"13 head unit album art?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rawdog, Jan 18, 2013.
  1. Jan 18, 2013 at 9:52 PM
    rawdog
    rawdog [OP] Well-Known Member
    Kelowna B.C.
    2016 TRD Sport Upgrade PKG DCSB
    Am I mistaken or is the new screen head unit in the 2013's supposed to show album art if playing off your iphone?
    I'm talking non JBL system, there is a spot where the album art should be shown but its never there.
  2. Jan 18, 2013 at 10:19 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Yes.
    It will only display if you have it connected via cable. It will not show up via BT.
  3. Jan 19, 2013 at 12:24 AM
    rawdog
    Kelowna B.C.
    No that didnt work either
  4. Jan 19, 2013 at 2:00 AM
    Conex
    Conex Well-Known Member
    You have to turn it on in the radio settings. Sometimes mine is slow to show it on the screen.
  5. Mar 12, 2013 at 3:13 PM
    LennyTheLip
    LennyTheLip Well-Known Member
    Long Branch, NJ.
    2013 SR5 DCSB
    Tint and tonneau for now
    MIne usually shows up when connected via cable, occasionally it doesn't. The interface seems a touch quirky also. If my radio is on, and I switch between ipod and radio, then back to ipod, I get no sound. I have to turn off radio, and turn back on.
  6. Mar 12, 2013 at 3:20 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    I will get some of the album art through pandora and spotify when streaming BT, it is hit and miss.
  7. Mar 12, 2013 at 7:55 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Yeah! I find that on my radio, it's a hit and miss too. The album does work though through my Iphone if it's connected though the usb connection.
  8. Mar 14, 2013 at 9:59 PM
    Soundwave
    Soundwave Well-Known Member
    B.C. Canada
    2013 TRD sport Double Cab 4x4
    OEM Roof rack
    I have had the same issues! Album art generally works, it looks nice, but I find somtimes I get no audio when I switch to ipod mode. I thought it was because I have an old iphone 3Gs, but I guess its a common issue?
  9. Mar 14, 2013 at 10:31 PM
    RoosterCogburn
    RoosterCogburn I have ten reputation points
    Vick Vinegar
    Ass Kick USA
    2013 DCSB 4x4
    I have a 2013 non-etune, and have never seen album art, but I also don't own an iphone or ipod. I'm not a big fan of apple products (actually itunes is my problem), so unless I get an aftermarket double din, I don't think i'll see anything lol.
    Also, the 2013 audio manual booklet (or whatever its called) has the compatible ipod/iphone list somewhere on there.
  10. Mar 15, 2013 at 6:26 AM
    On An Island
    On An Island Assimilated
    David
    Houston-ish
    '12 Black 4x4 DC LB TRD Sport
    Bilstein 5160 reservoir rear shocks, Bilstein 5100 height-adjustable front shocks, SuperSpring SSA19 leafs, Westin bull bar, KC Apollo Pro 6" spotlights, Leer 100XQ cap, K&N air filter, AntennaX 13" Euro antenna, tailgate washers, spare tire tool guide, Console Vault, FJ silver wheel caps
    I don't think that this is your problem, but it is something to consider.
    Depending on the size of the jpeg that is stored for your artwork, it can take a long time for the image to display onscreen. I loaded some larger-size images into my iTunes catalog and every one of those took a lot longer to display than the "stock" ones. I replaced them with small images and everything was back to normal.
  11. Apr 10, 2013 at 4:04 PM
    TacoVerde742
    TacoVerde742 Member
    Christian
    Gettysburg, PA
    2013 Double Cab SR5
    There is a way to turn the Album art on and off. Go to Setup, then hit General, and there should be an option for Display Animation or Captured Images. Make sure they are set to ON and then make sure you Save your new settings. This worked for me.
  12. Apr 10, 2013 at 4:19 PM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    I have a 2013 non-etune head unit and I get album art when I connect my I pod with the USB cable. I can also operate my ipod through the touch screen. I am totally amazed that my 13 reg cab 4x4 with crank windows has this unbelievable head unit.
