14 Bolt axle swap question.
Discussion in '1st Gen. Tacomas (1995-2004)' started by toypower, Dec 28, 2015.
  1. Dec 28, 2015 at 10:58 PM
    toypower
    toypower [OP] Well-Known Member
    corey
    Niceville FL
    98 Reg Cab Tacoma
    Sas swap, dana 44 high pinion front, Corporate 14 bolt locked, disc brake conversion. 8 inch superlift springs on 39.5 iroks, 5:38 front and rear. Hydraulic assist, 3 inch body lift, Yukon axles front/rear, bilstein shocks, CAI, rock ripper header.
    So I have my rear 14 bolt already under my truck and I know it can't be squared underneath the truck. I'm running 5.38 Yukon gears with the 14 bolt GOV factory locker. Every time I turn at certain speeds my truck automatically starts jumping due to the locker which leads me to believe the axle is more forward on one side than the other. When I first swapped this axle in I played hell trying to get it close to square underneath my truck. Anyone else done this swap? How'd you square yours up?
  2. Dec 29, 2015 at 8:15 AM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    Probably need to get a trambar and measure it out
