12v USB install
Discussion in 'Audio & Video' started by boxxed, Sep 13, 2021.
  1. Sep 13, 2021 at 9:12 AM
    boxxed
    boxxed [OP] Well-Known Member
    Denver, CO
    09 Off Road
  2. Sep 13, 2021 at 2:38 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    My cap light ran on batteries.
  3. Sep 13, 2021 at 2:55 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    The frame rail is easy to hide wires in and you won't need to drill anything into cab. Just zip tie and wrap in wire loom. I bought a pack of trailer wire in multi colors for extra circuits like this so I don't get them mixed up at the battery.
    I'd run a wire maybe a 12-14 ga all the way back from battery with it's own fuse on battery side. You can cut into bed or into door or cubby storage and mount a plug. That way you can use the light even when the truck is turned off. Optionally you can put a switch on it to turn it off when not in use or If you were worried about battery drain you might be able to find an inline low voltage shut off.
    I ran a 4 ga wire to a blue sea panel with USB and 12v plug and mounted that in a upper part of bed. When I get load of dirt I cover it and cubby doors with tape. I also run a compressor through same and it hides in my cubby. It has an on/off switch and I keep them off most of time.
    boxxed[QUOTED][OP] likes this.
