12volt solutions remote start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toytaco112, Dec 4, 2019.
  1. Sep 17, 2022 at 2:52 PM
    #41
    TacomaDblCab
    TacomaDblCab Well-Known Member
    Virginia
    2011 Tacoma Dbl Cab Off Road
    Window Tint, Kenwood DDX 470, Polk Audio DXi6500 (front), Polk Audio DXi650 (rear)
    I've had the remote start for quite some time, but after installing it the horn no longer beeps when locking or unlocking. I sent an email to 12volt, but they never did respond. Has this happened to anyone else? Also, after replacing the battery in the long range remote the beeping sound you get when the vehicle starts doesn't happen. It will beep when you remotely turn it off, but not when it starts to let you know it's running.
  2. Sep 17, 2022 at 7:31 PM
    #42
    toytaco112
    toytaco112 [OP] Sup
    Cedar Park, TX, US
    2012 Tacoma DBLCB 4x4 short bed
    King 2.5 Extended travel coilovers, JBA UCA's Deaver stage 2 leaf pack, All pro Aluminum replacement front with 9500lb smittybilt winch, cheap ebay rear replacement, 285.75x16 BFG All- terrains on Method NV wheels, Air ride bags light bars, rock lights bumber light bar And the list goes on..
    Mine stopped making the noise as well when unlocking locking truck Ive had the remote start installed in my truck for a couole years as well… I recently replaced my battery in the remote as well and I did a reset on the control module and it fixed the noise when starting the truck…
    Hope that helps
    TacomaDblCab[QUOTED] likes this.
  3. Sep 17, 2022 at 8:04 PM
    #43
    TacomaDblCab
    Virginia
    Thanks. I unplugged the module and plugged it back in. Must have been the same as doing a reset. It works now. It still has an occasional no start. It will just turn over and not start. Sometimes starting on the 2nd try. Does yours ever do that?
  4. Sep 17, 2022 at 8:41 PM
    #44
    toytaco112
    toytaco112 [OP] Sup
    Cedar Park, TX, US
    Only issue Ive had with the truck not starting is when I first got it It would just crank and crank but not start it ended up being my wireless Scanner/diagnostic tool it has the auto turn on when truck starts so it wont drain your battery when the truck is off Not sure why Bc now I have ScanGauge and i leave it plugged in and have no issues with truck starting… But I reset my module by holding a couple buttons waiting for it
    To blink green then red I have the reset procedure somewhere just need to find it when I do ill share it woth you. That fixed all my issues ilI had after replacing battery and what not…
  5. Sep 17, 2022 at 8:46 PM
    #45
    toytaco112
    toytaco112 [OP] Sup
    Cedar Park, TX, US
    Sent you a PM with the procedures
  6. Sep 18, 2022 at 7:21 AM
    #46
    NmapFE
    NmapFE Well-Known Member
    2014 DCLB 4x4 Limited. 6112’s/5125, KYB Top Hats, SPC UCA’s, Icon RXT leaf pack,
    Installed mine on 2014 Limited. My only issues was not initializing the sending unit because I didn’t read the back of one of the instruction sheets. After that, never had an issue and use it all the time
  7. Sep 18, 2022 at 12:22 PM
    #47
    toytaco112
    toytaco112 [OP] Sup
    Cedar Park, TX, US
    I only carry the remote start remote why do you all carry both for?
  8. Sep 19, 2022 at 5:22 PM
    #48
    NmapFE
    Good question… cause I’m an idiot
  9. Nov 18, 2022 at 8:22 AM
    #49
    E-Paz 732NJ
    E-Paz 732NJ Well-Known Member
    Eric
    NJ
    2015 Tacoma TRD-OR
    Has anyones fob stopped making sound?
  10. Nov 18, 2022 at 9:59 AM
    #50
    NmapFE
    Mine that did stopped working all together but I’ve not reset it. Give them call.
    E-Paz 732NJ[QUOTED] likes this.
  11. Nov 18, 2022 at 11:08 AM
    #51
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    replace battery.
  12. Nov 21, 2022 at 7:04 AM
    #52
    E-Paz 732NJ
    Eric
    NJ
    2015 Tacoma TRD-OR
    DId that in both Fobs and neither plays the sound when turning on/off... just lock and unlock beeps.
  13. Nov 21, 2022 at 7:12 AM
    #53
    TegoTaco
    Ontario, Canada
    Unplug the antenna for a few mins and try that…once in awhile mine will do the that.
    E-Paz 732NJ likes this.
  14. Nov 21, 2022 at 4:45 PM
    #54
    Nalex
    Nalex Well-Known Member
    2012 Tacoma DC TRD OffRoad
    When you turn on the truck using the remote starter why the oem fob sometimes would lock and unlock the truck and sometime does not work?
    Also does the truck beeps when you locks and unlock using the remote starter fob?
  15. Nov 22, 2023 at 11:09 PM
    #55
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I just installed on my 2013. The truck no longer beeps when locking/unlocking. I kind of wish it still did that as I use that sound to confirm operation from inside the house when I can't see the truck on the driveway... is there a way to turn the beeps back on?
  16. Nov 24, 2023 at 7:25 AM
    #56
    NmapFE
    Not sure why that happened after installation. I installed mine a few years back on my 2014 and the beep still worked as factory. There is a way to turn the “beep” on and off from the key fob from what i remember. The factory key fob. Youtube it and see if that helps?
  17. Nov 24, 2023 at 5:51 PM
    #57
    Nalex
    The car won’t peep when it turns on. The park lights will be on. the two way remote will peep a couple of times to confirm that the car is on. After that it will flash every few seconds.
    TegoTaco likes this.
  18. Nov 26, 2023 at 7:34 AM
    #58
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Correct. I emailed them and they said the beep goes away because they tie into the door locks rather than the main system.
    Does this then/now disable the factory alarm system? I haven't played around with the alarm to see if it still works?
    NmapFE likes this.
  19. Nov 26, 2023 at 10:57 AM
    #59
    NmapFE
    My factory alarm works as normal. Factory fob still work etc.
  20. Nov 26, 2023 at 11:32 AM
    #60
    TegoTaco
    Ontario, Canada
    Same here!
    NmapFE[QUOTED] likes this.
