12v water heating element selection help
Discussion in 'Technical Chat' started by Rujack, Feb 27, 2019.
  1. Feb 27, 2019 at 8:26 AM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I have one of those DIY ABS water tanks on my truck and I want to add a 12v heating element but not sure what is safe and sufficient. The tank is 4” ABS and ~8 gal capacity. I will thread on a metal pipe section where the element will install so as to not melt the plastic. Brass, aluminum, etc., not sure yet.
    I have a single battery atm, an x2 power group 27M @ 90ah.
    Looking at something like this:
    12 Volt 300 Watt 9 3/8 Inch DC Submersible Water Heating Element https://www.amazon.com/dp/B01BT9JEV6/ref=cm_sw_r_cp_api_i_zNRDCb3CEG7BV
    If I calculate a 25amp draw (did I do my math right?: 300w / 12v = 25amps), I can safely run this while the truck is running, and for about an hour or so with the engine off.
    Amirite?
  2. Feb 27, 2019 at 1:47 PM
    penadam
    penadam Well-Known Member
    Denver
    2003 Double Cab Tacoma TRD
    Your amp draw math is right. Since this is a constant power device when you're running your truck and it's charging at 14 V, you'll use ~21 Amps and you'll use ~25 when it's off. You'll heat your 8 gallons of water ~15 Deg F an hour given no heat loss from the tank.
    Note that your battery has a 20hr capacity rating of 90AH. This means that over 20 hours, it can discharge 90 amps, or 4.5 amps/hour. If you discharge at a faster rate, you'll get less capacity out of the battery. Peukert's law predicts that you'll get around a 63 AH capacity discharging at the 25 amp/h rate.
    If you're going to build this, make sure you incorporate a temperature switch for the heating element and a T & P relief valve, and your materials are rated for at least the temperature and pressure (simultaneously, remember PVC's strength decreases sharply with elevated temperatures) the relief valve are set for. A water heater left too long could eventually burst your tank, and if it's gotten hot enough, you'd be looking at a steam explosion.
    Matic likes this.
  3. Feb 27, 2019 at 1:52 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Impressive.
    I was like.........
    6 gearT444E likes this.
