12v in cab plugs on constant
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gabassman, Dec 9, 2011.
  1. Dec 9, 2011 at 6:20 PM
    Gabassman
    Gabassman [OP] Drive it like a 4WD
    Tyler
    Georgia
    Hello I looked through the pages of mods and did not see what I am looking for. If it is there please direct me.
    I am wanting my 12 v plugs in the cab to be on constantly and not just with the turn of the key. Any help would be appreciated.
  2. Dec 9, 2011 at 6:25 PM
    joes06tacoma
    Joe
    Central Coast, CA
    It's in here somewhere. I've seen it. Basically, you pull the lower dash apart on the driver's side, unbolt the fuse block, turn it over and remove the relay for the 12v outlets that is on the back side of the fuse block. Then you make a jumper wire up and jumper across the two power terminals that the relay normally connects.
  3. Dec 9, 2011 at 6:48 PM
    Gabassman
    Tyler
    Georgia
    Thanks I read the word document that was attached to one of the links. Do you know what else it makes hot beside the bed outlet and the 12v plug, if anything?
  4. Dec 9, 2011 at 6:53 PM
    Gabassman
    Tyler
    Georgia
    Tacoma Constant Cigarette Lighter & Power Outlet Voltage Mod
    Thats the title of the word doc. Wait.... brain fart its talking about the other 12v plug lol
  5. Dec 9, 2011 at 7:03 PM
    Gabassman
    Tyler
    Georgia
    Not sure if im actually goin to do it just curios mostly. Since the subject of bed outlet was brought up do you know how long you can run it with the truck off before killing the battery?
  6. Dec 9, 2011 at 7:15 PM
    Gabassman
    Tyler
    Georgia
    Im looking to see how long I can run something off the outlet in the bed with out having to crank the truck before i would kill the battery?
  7. Dec 9, 2011 at 7:46 PM
    Gabassman
    Tyler
    Georgia
    I have been powering a scale for weigh in at bass tournaments but with the truck running.....im tired of using gas for that.....just wondering if i can power it for at most hour n half with truck off with no problems
  8. Mar 4, 2012 at 4:56 AM
    Honey Badger1
    Honey Badger1 Well-Known Member
    Trip
    New Hampshire
    2011 Tacoma TRD Sport
    Fuzzy Dice, Fighter pilot mod, power ports always on, GPS wired to come on as key is turned, LED Map/dome lights, all weather mats, bed liner, tool box on rail system, Tinted tail lights, repainted badges, Home made grill, Light mounting bracket with two 6 inch. PIAA Drive lights, Stealth mod DTRL on/ off, leather arm rests, door and center.
    has thing been figured out?
  9. Mar 4, 2012 at 5:01 AM
    hardtaco
    hardtaco Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    I would think a digital scale is not going to be pulling many amps. You should be fine without the truck running.
  10. Mar 4, 2012 at 5:09 AM
    o5iiawah
    o5iiawah Well-Known Member
    Tim
    Philly 'burbs, PA
    '11 4x2 access cab 2.7l
    Yeah, a small scale should be fine. Something like a cell phone charger or a satellite radio unit is ok to run without worry.
  11. Apr 25, 2015 at 9:05 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Reviving old Thread just because it's so simple even Chris4x4 couldn't mess it up. Just spent about 20 minutes doing this mod worked flawlessly
