'13 V6, 4500 miles and my motor may be shot!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hotrod53, Feb 21, 2014.
  1. Mar 13, 2014 at 4:06 PM
    #221
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    If I posted a video of my truck "tapping" you guys would shit your pants :laugh:
  2. Mar 13, 2014 at 4:07 PM
    #222
    TCRAWFORD
    TCRAWFORD Well-Known Member
    Socal
    14 DCSB SR5 4x4
    Debadged, WeatherTechs, Wheelers Type A steelies, 265/75/16 BFG AT K/O
    You have my attention
  3. Mar 13, 2014 at 4:09 PM
    #223
    XXXX
    sKiP
    05 Prius
    Imagine a angry dwarf with a sledgehammer in your engine bay trying to escape.
  4. Mar 13, 2014 at 5:04 PM
    #224
    TCRAWFORD
    Socal
    14 DCSB SR5 4x4
    Yeah that can't be good, fixed under warranty?
  5. Mar 13, 2014 at 5:12 PM
    #225
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Well, that bites. I hope for your sake this goes smoothly and quickly for you. Out of my own curiosity, do you know if the reflash was done on yours? It might be as simple as a fuel or ignition timing issue causing the knocking.
  6. Mar 13, 2014 at 5:19 PM
    #226
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
    I was afraid of that ... Sorry hotrod
  7. Mar 13, 2014 at 5:23 PM
    #227
    MidnightRebel07
    MidnightRebel07 Well-Known Member
    Northside of Pittsburgh, Pa.
    2013 Tacoma BAJA T/X dcsb
    Weathertech floor mats, Go Rhino Dominator II step bars, EGR in channel ventshades, homemade spare tire bed rack, hitch step, K&N air filter and cabin air filter, 265/75/16 Goodyear Duratrac's, Phillips LED headlights, Yellow Jacket yellow foglights, led back up lights, Mobtown tailgate stiffener, Wheeler's 3 leaf add a leaf, Firestone ride rite airbags, Bentrodders bed reinforcement stiffeners, PIAA windshield wipers
    Hotrod, definitely keep us updated on the "Lemon case", mine hasn't duplicated the sound again yet. It did it a couple times before over this winter but I never got a chance to record it with my phone because I had my two year old with me.
    I was out at lunch today and ran into a Toyota tech at lunch. I asked him if they had any other Tacoma's at the dealership with weird noises (described the noise our trucks have been making), he said they've had a couple come in with something similar but they ended up all being power steering pumps freezing.
    On a side note my 2003 Ford Explorer Sport Trac 4.0l V6 has been doing the same sound for the last two weeks at start up until it warms up and I know for fact that the timing chain tensioners are worn out and partially broken and the power steering has been freezing up on it as well.
    It's hard to tell what it could be but I still lean towards some kind of oil pump/ getting enough oil to rotating parts/ timing parts fast enough. Although the whole power steering problem idea kinda makes sense as part of it.
  8. Mar 13, 2014 at 5:32 PM
    #228
    XXXX
    sKiP
    05 Prius
    LOL... Screw Toyota. They are worthless the majority of the time and I could of possibly caused it myself anyway. I took it in once when I set up an appointment with the service manager when he had his best engine guy in and those two douchebags had about 11 points of IQ between them both. Tried telling me it would cost over 1k to even take the head off of it so I got in my truck and said FU. New engines go for just over 1,200 if your lucky like I was when I was looking.
  9. Mar 13, 2014 at 5:49 PM
    #229
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    I have one done every time I change the oil in my Subaru. I will probably do my first one with the Tacoma at my 20K change.
    Did they replace the timing components/accessories or reuse what you had on the truck. I'm just wondering if it's something that was on your existing motor and they re-used it.
  10. Mar 13, 2014 at 5:50 PM
    #230
    XXXX
    sKiP
    05 Prius
    :laugh: My trucks only had the dealer touch it twice in 6 years. Once for TSB springs they screwed me on and never did alignment and the other time was trying to get a starter replaced under warranty when my truck was literally dripping with mud.
    The only good experience I had at a dealer was when I lost my lugnut key and the salesman who sold me the truck overrode the service manager who wanted to charge me $60 to borrow a techs key so I could unlock them in their parking lot. Even after that I was pissed they tried to make money off me.
  11. Mar 13, 2014 at 6:03 PM
    #231
    hotrod53
    hotrod53 [OP] Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    The timing chain idler gear and bearing, sliders and adjusters, serpentine belt pulleys, and oil pump were already new and probably not part of a short block. Most likely reused.
    The noise presents in the lower left side of the block, I thought sure that the short block would have fixed it.
  12. Mar 13, 2014 at 6:28 PM
    #232
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    That's what I'm wondering...if it's something in your existing setup that might be causing the issue.
  13. Mar 13, 2014 at 8:33 PM
    #233
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I am still leaning towards timing chain making noise. Secondary question is why. It could be failed tensioners, it could be stretched. I would think tech working on the truck had checked it but I guess not.
    If chain is stretched that would mean it's not getting enough oil. Maybe clogged jet.
    Either way. It's lemon or they need to give you new engine
  14. Mar 13, 2014 at 8:44 PM
    #234
    MidnightRebel07
    They did give him a new engine (short block), when they should've installed a completely new engine with everything on it from the factory. You pay for a complete engine when you buy it new so you should get a complete new one if it craps out this fast, JMO.
  15. Mar 13, 2014 at 8:45 PM
    #235
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    This is a terrible situation, but like you said probably the best outcome. I wouldn't want a rebuilt motor in a brand new truck.
  16. Mar 14, 2014 at 5:45 AM
    #236
    hotrod53
    Lynd
    Pittsburgh, PA
    I'm beyond the new engine satisfying me at this point. 3 trips in the shop, 33 days out of service since mid January, and now I own a $34,000 truck that has been apart more than an erector set. My Carfax has to be a disaster at this point and it can't help but affect the value if I were to sell it. I just know that all of the work that has been done will be detrimental to me somehow later in my truck's life.
    I wanted a crate engine but they forced me into a short block, I didn't like it, but it was my last ditch effort. I lost the use of my new vehicle all winter, through 3 Pittsburgh snow storms. I have made at least 6 round trips to the dealership, 44 miles round trip, I've taken time from work. I was stuck in peoples driveways twice this year. I had to get a ride home because my loaner Corolla would go in the snow when my brand new 4X4 sat in a nice warm dealers garage. I was unable to go to our camp all winter because it's back in the woods and I wouldn't even take a Corolla there in the summertime. Spring is on it's way and it will be boat towing time, I will need to deliver a couch and loveseat to my son's house in a few weeks, I need a truck, that's why I bought one! :mad:
    I've been patient until it was time not to be patient, I think that time is now, that's why I opened a lemon case yesterday. As I have said all along, my dealer has been great, he can't do something unless Toyota authorizes it. I'll have to go to the next level but I'm not taking any prisoners, my dealer has continued to do his best.... that's why I bought 3 out of 4 Toyotas from him. If Toyota doesn't screw me, that's where my 5th one will come from.
  17. Mar 14, 2014 at 5:53 AM
    #237
    XXXX
    sKiP
    05 Prius
    same location as my gremlin
    You're taking this pretty good.
    One thing you need to do is get a comparable rental. You need to put your foot down about that. Giving you a POS Corolla while working on your 35k truck is not sufficient. You need to tell the dealer you are a contractor and need a 4x4 truck to get to jobsites and such.
  18. Mar 14, 2014 at 6:01 AM
    #238
    hotrod53
    Lynd
    Pittsburgh, PA
    I've already been offered a somewhat comparable rental.... after about day 25, I drove to get it and Hertz where they rented if from, they closed at noon on a Saturday and I couldn't get it! I had to drive the 44 mile trip for nothing! The dealer didn't even know they closed at noon!
    I am a contractor and I use the truck for work and person use. I have been hesitant to this point to ask since I was told that taking payments and such would not shine well on the lemon case. They did offer me 1 month payment so far, when I told them my concern I never heard about it again.
  19. Mar 14, 2014 at 6:02 AM
    #239
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    Damn this sucks.... :(
  20. Mar 14, 2014 at 6:16 AM
    #240
    BlueT
    NorthEast
    Well your frustration is understandable.. Hopefully lemon process goes quick and easy.
    Its obvious that whoever is working on your truck is not very good at it. They just tossing parts at it, with out actually trying to find root cause.. And root cause from what you posted never was in the block. There is nothing inside the block that would buzz. I would imagine any tech would be smart enough, to open FSm and check, what is at that location.
    Problem is (and that's not limited to auto industry) that people with skills are very hard to find, and at the same time, an amount of people relying on those with skills is constantly increasing. That dealer maybe great to purchase cars but you are probably better of servicing your next truck somewhere else.
