130 Amp alternator question: Biggest DC-DC charger for house battery?
Discussion in 'Technical Chat' started by wi_taco, Feb 9, 2022.
  1. Feb 12, 2022 at 4:26 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Not to hijack OP, but can you post the model number for the controller you went with? I've been looking at Renogy for a similar setup, and couldn't find the details in your build thread. Thanks!
  2. Feb 13, 2022 at 5:03 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    DCC30S
    DeLaCasaTaco likes this.
  3. Mar 2, 2022 at 2:48 PM
    REDARC_Ryan
    REDARC_Ryan Well-Known Member
    Michigan
    2021 Tacoma TRD Off-Road
    OME BP-51's, CBI Covert Bumper, Rhino Rack Roof Rack, Mits Alloy Tray & Canopy, Alu Cab RTT, Falken Wildpeak A/T, RIGID Lighting
    Hey All,
    Sorry for the delay, lots of travel lately so I don't get a chance to check this as much.
    As for alternator size to charger thoughts, we generally say rule of thumb is about half of your alt is reserved for accessories. So with your 130A alt, 65A would be reserved for accessories, radio, 12v plug ins and such. So technically our BCDC1240D should be fairly safe.
    As for picking a charger, it goes a bit deeper. Our general rule is you should have the ability to charge half of your house battery within 3 hours of driving give or take. If you're going to run a 100Ah battery, you can easily replenish 50Ah with our BCDC1225D no problem. So no need to waste money on a larger charger unless you are hoping to future proof yourself when you jump to a larger battery.
    Our BCDC line is a DC-DC charger (ALT), MPPT Regulator (Solar), and Battery Isolator all wrapped into one that can handle Lead Acid, AGM, and Lithium profiles.
  4. Mar 7, 2022 at 4:29 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    I know in my 2017 with tow package (130A alternator) the 12v line on the trailer connector is fused at 40A, so the alternator can for sure handle that additional load on top of all the mandatory truck functions.
  5. Mar 7, 2022 at 4:39 PM
    roundrocktom
    roundrocktom Well-Known Member
    2021 Silver DCLB Off Road
    How much heat is dissipated by the BCDC2540?
    I have a 100Ah Lithium-Ion, I'll drop that into a trolling battery box, but the Redarc 2540 will be bolted on the outside of the battery case.
    It will ride in the truck, but portable so I can leave the fridge at camp, with a solar panel, while out running trails. Also handy at night to run my CPAP.
  6. Mar 7, 2022 at 5:33 PM
    REDARC_Ryan
    Michigan
    Depending on the model the 1225/1240 heat will vary but if its outside of the case it shouldn't be terrible unless you're pulling hard to charge an empty battery.
  7. Apr 4, 2022 at 7:15 PM
    RobotTheDog
    RobotTheDog Well-Known Member
    AZ
    21 TRD OR DCSB CEMENT
    All encompassing layer of dust
    I've got a redarc bcdc1240 that powers a 200ah lifepo4. It's not in the truck full time but I've never had any issues.
    wi_taco[OP] likes this.
