13 mpg city
Discussion in '1st Gen. Tacomas (1995-2004)' started by Solar King, Dec 22, 2011.
  1. Dec 23, 2011 at 5:37 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Open loop is just one of the ways that the ECU handles the AF ratio. there is Open loop, closed loop and WOT.
    I think open is just dumping in fuel to make it run, basically..i can't remember tho..
    closed is very specific amount calculated to the millisecond basically. (when your warmed up at Idle or with CC)
    WOT...no explaining needed :p
    i think..been a while since i have gone over that stuff..it'll need confirmed/corrected.
  2. Dec 23, 2011 at 5:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    "Open Loop" means the Air/ Fuel ratio is dictated by what signals the ECU reads from the coolant temp, and MAF sensors. When cold, it runs rich to aid in warming up the engine safely. When "Closed Loop", the ECU now takes its info from the O2 sensors.
  3. Dec 23, 2011 at 5:57 PM
    Cobhc
    Cobhc Well-Known Member
    Eric
    California
    Interior: Ecometer, Pioneer Avic F-900BT. Under The Hood: TRD Cold Air Intake, Painted Engine Cover. Exterior: Heavy Tints, OEM Roof Rack, Painted Wheels, Dual Exhaust Flowmaster 50 Series, Tail Light Guards, Avid LightBar with KC 775 Lights, BakFlip F1 Tonneau Cover, AMP Research Bed Xtender HD, OEM Bed Mat, GoRhino Hitch Step, Vent Visors, Blacked Out Emblems, 3" Carbon Fiber Antenna...
    Look into maybe getting an ecometer. Having a meter in front of you that shows your instant MPG will help you control your gas consumption. It also shows your overall mpg. I was averaging 18mpg last year, I'm at 19mpg this year.
    http://www.autometer.com/ecometer/
  4. Dec 23, 2011 at 8:40 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    true.
    Would letting your truck warm up to operating temp before you drive it help negate this? Or are you just wasting fuel letting it idle?
  5. Dec 23, 2011 at 9:54 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    You burn fuel idling too so most likely it would yield same result MPG wise...
  6. Feb 20, 2012 at 9:44 PM
    Solar King
    Solar King [OP] Member
    WEST LA, CA
    00' Tacoma V6 2wd TRD xcab Stock
    I'm back. I have run 3 full tank cycles.
    1st tank 87 octane = I cleaned my MAF sensor and installed a paper air filter. = 13 mpg
    2nd tank 87 octane = Cleaned my K & N air filter with the K & N cleaner kit and re installed it. = 13 mpg
    3rd tank 91 octane = With K & N air filter. = 12.5 mpg
    I typically drive 3.5 miles each way to work and about 25 miles on the weekends on PCH highway.
    So what's next? Any ideas?
  7. Feb 21, 2012 at 6:25 AM
    Madjik_Man
    Colorado Front Range
    A 3.5 mile commute is a gas killer.
    The only thing I can suggest is using cruise control as much as possible.
  8. Feb 21, 2012 at 6:36 AM
    cgs2k2
    cgs2k2 old man
    Try un plugging your battery and cleaning off your MAF (mass air flow sensor) with some electronic cleaner. If you look at the little bulb and it's black, it should be orange. That has always helped me a little bit. I clean it after every oil change or so.
  9. Feb 21, 2012 at 7:33 AM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    You know i've been on the quest to boost mine back up as well. I'm getting around 220 a tank and i hate it.
    91 octane
    Rebuilt throttle body
    Clean MAF sensor
    New Filter
    Oil is only 2k miles old
    fresh plugs
    fresh wires
    fresh batt
    tires rotated, and road force balanced
    well lubed Zerks
    Light foot
    And i still am getting shit MPG
  10. Feb 21, 2012 at 8:18 AM
    Madjik_Man
    Higher octane in our engines typically yields lower mpgs
  11. Feb 21, 2012 at 8:21 AM
    Madjik_Man
    I get my best mpg with 85. But use 87 just because I don't want potential knocking and pinging
    91 is pretty much just used for much newer engines, turbo charged or high performance motors
    I wrote up a long post on this not too long ago... basically regurgitating what I learned on the Legacy GT forum
