13mpg.
Discussion in 'Performance and Tuning' started by tommelleo22, Mar 15, 2011.
  1. Mar 15, 2011 at 3:47 PM
    tommelleo22
    tommelleo22 [OP] Well-Known Member
    Joe
    New Castle, PA
    07 trd sport off road
    Yellow Fogs kicker cvr 10's alpine ivaw205 head unit, leveling kit
    running stock rims on 270/70/17 grabber at2's. no cap trucks just leveled motor's stock and i'm currently getting only 13.6mpg. :( please tell me this should be better on my 07 double cab sport.
  2. Mar 15, 2011 at 3:58 PM
    tommelleo22
    Joe
    New Castle, PA
    to be honest after having my 05 Titan LE and the v8 i don't beat on my taco because it's nothing in comparison to the titan i had and i dont want my mpg to drop off so i do baby it and still getting horrid mpg :/
  3. Mar 15, 2011 at 4:02 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    Are you in town driving? if so, keep your rpm's below 2,000. i know it sucks if you have a heavy foot like mine. but if you want better gas mileage, you are gonna have to stay out of it. my best in town is 14.5. my best on the highway is 18.3. driving in town sucks. i was told to burn 87 grade gas also. i did notice a difference with the 87 grade. good luck.
  4. Mar 15, 2011 at 4:05 PM
    tommelleo22
    Joe
    New Castle, PA
    thanks bro and ya mostly town and i never really get on it unless im pulling out and i just stopped running 93 due to outrageous gas prices and calling toyota about my mpg and them telling me they don't call for 93 to just run 87
  5. Mar 15, 2011 at 4:11 PM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    almost 17 here due to new tires 265/75/16 bfg alt ko's
  6. Mar 15, 2011 at 4:14 PM
    curmudgeon
    curmudgeon New Member
    CLee
    San Francisco Bay Area
    4x4 V6 6sp
    Bilstein 5100 @ 1.75" Firestone air bags
    obviously mileage depends on many factors such as percentage city vs highway miles, weather, driving style, % ethanol content, etc. however, the non stock tires are roughly 1" larger in diameter so you are traveling further than your odometer states (unless you've corrected for this) so your mileage is roughly 1.5-2% better than you think. Check your air pressures, try filling with non-ethanol laced gas. For comparsion, I swapped my orginal 245/75-16's for 265/75-16's on the stock rims with the more aggressive Goodyear AT's and dropped 1.5-2 mpg (corrected) with my Access cab 4x4 (lower geared) 6sp stick. Autos get better mpg with their higher final drive. I'm averaging 17-18 mpg if I keep light foot, but drops rapidly if I exceed 75 mph, or if I drive in snow.
  7. Mar 15, 2011 at 4:16 PM
    fj6high
    fj6high Well-Known Member
    Howard
    Tarpon Springs
    07' Fjcruiser
    6"Fabtech +OME Heavies and Custo Skyjackers. Way to much to list.
    My FJcruiser is just as bad as the 05' Taco I traded in. The bigger tires will rob your mpg's everytime!
  8. Mar 15, 2011 at 5:07 PM
    Doug2000
    Doug2000 Well-Known Member
    London, Ontario, Canada
    2008 Toyota Tacoma Quadcab 4x4
    Did you lose 3 mpg with BFG AT, cause I was going to by those, same size.
  9. Mar 15, 2011 at 5:52 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    According to tirerack those are pretty light tires, about the same as my 265/75/16 Duratracs. My 07 4x4 DC has gotten 18.8 last 4 tanks, 90% hiway 55mph. Must be the increase drag from those big stickers on the side. 13 sux man and tire size correction wouldn't explain that. And yeah I ran about 10 tanks of premium fuel (91) consecutively and didn't see any difference in power or mpgs. Sumting wong! How many miles on your 07?
  10. Mar 16, 2011 at 3:17 AM
    brians05taco
    Brian
    Lafayette,La.
    doug was getting 18 easy with my nittos same size tire just 10 lbs lighter than the bfg.. now its 17 if i baby it. the extra weight of the ten ply tires doesnt help at all.... might take that into consideration before u buy....although have no complaints on the tires they ride alot better than the nittos i had
  11. Mar 16, 2011 at 4:01 PM
    tommelleo22
    Joe
    New Castle, PA
    airun i took the stickers off a month after i made them so :D lmao and only 32,000 and the stock tire size yoter is 265/70/17 im slightly bigger but it's barely noticeable to the eye let alone effect my truck even 1 whole mpg. i just don't see why my mpg has dropped off i purchased my tacoma to get a break from the gas station with my 05 Titan lol but at this point if im going to get shit gas with everything im buying a cummins and at least buying a truck tried and trued. with decent mpg hell 91 is almost only 10 cents a gallon cheaper than diesel here in PA
  12. Mar 17, 2011 at 6:56 AM
    Airun
    Aaron
    Show Me State
    Have you ran some injector cleaner? I'm sure youve done air filter and plugs and all that. Seems to run smooth and all?
    May have to take it in to a good mechanic
  13. Mar 17, 2011 at 7:16 PM
    dan0
    dan0 Well-Known Member
    swamplands of sc
    Sold 2011 Prerunner Doublecab 4cyl auto
    My dual cab 2.7 got 19mpg on it's first tank of gas (city)
    supposed to get better after it breaks in
  14. Mar 22, 2011 at 8:04 PM
    jasogonz
    jasogonz Active Member
    Albuquerque
    11' TRD Sport (Taco Rojo)
    satoshi grill (Elusive Elements insert), 6" Fabtech Dirt Logic, 18" KMC XD Monsters, 275/70-R18 BFG T/A ko
    :mad:i get about the same gas mileage too. :frusty:
  15. Mar 23, 2011 at 7:56 AM
    Airun
    Aaron
    Show Me State
    The only time I've gotten that low is loaded down running 75-80 mph on hilly interstate with headwind. Probably bad combo of multiple variables such as driving habits, crappy gas, perhaps suboptimal engine condition and drag/resistance (heavy wheel/tire combos, cruddy bearings or driveline components etc). And of course condsidering calibration of speedo/odo as well.
  16. Mar 23, 2011 at 8:02 AM
    smurf taco
    smurf taco Well-Known Member
    Brian
    Hobe Sound, Fl
    speedway blue 09 prerunner sport 2wd
    brite ass led headlights and fogs, fuel hostage wheels, mellow tone dual exhaust, black westin bull bar, go rhino nerf bars, toyota neoprene black and blue seat covers, image dynamics door speakers all around, Bilsteins 5100s all around set at 0 with maxtrac spindles and eibach coils and total chaos UCAs with OCtaco brakelines all around and all pro expo leafs in the rear running 295/70/17 cooper ST Maxx, cobra cb radio w/ 3ft fire stik, bed lights, jvc double din head unit, AC in cab mod, AFE CAI...more mods to come
    this could be a couple reasons 1. the psi in the tires could be low 2. you could be beatin the truck up where ever you go and 3. you may need to change your air filter
  17. Mar 23, 2011 at 8:08 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    I do better commuting to and from Boston (rush hour traffic) than I do on an open highway. I get 18 mpg commuting and 17 with cruise set on the highway at 73 +/-mph. If it's flat, I can get up around 20 but hills kill the mileage! Not sure what part of PA you're in, but if you're in the mountains that could be the cause. FWIW, I've got a 2007 Dbl cab 4x4 with a cap and running 265/65R17 A/T tires.
