1300 mile tow report
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WOTaco, May 10, 2016.
  1. May 10, 2016 at 2:59 PM
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    Ah I see.
    Thank you!
  2. May 10, 2016 at 5:43 PM
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
  3. May 13, 2016 at 6:11 PM
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    Very nice boat. How long is the boat. Looking forward to taking out my 17 foot boston whaler. Thanks for the tow review.
  4. May 13, 2016 at 6:34 PM
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    With an auto the main reason you don't tow in overdrive is because of the heat buildup. In lower drive gears your input and output shafts are locked.This means for one there is less heat build up, and two there is engine braking (just helpful when towing to take strain off brakes, another system that can have bad reaction to excessive heat buildup..). The reason more heat builds up with overdrive is a few factors compounding each other. For one thing when you are in overdrive the output shaft is then spinning faster than the input shaft, so there are more parts spinning around inside of the transmission, friction between these parts leads to more heat. The other thing is you are now spinning at lower rpm, so your trans pump is not generating as much flow, and the effectiveness of your trans cooler is decreased. Keeping it in drive helps to reduce the internal friction because the input/output shaft are locked, and your rpm is higher so your trans fluid flow is increased and the cooler operates better.
    I don't really see the heat buildup in a manual transmission being any different between different gears (they all operate essentially the same, so the same type of bits are going to be rubbing against each other regardless), so the only reason to keep it in a lower gear is to keep rpm up so your trans pump has more flow to the cooler. if Toyota says to tow in a certain gear, I'd probably listen to them.
    There might be some other reasons, or maybe I'm completely wrong. This is my understanding of things though, so feel free to correct me if I'm wrong (wouldn't be the first time that's happened when I've decided to open my mouth ...).
    Johnny919 likes this.
  5. May 13, 2016 at 6:42 PM
    Johnny919
    Johnny919 Well-Known Member
    Long Island, NY
    2006 Honda Pilot EXL 4WD
    Thanks for the explanation, but don't you mean keeping it in 4th helps reduce the internal friction, not drive?
  6. May 13, 2016 at 6:48 PM
    Syncros
    Syncros Well-Known Member
    Nice review, nice to hear the 3.5L holds 6th fine. Long live the MT!
    WOTaco[OP] likes this.
  7. May 13, 2016 at 6:48 PM
    JoeRacer302
    Joe
    Pasadena, CA
    When I say "drive" I am referring to the "drive" gears that are non-"overdrive." These gears have the input-output shaft locked. In a standard 4 speed auto you have 1-2-3 that are all drive, and then a 4th over-drive. I am not sure about the 6 spd auto in the Tacoma. I don't own one and I'm not familiar with the specifics concerning which gears are the drive and which are over-drive.
    Johnny919[QUOTED] likes this.
  8. May 13, 2016 at 6:51 PM
    Johnny919
    Long Island, NY
    Ah, i gotcha. Yeah, 5th and 6th are both overdrive gears.
    JoeRacer302[QUOTED] likes this.
  9. May 13, 2016 at 6:57 PM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    Still :popcorn: for @gearcruncher
    Thank you @JoeRacer302 for your input.
    I would also like to know more about this for myself. I have the MT, and I do a fair amount of towing.
    JoeRacer302 likes this.
  10. May 13, 2016 at 7:04 PM
    JoeRacer302
    Joe
    Pasadena, CA
    I'm actually not sure if the manual has a trans cooler or not. However, assuming it does, you may look into a trans temp gage. That will tell you if the gear you're running in keeps enough flow through the cooler or not. If the temps are high, drop it down a gear and get the rpm's up to get more flow through the cooler. I'd also do the same if it were an auto.
    This is my first manual truck, so I'm still learning about it myself! My last truck had an old 4 speed auto in it, so I'm a lot more familiar with that kind of setup :)
    holyfield19[QUOTED] likes this.
  11. May 13, 2016 at 7:04 PM
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    @JoeRacer302
    So what about the heat build up? Isnt that where the trans cooler with the tow package helps out??
  12. May 13, 2016 at 7:05 PM
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Yes. I have the trans cooler.
  13. May 13, 2016 at 7:06 PM
    JoeRacer302
    Joe
    Pasadena, CA
    You still have to keep flow through it, and that flow is from a mechanical pump that is rpm dependent. If your rpm isn't high enough then your flow isn't high enough. This all depends on the load, heat being generated, and the flow rate. Really the only way to be sure is if you are monitoring trans fluid temp. If it gets high, then you aren't getting enough flow (or you've simply exceeded the capabilities of the heat exchanger).
  14. May 13, 2016 at 7:11 PM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    2nd gens with the 6mt didn't have a trans cooler. Not sure about the 3rd gen.
  15. May 13, 2016 at 7:41 PM
    #35
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Is the cooler in front of my radiator not the trans cooler??
  16. May 13, 2016 at 7:53 PM
    #36
    Mr. Torgue
    Mr. Torgue Explosions!!?!!?!?
    2016 7544HHBBP
    LED lighting
    That's only part of the equation. Over dive gears put a lot of stress on the gears when towing.
  17. May 13, 2016 at 7:58 PM
    #37
    StevoNB
    NB, Canada
    Yes, I believe so. And you have a 6 speed? When I built my truck online, it specifically said that only the autos came with the transmission cooler as part of the towing package.
  18. May 13, 2016 at 9:42 PM
    #38
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    The manuals do not have a cooler. The cooler you are referring to on your trucks is either the HVAC condenser or the power steering cooler.
    JoeRacer302 and StevoNB like this.
  19. May 14, 2016 at 3:34 AM
    #39
    Gen3inFl
    Gen3inFl Active Member
    2016 4x4 double cab
    Thx. Panga is cool. The Zuk 140 excellent engine, note it's really closer to a 130-135... That said, super solid engine. There are 3 or 4 internal anodes (easy access). They are super thin in diameter (not like the pencil thick ones in Yammy). Most dealers do not look at during routine service. In salt they burn out fast! Plan to replace at every 100 hr service. Very quiet engine, keep it under 5k rpm and awesome fuel economy, (low to mid 4 better). Only issue I ever had is seals on tilt trim, at about 600 hours.
    Do not buy fancy electronic gauge..analog to digital conversion system poor. Save yourself the $500.
    As to weight, think only adding maybe 410lbs with engine (but fuel, ice etc obviously adds more).
  20. May 14, 2016 at 3:58 AM
    #40
    JoeRacer302
    Joe
    Pasadena, CA
    Yea, I wasn't sure if they did. Thanks for clearing up that question :)
    RedBeard1[QUOTED] likes this.
