'13 V6, 4500 miles and my motor may be shot!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hotrod53, Feb 21, 2014.
  1. Mar 24, 2014 at 6:09 PM
    #361
    hotrod53
    hotrod53 [OP] Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    yes, I am on my second oil pump and yes, copies...lol
  2. Mar 25, 2014 at 5:50 AM
    #362
    JWit
    JWit Well-Known Member
    Joel
    NH
    13 MGM DCLB Sport
    I've got a 13' with 18k miles on it. Been making this noise since day 1, thought it was normal. Subing to see if anyone comes to any real conclusions here.
  3. Mar 25, 2014 at 8:17 AM
    #363
    tony2018
    tony2018 Well-Known Member
    Maybe we should roll deep with all our Tacoma's parked out front, blocking entrances and exits Hopefully the respond with there Tundras.....yes its sarcasm.
  4. Mar 27, 2014 at 11:16 AM
    #364
    happy
    happy Well-Known Member
    Eagle, CO
    '14 DCSB SR5 4x4 Silver Sky
    CBI Moab 2.0, 2.5" Radflo Coilovers, Light Racing UCA, Dakar Leaf Pack, 265/75 16 Kelly Safari TSR, Leer XR100
    I've had my truck back from the dealership for two weeks now. I've put 500+ miles on it, and every morning has been at or below freezing--a few mornings down in the low teens.
    My front cover/water pump/oil pump assembly was replaced. The noise has not reappeared.
    Our tacoma v6's are still noisy engines, but nothing like the video i posted before.
  5. Mar 27, 2014 at 11:30 AM
    #365
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Screw that!
    The burden of proof is on them to prove you mistreated your engine - not to prove you treated it well.
    I suggest you get a lawyer ASAP.
  6. Mar 27, 2014 at 2:03 PM
    #366
    TrdSurgie
    TrdSurgie revised
    Oahu
    Not nessary yet.
    I lemoned a 535 without a lawyer. Smooth system.
  7. Mar 27, 2014 at 3:31 PM
    #367
    TCRAWFORD
    TCRAWFORD Well-Known Member
    Socal
    14 DCSB SR5 4x4
    Debadged, WeatherTechs, Wheelers Type A steelies, 265/75/16 BFG AT K/O
    Thats good to hear, I plan on taking mine in next tuesday. I hope it goes as well as it did for you.
  8. Mar 27, 2014 at 4:57 PM
    #368
    happy
    Eagle, CO
    Have them pull the serpentine belt first thing, that rules out all the "accessories" that it sounds like.
  9. Mar 27, 2014 at 5:42 PM
    #369
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    I actually told them that when I took mine in, their answer was that they couldn't because its not part of the troubleshooting guide/steps from Toyota.. :rolleyes: ..... so their troubleshooting was to make a visual inspection, check for DTCs...... thats it......
    I received my results from BlackstoneLabs, it does not help much right now, after one or two more oil changes it will be valuable as I will have something to compare the new results.
    Basically I had a lot of metal residue and silicone, but since its a new truck its something that they consider normal, so I will need to do another test after at least two oil changes, by then those numbers should be considerably lower.
    Still convinced that this is not normal, even more after listening more to co-workers 13' Tacoma, and reading the post above of the problem being solved.....
  10. Mar 28, 2014 at 6:47 AM
    #370
    tsub345
    tsub345 Well-Known Member
    Travis
    Near Pittsburgh, PA
    '17 Super White TRD OR
    Solid Fold 2.0, Cali Raised LED Stealth mount bar, Tint, Wet Okole Covers, Tailgate/Glove Box Letters
    Sub'd.
    I just traded my '11 with 104,xxx miles on it for the exact same truck in a '14. I am going to have to listen to my truck at lunch today to see if it makes the noise on start up.
    I found this thread because last night when I shut my truck off it made a grinding noise like something was still rotating. It made the same noise this morning when I got to work so I was a little concerned. It only has 800 miles on it.
  11. Mar 28, 2014 at 6:50 AM
    #371
    XXXX
    sKiP
    05 Prius
    Are you saying to pull the belt and start the engine to see if it still makes noise :confused:
    Silicone or silica?
  12. Mar 28, 2014 at 9:11 AM
    #372
    happy
    Eagle, CO
    Yep. That's exactly what my dealership did. It cut straight to the chase. I got a call within 45 minutes that the noise was coming from the engine.
    Epa4wd--in this instance I would be pretty pushy, after all, you just bought a brand new truck for big $.
  13. Mar 28, 2014 at 5:04 PM
    #373
    hotrod53
    Lynd
    Pittsburgh, PA
    tsub345.... be aware that the air pump cycles both when your engine goes from fast idle to slow idle on initial startup and it also cycles as if it is purging just after the key is turned off. Both of these are normal.
  14. Mar 28, 2014 at 5:06 PM
    #374
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    So OP was your motor shot or what?
  15. Mar 28, 2014 at 5:29 PM
    #375
    hotrod53
    Lynd
    Pittsburgh, PA
    MGMTacolover55..... 2 repair attempts then the engine was pulled and a short block installed.... it still makes the noise! I'm on week 2 after filing for Lemon Law.
  16. Mar 28, 2014 at 6:01 PM
    #376
    tsub345
    Travis
    Near Pittsburgh, PA
    Hotrod-I listened to my truck a couple of times at startup today and didn't here the same noise in the video, but I will keep an eye (or ear on it). Trdsurgie let me know that the noise that I am hearing on shutdown is my smog pump.
  17. Mar 28, 2014 at 6:25 PM
    #377
    TugBoatTrash
    TugBoatTrash Face first!! Hammer down!!!
    Bob
    E. Freetown MA
    15 DC Tundra SR5
    Do dents and scratches count?
    My 2014 makes this noise. But, unlike the OP, my noise is very faint. I can hear it but I doubt anyone else would think it was out of the ordinary. It is the same noise though. Sounds exactly like the video. Hoping their is a resolution to this before mine becomes a problem.
  18. Mar 30, 2014 at 4:57 AM
    #378
    epa4wd
    Eduardo
    2019 SR
    Silicon without the "e" my bad.
  19. Mar 30, 2014 at 6:14 AM
    #379
    tsub345
    Travis
    Near Pittsburgh, PA
    So I had to play musical cars in the driveway this morning and I let mine run to defrost the window. After the engine went through its usual start up I could hear the same noise as the video but mine stopped after about five minutes.
  20. Mar 30, 2014 at 6:41 AM
    #380
    hotrod53
    Lynd
    Pittsburgh, PA
    Whatever makes the noise commonly stops when the engine begins to warm up.
