12v Power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Snoyota, Jan 24, 2011.
  1. Jan 24, 2011 at 11:29 PM
    Snoyota
    Snoyota [OP] Well-Known Member
    Taylor
    Marin County, CA
    07 Black Dbl Cab Sport
    3" King coilovers with resi, king rear shocks with resi, ome dakar leafs, 4xinnovation kickout sliders, CBI front bumper, warn M8000 winch K&N filter. Pioneer deckplate with 500w alpine amp and 13" Focal Sub
    I want to wire up some off road lights and compressors, etc. I dont want to tap into an existing 12 volt power source under the dash. If I get a fuse box and wire it to the battery and connect the accesories directly to that fuse box, will that work?
    Thanks for the help
  2. Jan 25, 2011 at 7:51 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    If you are talking about a tank air compressor than you will need a power inverter for the compressor. I was going to recommend running it off your Bed outlet 12V but it can only handle about 400 watts. You can buy an external inverter for higher wattage and hook it to battery for temporary uses of your compressor then store it when done.
  3. Jan 26, 2011 at 1:48 AM
    Snoyota
    Taylor
    Marin County, CA
    not what i meant
  4. Jan 26, 2011 at 2:00 AM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    http://www.tacomaworld.com/forum/technical-chat/103969-electronics-basics-reference.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/127538-wiring.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/130265-aux-fuse-block-where-locate.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/103200-blue-sea-fuse-block-install.html
