13 tacoma leafs bad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dnobz28, Aug 28, 2018.
  1. Aug 28, 2018 at 1:55 PM
    dnobz28
    dnobz28 [OP] Member
    My 2013 4x4 has about 80k miles looking for feed back about the leaf springs. Found no recall on my truck but the end of my bed bounces up and down when going around 50 mph. Seems that the bed sinks dramaticly with any wieght in the back. Leafs look like there almost bending down. Looking for new leafs or should i jus add a leaf? Thanks
  2. Aug 28, 2018 at 2:46 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Get a new leaf pack(Dakar). Or check craigslist for set of oem recall tsb pack if you're not gonna lift the truck. If your stock pack is still decent, you can get 3 leaf aal setup.
  3. Aug 28, 2018 at 2:55 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Your 2013 is likely out of the window for the TSB for driveline vibration where you could of gotten the 3+1 leaf pack from toyota. Your 2013 TRD OR has stock a SUUUUPPER shitty 2+1 leaf pack (they though they would put softer suspension on the rear of the TRD OR to make it more compliant off road).
    That stated i had the TSB done to my truck, and the 3+1 leaf pack with single 2in AAL i have is alright, but dakar EL095R mediums are currently on their way to replace those shitty stock soft ass noodle springs.
    12TRDTacoma likes this.
  4. Aug 28, 2018 at 2:56 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I wish Toyota wrote checks for TSB. If I am going in for a TSB, at least give me the option to get cash towards a better, aftermarket option. Don't replace shit with shit..
  5. Aug 28, 2018 at 4:51 PM
    Pigpen
    Dan
    Northwest Montana
    All 2nd gen leaf springs suck, including the TSB. Get some Dakars.
    AustinPizzini and ChadsPride like this.
  6. Aug 28, 2018 at 4:59 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Mine were replaced when they replaced the frame.
  7. Aug 28, 2018 at 5:18 PM
    nd4spdbh
    SoCal
    FYI everyone.... ebay is doing a sale today 15% off and most of the dakar packs you can find on ebay are eligible. FYI i made an offer to a seller on ebay on sunday for 350 shipped for a pair of EL095R's and they accepted.... wish i had waited to pay till today cus that woulda been 300 bucks for a full set of dakars! O well.
    geekhouse23[QUOTED] likes this.
  8. Aug 28, 2018 at 5:19 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    A TSB is nothing more than an aid to assist the tech in diagnosis of a common issue. They aren’t paying you out on it.
  9. Aug 28, 2018 at 5:23 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I used a 3 leaf AAL (Dealer F59) when my truck was new and was experiencing axle wrap under hard braking. Best decision I could had ever made. I loaded up a rear end of 300 lbs at least (4X4 K1500 GMC Yukon full on rear end axle assembly) recently and the rear end didn't even squat or sink. The stock 4 leaf pack is decent if you have a quality AAL backing it up. That is just my opinion.
  10. Aug 28, 2018 at 5:35 PM
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    my 13 sr5 stock leafs sucked, especially when towing anything, said the hell with it and put OEM dakers on it and now its much better...
  11. Aug 28, 2018 at 5:49 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    :smack:
    Stop it!
    You know that makes too much sense for them to do!
  12. Aug 28, 2018 at 5:52 PM
    geekhouse23
    Yep. I would tell the Toyota techs the same thing about getting a check every time I saw a truck in there getting a leaf TSB.
    PackCon[QUOTED] likes this.
  13. Aug 28, 2018 at 5:54 PM
    Bishop84
    Bishop84 Well-Known Member
    Sounds like the shocks are on their way out causing the bounciness.
    The leaf's suck but may not be the cause of the complaint.
  14. Aug 28, 2018 at 5:56 PM
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    I added a Wheelers AAL to mine and it sorted it right out. Not bad for $60, I think it was. No more arse sag and no need to replace the pack. Yes I have hauled a fair amount of weight in my Baja...
    Cheers, :cheers:
  15. Aug 28, 2018 at 8:06 PM
    nd4spdbh
    SoCal
    Agreed.
    I have the wheelers 2in single AAL and axle wrap is SO oh SO SO bad with them, its scary how bad it is and how hard it has to be on the driveline.
