14 Bolt Trusses from RuffStuff!
Discussion in 'RuffStuff Specialties' started by Dan Fredrickson, Nov 21, 2012.
  1. Nov 21, 2012 at 11:55 AM
    Dan Fredrickson
    Dan Fredrickson [OP] Steel Hauler Vendor
    Dan
    Sacramento/Flagstaff
    '66 FJ45
    Ok already! Yes we took our time in making these but it was worth the wait ;)
    We don't copy other companies products and when another company made a better truss we stood back and watched and learned, what did we learn? We decided they had a pretty good idea but we found ways to do it better, for less...
    First off, we did not create an Ibeam, while strong it is welded to only one side of the axle. I have seen way too many warped axle housings simply because of that. When you apply a ton of heat to one side without doing the same to the other side what do you guess the odds are that you just warped that axle housing?
    Ours are like all of our trusses for our Custom Axle Housings where the weld points are opposed 180 degrees so when welding you are heating both sides of the tubes evenly and minimizing warp! Thats right, we create a Torsion Box rather than an Ibeam. Just another way to add heaps of strength while minimizing weight.
    Another thing we do is make the Pinion Support part of the package. I do not want to encourage you to weld the housing to the casting only to watch it crack off later, or even worse and warp or crack the casting. The Pinion Support is also made with oval holes so you can run it with or without a Pinion Guard ;)
    Garett will complete a 4 link package using these tommorrow morning and it will have a ton of options like adding a Diff Cover or Pinion Guard or Disc Brake Brackets at discounted prices. Or multiple link options from our Horizontal 4 Link brackets to the simple and inexpensive choices like our link tabs...
    Right now the price looks like it will be $190 for the Truss and Pinion Support :)
  2. Nov 21, 2012 at 12:06 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Woot! RuffStuff is awesome. Love my traction bar from you guys!
  3. Nov 21, 2012 at 12:06 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    That looks awesome!!
  4. Nov 22, 2012 at 8:46 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Thanks guys, we try our best to get you new products!
