12V Power port
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RTedder2, Sep 22, 2023.
  1. Sep 22, 2023 at 2:57 PM
    RTedder2
    RTedder2 [OP] Well-Known Member
    Roger
    Inferno '17 TRD Offroad
    Hey all, I just picked up the Toyota dual usb "Smart USB" port (pn PT976-89202). The only instructions for it I can find are for the Camry. I'd really like to keep it just a quick plug and play deal and not have to rig up something other than the connector it came with.
    Any ideas on a connector in the dash area that's the one I'm after?
    It's not the usual 12v cig style connector.
    Thanks all!:cheers:
  2. Sep 22, 2023 at 5:34 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    That part is typically installed for the back seat, on the back side of the center console. You can install it anywhere you would like though.
    RTedder2[OP] likes this.
  3. Sep 22, 2023 at 6:08 PM
    RTedder2
    Roger
    No no, I understand that part. I'm wondering where the electrical connector is at. I'm assuming in typical Toyota fashion that the connector is already there.
  4. Sep 22, 2023 at 6:12 PM
    Jord4n007
    Jord4n007 Active Member
    Jordan
    New Orleans
    2022 TRD Sport Double Cab Magnetic Gray Metallic
    RetraxProXR Roll-up bedcover, Uniden R8 Radar Detector with mirrortap/mount, Husky X-act Contour floormats, MESO Hex Rack, MESO Mini Keypad Dongle, MESO Fuse Block, Carlinkit Android dongle (gives you fully unlocked android OS through factory touchscreen, youtube/netflix/etc and wireless apple carplay)
    I don’t think you are going to find a connector for it just hanging in the dashboard. That only happens if the part is an option on your vehicle that you didn’t have from the factory. Tacomas don’t come with an option for an extra USB port besides the one in the console and the regular one for the stereo. If you don’t have the one in the center console already then you may find the plug under you center console. The plug may be different though and require some modification.
  5. Sep 22, 2023 at 6:17 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    Did you check to be sure it is compatible with the Tacoma? Assuming you want to install it in a Tacoma. The only pictures I could find show it installed in the dash of a sedan of some sort.
  6. Sep 22, 2023 at 6:17 PM
    K9tacoma
    K9tacoma Well-Known Member
    Austin
    Central Ohio
    2023 Tacoma TRD Off Road - Lunar Rock
    I installed my own cigarette 12v socket in the back of the center armrest for the backseat. I didn’t take apart much else besides that back panel, but I can tell you I didn’t see any unused connectors or clips back there. There isn’t much back there besides some ECU looking box with heat fins on it.
    HisDad likes this.
  7. Sep 22, 2023 at 6:21 PM
    RTedder2
    Roger
  8. Sep 22, 2023 at 6:22 PM
    HisDad
    Texas at last
    My 2019 SR5 doesn't even have that. I put one of those round dual USB ports in as part of my radio/electronics install and had to run the power wire for it from the added fuse box back.
  9. Sep 22, 2023 at 6:23 PM
    RTedder2
    Roger
    @K9tacoma Ive been into that area adding the 400w mod for the inverter. But everything i see online for that plug i purchased shows it to be closer to the dash. Its a pretty long cable.
  10. Sep 22, 2023 at 6:25 PM
    HisDad
    Texas at last
    Are you installing it in your '17 or a '21?
  11. Sep 22, 2023 at 6:26 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    That port on my truck (in the back of the console for rear seat passengers) was vampire clipped to the wires that feed the console interior port. I cut out the vampire clips and butt spliced it together.
    ktbell444 and RTedder2[OP] like this.
  12. Sep 22, 2023 at 6:28 PM
    RTedder2
    Roger
    My '17. To be fair, I've installed a few other electrical stuff like this meant for newer Tacomas. Such as the factory tailgate lock.
    I'm honestly just hoping. Wiring in a new plug or whatever i need to do is defiantly in my wheel house
  13. Sep 22, 2023 at 7:49 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Since I'm useless with tools and electrical and anything mechanical I had one installed that lives in the
    rear cubby under the seat ( access cab ) wired to the battery ( ignition on only ) to power my Dometic CFX3 35
    while driving. While not driving I plug it into my Jackery 1000 Pro.
    Wife pointed out that I should plug the Jackery into the new port to keep it charged while driving and then
    run the Dometic off of the Jackery full time.
    ( duh )
    Had to break out the 200w Solar Panels on a recent trip as the power blew in the camp ground. I set them up on top
    of the tonneau and ran the cord thru the sliding window. Worked well.
  14. Sep 22, 2023 at 7:57 PM
    Jord4n007
    Jordan
    New Orleans
    that is the power inverter for the 120V A/C plugs in the bed
    K9tacoma[QUOTED] likes this.
  15. Sep 23, 2023 at 8:06 AM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    You can plug it in anywhere that is a +12V source and a ground. They're probably adding length to reach the 12V socket plug or to allow installation practically anywhere without you needing to add your own length. If that's the route you want to go, here's the schematic. #1 is up front, #2/USB is inside the center console.
    RTedder2[QUOTED][OP] likes this.
  16. Sep 23, 2023 at 12:13 PM
    Jord4n007
    Jordan
    New Orleans
    lol I have never heard anyone refer to T-Taps as “vampire clips” - I like it
  17. Sep 24, 2023 at 11:37 AM
    RTedder2
    Roger
    The black U3 connector maybe the one i need. It's the right shape and pin number
