12v outlet not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Front sight, Feb 7, 2012.
  1. Feb 7, 2012 at 11:47 AM
    Front sight
    Front sight [OP] Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    My 12v outlet is not working. My cig outlet is working fine, I checked the fuses behind the change bin and they were fine. Is there any other fuses in this system? Maybe behind the outlet? I just don't want to take apart the dash if I don't have to.
    Thanks
    Oh and I did a search and could not find an answer.
  2. Feb 7, 2012 at 1:15 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    anoyther fuse box under the hook, behind the battery
  3. Nov 9, 2012 at 7:14 PM
    jpaw30
    jpaw30 Well-Known Member
    Im still having the same problem. My cig fuse blew so I changed that one in the coin fusebox.
    The 12v outlet is still not working
    I looked at the one under the hood and I have a 120alt fuse there but the 100 fuse is not in there. Could that be the reason?
    Thing is that it worked when I bought it from the previous owner, it did require that the power cord on my gps be in the right place to light up, however one day you couldnt get anything out of the outlet
  4. Nov 9, 2012 at 7:22 PM
    Front sight
    SW Florida
    I found the problem with my outlet. I had to take apart the dash to get to it. The outlet has an inline fuse directly behind it. I deleted it. I'd rather change one fuse under my dash than take my dash apart. I used a thicker gauge of wire and soldered it in. No problems since.
  5. Dec 6, 2012 at 9:21 AM
    Devog7
    Devog7 Well-Known Member
    Hermitage PA
    19 DCSB TRD-Off Road
    N2 Remote start, TRD Pro Grille, Pop & Lock,
    How did you get the outlet out or get behind it?
  6. Dec 6, 2012 at 11:00 AM
    Front sight
    SW Florida
    Getting to the fuse was kind of a pain-which is why I deleted it. You have to undo the center console and then remove the section of dash the outlet is connected to. The outlet does not pop out. The fuse is on one of the wires on the rear of the fuse. Hope it helps you some.
    Slashaar likes this.
  7. Dec 6, 2012 at 3:24 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is not a factory configuration. That would be an aftermarket outlet with an inline fuse.
  8. Dec 6, 2012 at 3:27 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    . . . Sub'd
  9. Dec 7, 2012 at 9:40 AM
    Front sight
    SW Florida
    Don't know what to tell you :confused:. Fuse was there, I know that I didn't add it. It took me forever to figure out where the problem was. I wish I would have taken pic's. The fuse was sodered to the back of the outlet.
  10. Dec 7, 2012 at 9:43 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, someone was messing with your wiring. Do your outlets stay hot all the time or only when the ignition is on? Reason I ask is I re-wired another member's truck so his outlets were hot all the time and put the in-line fuse behind the dash, near the outlet.
  11. Dec 7, 2012 at 10:06 AM
    Front sight
    SW Florida
    In the process of tying to find the problem to my none working outlet, I did wire my outlet's to be hot. But I did that. :notsure:
  12. Dec 8, 2012 at 2:02 PM
    jpaw30
    check all of my fuses in the box and they all appear to be fine?? Is there instructions somewhere for taking apart the dash to look at that outlet? or a different way to test it?
  13. Dec 8, 2012 at 6:23 PM
    canucktacoma
    canucktacoma Active Member
    mike
    gta area, ontario canada
    sr5
    is it possible to add 12v up where garage door holder is,would like to add something there for the gps,
  14. Dec 8, 2012 at 11:43 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Unless you have a regular cab or a five lug, it should already have the connector for the overhead display that the trd trucks get sitting above that roof console. Two of the pins will be ign+ and gnd, would be easy to connect to that for gps or other small loads. Pretty sure its been done and documented on here.
  15. Dec 9, 2012 at 2:04 PM
    canucktacoma
    mike
    sr5
    i've got a 2008 with holder & vanity lites there.probably missed post re how to,,if you know where to look let me know,,new to site & still finding my way.thanks mike
  16. Jun 18, 2018 at 11:25 AM
    RICK77
    RICK77 New Member
    Tacoma 2006 TRD
    Hello!
    I want to change the cover of my 12V beacause it is broken. I removed the central console but I could not remove the cover that goes below the A/C controls and the Central Consol. How do I remove that Part of the Dash where the cig outlet and 12V outlet are located? In Yoyube I did not find the answer.
    Do you have any ideas or guideline to do it?
    Thanks!
