13WL Tundra calipers- OEM part numbers
Discussion in '1st Gen. Tacomas (1995-2004)' started by Arctic Taco, Apr 30, 2023.
  1. Apr 30, 2023 at 6:54 AM
    Arctic Taco
    Arctic Taco [OP] Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    I have a question, does anyone know if these are the correct Toyota part numbers:
    47750-0C022 LH
    47730-0C022 RH
    I’m trying to find out if this pair are the OEM part equivalent of 13WL
    My Google-fu is lacking, I have an inquiry into Toyota Parts deal as well. Most of the search engines on the Toyota parts sites require a VIN number for their fitment.
    I’m looking to replace my front calipers, the driver’s side one randomly sticks then engages with a fairly loud clunk. This happened randomly 3 times on my drive up the AlCan this year, so I think I may have one that is sticking, might be a bad casting? Either way I am going to change and flush the brake fluid, and check the master and slave cylinders as well.
    I am contemplating replacing the NAPA calipers with Toyota calipers- I used NAPA eclipse 13WL calipers, might just be wise to replace the slave and master as well. The truck has 197k on the clock now, so it is probably about time to go though the entire brake system.
    Are these the correct OEM parts?
    Thanks
  2. Jan 15, 2025 at 9:39 AM
    Javi's Taco
    Javi's Taco Active Member
    Were these part numbers correct?
  3. Jan 15, 2025 at 10:19 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Here's what you need:
    This page has a great step-by-step guide (with pics) on the upgrade. OEM is best for the pads, but for the calipers you shouldn't pay the premium. Get them from your local parts store (ideally) or amazon, which will give a lifetime warranty in case you ever need to replace them. And don't forget the upgraded lines, they make a big difference with the larger calipers.
    Step by Step Tundra Brake Upgrade on a Tacoma
