort the issue.
    I checked the blue 15A fuse under the steering wheel that's for the power outlets, and it looks fine. I saw on another post that someone was talking about a relay that can cause issues, but I don't know where that's located.
    Anyone got any suggestions?
    much appreciated
    -- Mike
  2. Aug 31, 2017 at 8:32 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    my outlets just went out last night and yes there is a relay that controls it but I have not read the manual yet to know where its location is
  3. Aug 31, 2017 at 8:49 AM
    Muddinfun
    Muddinfun Well-Known Member
    The relay is on the back side of the fuse block. I think it's the left one.
    Just for info, the fuse is hot all the time and supplies power to the relay contacts. The relay is energized when the key is turned on.
  4. Aug 31, 2017 at 12:51 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    If you have a multimeter check continuity with the fuse unplugged. If using a light meter check for voltage (light) on both sides when the fuse has power. Visual inspection of fuse could be misleading if there is a hairline fracture.
