13' Taco barely started this morning and smog pump not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BronsDaGreat, Feb 25, 2014.
  1. Feb 25, 2014 at 5:58 PM
    BronsDaGreat
    BronsDaGreat [OP] Well-Known Member
    Bronson
    Wahiawa, HI
    13 TRD Sport DCSB
    6" FabTech Lift 20x12 Fuel Hostage Wheels 33x12.5 Toyo M/T Camburg Uni's UCA Spintech Muffler AppRadio 3 BHLM Wet Okole Seat Covers WeatherTech Floor Liners WeatherTech Vent Visors 6000k HID Headlights and fogs All Lighting Changed To LED AntennaX 13" Antenna Ceramic Tint K&N Drop In Filter Fully Debadged Blacked Out Emblem
    My truck barely started this morning like I had left the lights on or something and I noticed that I cant hear my smog pump when turning off the truck.. Last night I changed the Fog anytime mod fuse holder with one with a thinner wire and I installed an ELM 32 OBD2 reader for use with dash command app for iphone.. Whats going on? Will the smog pump not working damage my truck in any way? My truck seems to be starting fine now but the smog pump is not going off.. Thanks..
  2. Feb 25, 2014 at 6:05 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Intermittent starting problems are semi-common in these trucks. I've had probably a half dozen slow starts. It could be related to your mods but it could also be the random rough start. Some folks attribute it to the fact that our trucks come with 2 different kinds of spark plugs in them.
  3. Feb 25, 2014 at 6:06 PM
    bjboucher
    Brad
    San Antonio, Texas
  4. Feb 25, 2014 at 6:33 PM
    BronsDaGreat
    Bronson
    Wahiawa, HI
    13 TRD Sport DCSB
    Thats a relief!! all my mods connections are good to go!! Another question is I started my truck about 8 times in a row to see if the smog pump was supposed to work every time when shutting down.. is it suppose to work every single time or only when needed to pump clean air?
  5. Feb 25, 2014 at 8:19 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    i have heard of the OBD bluetooth adaptors draining batteries.
  6. Feb 25, 2014 at 9:16 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    LOL Some funny shit there!
  7. Feb 25, 2014 at 9:26 PM
    nd4spdbh
    SoCal
    the fact that starting issues can be caused by the 2 different types.... or the fact that there are 2 different types.
    The former, yeah thats laughable.... different plug manufacturer are not the cause.
    The later is true... every 1GR has 3 denso and 3 ngk plugs.
  8. Feb 26, 2014 at 4:34 AM
    bjboucher
    Brad
    San Antonio, Texas
    Just passing along what I've read. Several folks that have replaced the stock plugs said they no longer have the issue.
  9. Feb 26, 2014 at 6:06 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Maybe your pump continued to run killing the battery and now the pumps toes up from running all night.
  10. Feb 26, 2014 at 7:50 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It is funny some think that Toyota using Denso and NGK plugs causes starting issues. They are the same Type plug ( heat range etc ) just different Manufacturers.
  11. Feb 26, 2014 at 8:03 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    What's the real reason for the 2 'different' plugs then?
  12. Feb 26, 2014 at 8:08 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    Mine doesn't work each and every time. Only if I start, let run for a minute or so, and turn off. If I just turn on and off, it doesn't pump...
  13. Feb 26, 2014 at 8:16 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    The intermittent start is normal, my 08 and 11 both did it on occasion (when it was really cold out and had been sitting for sometime). Forget the explanations I got when I asked here, something with fuel pump.
  14. Feb 26, 2014 at 8:29 PM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    I've heard that if it's been sitting, you should turn the truck to on for a second before starting to "prime the fuel pump". Still seems to be a far between intermittent problem. As far as hard starts, my 2011 did it once and my 2013 did it once the first month I had it. Tried again, and it started right up. Personally, I never allow time to "prime the fuel pump" when starting, so I find that reasoning hard to believe...
  15. Feb 26, 2014 at 9:25 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Toyota keeps two major suppliers on the hook for Quality Spark Plugs. Then if one has production issues the other can usually step up and cover the void. It is a cover your ass thing.
  16. Feb 26, 2014 at 9:26 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You shouldn't have to prime the pump unless there is a leak or leak by somewhere.
  17. Feb 26, 2014 at 9:46 PM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    Agreed...again, hard to believe that is the reason...
  18. Feb 26, 2014 at 9:53 PM
    ASUAviator
    ASUAviator Well-Known Member
    Anchorage, AK
    Tacoma TRD Off Road
    Ive had 2 starting issues I can think of in the year Ive had my '13. Once after a long cold night and the other after not starting it for a week. Both times I immediately turned the key to start it and the engine 'coughed' while turning over. Now I wait a second when starting in these conditions to let the fuel pump prime and have not had a problem since. Its common sense when you think about it. Nobody starts running a marathon when there alarm goes off at 5am. Give it a second to wake the systems up and let her have it.
  19. Feb 27, 2014 at 4:50 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    The pump runs when the key is first turned on, stops then runs again as long as you are cranking the engine till it starts. Priming a pump that is all ready primed is a complete waste of time
