12V outlets don't work
Discussion in 'Technical Chat' started by the arkitect, Dec 29, 2009.
  1. Dec 29, 2009 at 10:43 AM
    the arkitect
    the arkitect [OP] I will gladly pay you on Tuesday...
    Houston
    08 PreRunner SR5
    My 12V outlets stopped working. I've checked all the fuses and they're all good. Anyone know where else this problem could be coming from?
  2. Dec 29, 2009 at 12:30 PM
    the arkitect
    Houston
    08 PreRunner SR5
    I'm a nub so bear with me, but how do I reset the transformer?
  3. Dec 29, 2009 at 12:32 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    12V outlets...like the cigarette lighters?? No resetting the inverter for that IIRC. If the fuses are good...take it to the dealer.
  4. Dec 29, 2009 at 12:35 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    check the relay.......
  5. Dec 29, 2009 at 12:35 PM
    98tacoma27
    Ben
    Not Beech Creek
    There should be nothing wrong with the invertor. It has nothing to do with your 12v outlets. One of three things: 15 A POWER fuse, 7.5 A ACC fuse or the ACC relay.
  6. Dec 29, 2009 at 12:36 PM
    the arkitect
    Houston
    08 PreRunner SR5
    Yeah, the cigarette lighter outlets...guess i need to take it in.
  7. Dec 29, 2009 at 12:38 PM
    the arkitect
    Houston
    08 PreRunner SR5
    Where is the ACC relay? I've checked both the power fuse and the ACC fuse
  8. Dec 29, 2009 at 12:49 PM
    98tacoma27
    Ben
    Not Beech Creek
    Next to the body ECU. Check page 29, bottom right
  9. Dec 29, 2009 at 12:52 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Start with the fuse, then go to the relay, and if you still have an issue, check continuity of the circuit in question with a ohm meter. While you are checking the continuity you can also check to see if there is a short in the line.
  10. Dec 29, 2009 at 1:04 PM
    the arkitect
    Houston
    08 PreRunner SR5
    If the problem is at the relay, do I have to replace or can I simply reset it? If I can reset it, how do I do that?
  11. Dec 29, 2009 at 1:07 PM
    SC4333
    Grant
    FL
    Replace it. Just pull the relay out and slap a new one in.
    Unfortunately you cannot reset a relay. Its either good or bad. On a better note, they dont cost much. Maybe 30 bucks if you have to purchase it at the dealer, although a lot of relays can be found at an autoparts store.
  12. Dec 29, 2009 at 1:09 PM
    SC4333
    Grant
    FL
    I just thought about something. Go to the cheap free mods thread and look up the always on 12v outlets. This does away with the relay all together. You just pull the relay out and jump two of the connections with a heavy gauge wire. This was the first mod I did to my truck and probably one of the best. I hated the fact that the outlets would turn off when you take the key out of the ignition.
  13. Dec 29, 2009 at 3:40 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    the 12v on all the time mod is the best! i would think if you pull the relay and wire it as the mod says to do and it still doesnt work then take it in but the relay is probably your problem.
  14. Dec 29, 2009 at 4:01 PM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    You've checked the fuse box down and to the left of the steering wheel correct? That's where the fuse box for the interior crap is. I've blown that fuse a couple times with a bad power inverter.
  15. Dec 29, 2009 at 5:51 PM
    the arkitect
    Houston
    08 PreRunner SR5
    I didn't even think about the fuses under the kick panel. I'll check those first, thanks for the heads up. If i'm not mistaken, the power fuse and the acc fuse are both in the fuse box next to the battery, and those were both good.
  16. Dec 30, 2009 at 7:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    They should be in the kick panel
  17. Jan 3, 2010 at 5:29 PM
    the arkitect
    Houston
    08 PreRunner SR5
    It turned out to be the power fuse. Jumped the relay anyway, thanks for all of your help everyone.
