13 Taco dash rattles!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hammer Slammer, May 14, 2014.
  1. May 14, 2014 at 5:15 AM
    Hammer Slammer
    Hammer Slammer [OP] Member
    Anyone else have a rattle in the dash on 13 taco 4x?
    Any idea what it is and how to fix it?
    It drives me crazy!!!
  2. May 14, 2014 at 8:03 AM
    Tacomexico
    Tacomexico Member
    Manuel
    Campeche, Mexico
    Tacoma TRD 4x4 white
    None, just got from dealer
    I have some rattle-like noises apparently coming from underneat the passenger seat in my 13 taco 4x as well. It only sounds in uneven terrain and off-road. The seat looks fine and all the bolts holding it to the cabin floor look tight and ok.
    It is driving me crazy indeed!!, so any help would be much appreciated.
  3. May 14, 2014 at 8:31 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    I noticed some rattles in the front of the dash near the windshield when I offroad. It's actually the windshield vibrating on the dashboard.
  4. May 14, 2014 at 9:27 AM
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    You might want to take it into the dealership, show them what is going on. 2013's are not supposed to rattle. It's still under warranty.
  5. May 14, 2014 at 9:41 AM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    What I'm talking about is going down washboard roads...not a city street. Don't know about OP...
  6. May 14, 2014 at 7:06 PM
    Willcory
    Willcory Well-Known Member
    San Antonio TX
    2013 Black Tacoma 4x4
    My 13 does the same exact thing!
  7. May 14, 2014 at 8:34 PM
    luvium
    luvium Well-Known Member
    San Diego
    13 DCSB 4x4 TRD Offroad M.G
    Trimmed front flaps Extra D rings
    I fixed the rattle. It only rattled on cold mornings, driving over reflectors or bumps, it was coming from the center dash by the windshield.
    I took a 3/4 thick piece of hard rubber and cut into a triangle with 1 1/2" sides, then pushed down between the window and dash right in the center, make sure its really snug and down enough so you don't notice it. It took me a few tries and different sizes to get a good fit.
    I really didn't want to dealer to pull the dash out, who know what else would rattle after they pulled it apart.
  8. Jun 2, 2014 at 9:07 AM
    DenisSeattle
    DenisSeattle Well-Known Member
    TRD Off Road
    Mine seems to come from the passenger side of the dash, specifically the left side of the glove compartment area, where there's also a vent.
    It rattles when I turn, not speed dependent, and sometimes when I stop or start at intersections. It sounds like a tire valve cap in a cup holder, rolling from side to side.
    To me as the driver, it sounded like it was coming from all over the passenger side -- the door, under the seats, in the glove box. But a passenger identified the location described above after just a few minutes of driving around a parking lot.
    It goes away sometimes. It never rattles just going down the road. It has nothing at all to do with the fan. Everything works fine.
    The dealer has looked at it and didn't find the problem. They cleaned a lot of leafy stuff out of the air intakes and the rattle continued. I've taken everything out of every cup holder, cubby, console, and the glovebox -- no change in the rattle.
    I suspect (a) some small object fell into the air circulation ducts, or (b) a piece fell off of something inside a duct or fan housing. I don't know how to get it out, though. As luvium said, dismantling the dash might just introduce more rattles.
  9. Jun 2, 2014 at 9:28 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    For those hearing rattles around your glovebox area, check the cables/wires underneath it. They sometimes bump eachother or hit the panels. I had rattles around there and a few extra zip ties to the cables got rid of them.
  10. Jun 5, 2014 at 4:41 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Mine just started a couple days ago. If I press hard on the center of the dash, near the windshield, it goes away.
    I'll try putting a piece of foam in there and report back.
    Rattles suck!!!
  11. Jun 5, 2014 at 6:39 AM
    wgreenlee1021
    wgreenlee1021 Off the Meds Again...
  12. Oct 28, 2014 at 6:53 AM
    Lespaulkid01
    Lespaulkid01 I prefer the term "beer researcher".
    MoCo, Maryland
    2013 Double Cab TRD Sport, Pyrite Mica
    tool chest, vent visors, tuffy bed box, scangauge, Bilstein 5100's, OME 885x springs, Wheeler's HD AAL, LED map, dome, and reverse lights, Bestop Supertop.
    Old thread, but mine just started this about month ago it's it's driving me nuts. I put a 1/8" thick piece of neoprene between the dash and windshield and it stopped for about 3 days, but it's back now.. I may just need a thicker piece of rubber though.
    Has anyone been able to find the actual source and fix it permanently? Mine is coming from the center of the dash right around the defroster vent.
  13. Oct 28, 2014 at 6:58 AM
    MarkH
    MarkH Well-Known Member
    Mark
    San Jose, CA
    13 PreRunner TRD Off Road
    Just had my 2013 in the shop for a dash rattle, took them all day but they finally found one of the heater ducts was the source of the rattles. They installed some extra insulation around this duct, and secured it all in place, and no more rattles. Well at least so far.......
  14. Oct 28, 2014 at 7:05 AM
    Lespaulkid01
    MoCo, Maryland
    I wonder if that's what mine is.. If I press on the dash right next to the defroster vent, the rattle stops. I was thinking maybe it was the vent rattling against the actual duct.
  15. Oct 28, 2014 at 7:09 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I used two strips of 1/4" thick x 3/4" wide x 12" long neoprene. The rattle has been long gone.
  16. Oct 28, 2014 at 8:21 AM
    Lespaulkid01
    MoCo, Maryland
    Maybe I'll try that. Where'd you get the strips from?
  17. Oct 28, 2014 at 8:26 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    It's the stuff that I use for my tailgate caps. I've got piles of it. Order a cap and I'll throw some extra in the box :cool:
