14 wides
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sagecalla, Nov 10, 2015.
  1. Nov 10, 2015 at 5:42 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    I'd actually run 14 wide wheels rather than spacers. That's just me though. Tons of people out there that run spacers i know, I just wont run em.
  2. Nov 10, 2015 at 5:49 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    A lot of tire to turn, and stop, so say good bye to your brakes too. This is just a bad idea. You're gonna kill that truck. 3" suspension and 3" body will create a ton of body roll, so you'll wear the body lift pucks through the sheet metal on the cab. You'll need 3-1/4" backspacing or a 3/4" spacer to even come close to the tires clearing the frame or as mentioned have shit for a turning radius. You're gonna wear out ball joints, bushings, and suspension components, and wait til you have to sink $400 into a new steering rack.
    Blackout14 likes this.
  3. Nov 10, 2015 at 5:50 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Just don't turn while you're sitting still and you're good :thumbsup:
  4. Nov 10, 2015 at 5:52 PM
    Laxtoy
    Maltby, WA
    Not to mention your ride will be shit with a spacer and an add a leaf. So when all is said and done, you'll have a truck that sucks to drive, is worn out from bad suspension geometry and gets shit gas mileage, good luck with reselling it
  5. Nov 10, 2015 at 5:53 PM
    Laxtoy
    Maltby, WA
    That'll be about all it's good for
  6. Nov 10, 2015 at 5:53 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    My truck rides like shit, gets shit mileage and I still love it?
  7. Nov 10, 2015 at 5:55 PM
    Sagecalla
    Sagecalla [OP] Member
    Sage
    2004 Tacoma trd
    The truck has a ton of miles on it so I wasn't wanting to sink even more money than I have into it. Basically Everything but the motor is new. Maybe I'll just stick to the 12 wides and sink my money into a motor swap instead. Thanks guys for all the info!
  8. Nov 10, 2015 at 5:57 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    All i want is 12 wides lol
  9. Nov 10, 2015 at 5:58 PM
    Laxtoy
    Maltby, WA
    I don't wanna bash you, it's your truck, do what makes you happy, but there is a ton that goes into it if you wanna lift it, to the point where it can get dangerous or leave you with a lot of problems. I'm at 275,000 miles, so it may surprise you, if the motor is running well it likely will for a long time to come.
  10. Nov 10, 2015 at 6:01 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Prolly more than youre gunna want to spend but if i were to do it, id scrap the BL and go for a 6"DB lift.....
  11. Nov 10, 2015 at 6:04 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    From the frying pan into the fire haha:D Please tell me this swap isn't V8 related...
  12. Nov 10, 2015 at 6:10 PM
    Sagecalla
    Sage
    2004 Tacoma trd
    I'm thinking a 4bt
  13. Nov 10, 2015 at 6:11 PM
    Sagecalla
    Sage
    2004 Tacoma trd
    It's already has some height to it so I guess I'm just gonna leave it alone lol I hit 300,000 a few days ago
  14. Nov 10, 2015 at 6:13 PM
    Laxtoy
    Maltby, WA
    WHAAAA? You're gonna put a diesel in it? Wow. I don't know where to go with this, but you sure as hell don't wanna put a spacer lift in it or put it on 14's. That diesel will be too much weight. Seriously, you don't have much money to proper suspension setup, but you can afford a diesel swap. I suspect you to be on the drugs darlin
  15. Nov 10, 2015 at 6:18 PM
    #35
    bry838
    oregon
    Wow a diesel.swap!!?? Hell yes!! But like laxtoy said youll do a 4bt swap but wanna skimp on the suspension? If you do the 4bt (which would be my dream swap) then a SAS would most definitely have to occur!!!
    Lol youll be 30k deep in no time!
    Will you be my girlfriend??? I have two more tacomas to add to the pot! You can use one of mine while we do the SAS and 4bt swap!
  16. Nov 10, 2015 at 6:21 PM
    #36
    Laxtoy
    Maltby, WA
    NO DIESELS ON THE TRAIL!! :D Stanky!
  17. Nov 10, 2015 at 6:22 PM
    #37
    Sagecalla
    Sage
    2004 Tacoma trd
    I'm saving for the diesel and have already talked to a shop about it all. The bigger lift was more of something that ran through my head but the 4bt will at some point deffinitely be in the future
  18. Nov 10, 2015 at 6:31 PM
    #38
    Sagecalla
    Sage
    2004 Tacoma trd
    Shop said it was gonna be expensive but deffinitely not 30k lol there's a lot to do. Found a rebuilt 4bt for 6k and whatever comes after that
  19. Nov 10, 2015 at 6:31 PM
    #39
    Laxtoy
    Maltby, WA
    To each their own. I'd rather put a 4bt in a 80 series land cruiser, but that's just me, then you already have lockers, solid axles, and the drivetrain plus the room in the engine compartment.
  20. Nov 10, 2015 at 6:33 PM
    #40
    bry838
    oregon
    I was referring to the suspension work(SAS) and the motor swap and a lil exaggeration there with the 30k. Just seems like once ya start with the mods they dont stop if ya know what i mean... with all that plus labor 30k wouldnt be outta the realm though....unfortunately, haha
    I bet just for the 4bt itd end up being 15k all said and done with though. Then just for the sake of being totally awesome and bad ass to the bone youd have to SAS that sweet thing!! Another 15k easy on a nice setup. You get to 30k real easy and one couldnt just stop there, the cycle would continue haha.
