13 mpg city
Discussion in '1st Gen. Tacomas (1995-2004)' started by Solar King, Dec 22, 2011.
  1. Dec 22, 2011 at 11:42 PM
    Solar King
    Solar King [OP] Member
    WEST LA, CA
    00' Tacoma V6 2wd TRD xcab Stock
    My morning and evening commute is 3.5 miles, with about 7 stop lights to deal with, some days I get all green light some days all red lights, some days mix.
    I use to average 17 mpg easy. For the past 4 fill ups i noticed I am now averaging 12.5 mpg. :confused:
    145K miles, K & N air filter, stock tires (40psi). Chevron or 76 station (87) octane gas.
    Any suggestions would be appreciated.
  2. Dec 22, 2011 at 11:45 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Clean the MAF w/ MAF cleaner (its probably oily due to your K&N), get rid of the K&N and run a paper filter, clean your throttle body and change the fuel filter. And you should get back up to 17-18mpg in the city.
    And if you haven't done plugs and wires recently, do them too.
  3. Dec 23, 2011 at 12:28 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Winter gas. Though we don't have much of a winter in california we still get winter gas which will lower your mpg.
  4. Dec 23, 2011 at 12:30 AM
    TacoMX
    Jonathan
    Deltona, Florida
    could be a contributing factor...but not a 4+mpg loss factor
  5. Dec 23, 2011 at 12:33 AM
    pancho
    pancho Go home Nubbs, street lights are off!
    Pancho
    Southern California
    18 Cement OR 4x4 DCSB
    Black out emblems. TRD Pro grille.
    for me it has dropped the mpg. and I drive a 4 banger
  6. Dec 23, 2011 at 1:07 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    What they said also remove the lead foot mod that helps a lot. lol :D
  7. Dec 23, 2011 at 1:40 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    sub"d I get terrible terrible mileage, aka 200 miles a tank, Il l try anything!
  8. Dec 23, 2011 at 6:54 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    I'm suffering a 3-4mpg loss lately as well. I chaulked it up to winter gas at first, then decided to change my plugs and wires. So far I havn't noticed a return to the norm (17mpg) but it's only been through 1 tank. I guess I should clean the MAF and replace the fuel filter if it doesn't get better soon
  9. Dec 23, 2011 at 10:54 AM
    Solar King
    WEST LA, CA
    My 1st. Step will be clean the MAF sensor, because I have the time to do it today.
    What about cleaning the K&N filter instead of installing a paper one?
  10. Dec 23, 2011 at 10:57 AM
    TacoMX
    Jonathan
    Deltona, Florida
    Yeah, the K&N requires regular cleaning. But because it requires oil you will just keep getting oil on your MAF, and the K&N isn't the best for filtration efficiency.
  11. Dec 23, 2011 at 10:59 AM
    Warhorseforever
    Will
    Sand Lapper
    The AFE Pro Dry is the filter of choice I believe on TW.
  12. Dec 23, 2011 at 11:01 AM
    TacoMX
    Jonathan
    Deltona, Florida
    Best IMO, is OEM denso filter. Purolator pure one filters are also very good.
    OP: Keep in mind that high flow filters have little to no effect on gas mileage.
  13. Dec 23, 2011 at 11:03 AM
    Aw9d
    Aw9d That one guy
    When I clean any filter that requires oil, use very light oil.. don't saturate the hell out of it. I also let mine sit for about 2 days to let any access oil drip off the filter.
  14. Dec 23, 2011 at 11:35 AM
    Solar King
    WEST LA, CA
    1 step: Clean MAF sensor
    2 step: Install paper air filter
    will bounce back in after a full tank run and let you all know my results.
    Be back after the new year.
    Happy holidays bro's.
  15. Dec 23, 2011 at 11:37 AM
    TacoMX
    Jonathan
    Deltona, Florida
    good luck :cool:
  16. Dec 23, 2011 at 5:04 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Psh. got 9.73mpg the tank before last..what are you bitchen about? lol
    Have you seafoamed before?
    Stock exhaust?? No codes being thrown?
  17. Dec 23, 2011 at 5:17 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I've been getting 12-14 mpg for the last 2 months. I think it is a combination of winter gas, studded tires, cold weather, and the use of 4wd. In the summer I was getting 18 city, 21 highway...Hopefully it goes back to normal in a few months.
  18. Dec 23, 2011 at 5:20 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    2nd gen here.
    Mine has decreased 20 miles or so to the tank. Damn winter
  19. Dec 23, 2011 at 5:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Consider also, along with the winter blend fuel, that a 3.5 mile drive, is barely enough to get the engine up to operating temp. Most of your comute is spent with the system in Open Loop, so its running rich.
  20. Dec 23, 2011 at 5:31 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    You drive a truck, you won't have great MPG. If you are So concerned about MPG trad truck in for Prius.
    /thread
