14mpg in 3.4L quad cab ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 02 quadcab, Oct 25, 2023.
  1. Oct 25, 2023 at 11:53 AM
    02 quadcab
    02 quadcab [OP] Well-Known Member
    My mpg is stuck at 14mpg for the last 4 tanks of gas that I calculated. truck is on 32 in tires. Recently fixed wheel bearings, dragging breaks, and upper a arms. Put in new air filter and no improvement. No check engine lights and recently passed smog. I have not aligned it but drives straight and tires appear to be wearing normally. What to look into. I should be getting closer to 270 miles per tank but closer to 220 now.
  2. Oct 25, 2023 at 12:02 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    Kolter45, Nessal and YF_Ryan like this.
  3. Oct 25, 2023 at 12:07 PM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    When you calculate your mileage, how are you correcting for the extra tire height?
    ToyoTaco25 likes this.
  4. Oct 25, 2023 at 12:57 PM
    02 quadcab
    I have had the same tires for over 10 years used to get 270 to maybe 300 per tank last year or so has been about 230 per tank. I should have specified no ride height changes have been made recently. Trying to get ideas for why the drop. I thought it was the caliper drag and wheel Berings but no significant improvement with those changed.
  5. Oct 25, 2023 at 1:03 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Is that hwy or city mileage ? Sounds low to me either way.
  6. Oct 25, 2023 at 1:21 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Engine tune up time- clean MAF & IAC, new PCV, spark plugs, wires, fuel filter & injectors.
    Do you have a ODBII reader/SGII to check the fuel trims?
    I'd also be checking for any exhaust or vacuum leaks to ensure the sensors are getting good data.
    02 quadcab[OP] and Kolter45 like this.
  7. Oct 25, 2023 at 1:54 PM
    2004Taco
    Lou
    California
    Have you changed your driving habits? Are you throwing any codes?
  8. Oct 25, 2023 at 4:51 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I have always gotten 12-15mpg regardless of tires or setup, but ya you need to add a little bit for your tires
  9. Oct 25, 2023 at 5:56 PM
    02 quadcab
    Not really any changes and no codes that’s why I’m asking here. Definitely a reduction TK mileage I used to get years ago
  10. Oct 25, 2023 at 5:57 PM
    02 quadcab
    I have an OBD reader so I’ll need to look up what those are supposed to be at. No codes on anything tho.
  11. Oct 25, 2023 at 6:53 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Could be gas. Gas stations are running higher ethanol contain to try and fight rising gas costs. Down side is lower mpg. Both of my doubles cabs got around 15 mpg. Make sure your checking tire pressures.
  12. Oct 25, 2023 at 6:59 PM
    02hilux
    Planet: EARTH
    I would love to get 14mpg... currently getting 8mpg
    But it's SMILE PER GALLON for me.
    :hattip:
  13. Oct 25, 2023 at 7:00 PM
    tacoman2001$
    I get 10ish but I'm on stock gears and 33x12.5s and supercharged with a lift and extra weight.
    02hilux[QUOTED] likes this.
  14. Oct 25, 2023 at 7:02 PM
    02hilux
    Planet: EARTH
    Heck, even 10 I'll take. Lol
    I get 8 on the highway with a good wind. In town, I average 7ish if I'm lucky.
    I'll idle and watch my guage drop, lol.
  15. Oct 25, 2023 at 7:04 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    This would be my first move. I'd add checking coil pack resistance to that list too.
  16. Oct 25, 2023 at 7:25 PM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    Hmm, it's been a long since I calculated MPG. When I used to it would be 14-16 average. That's with lift and 285/75 16 Duratracs.
  17. Oct 26, 2023 at 6:20 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    So Glad I've kept my truck stock. I'm getting 23.5 mpg on the interstate with cruise control on 70mph. If I can keep my foot off the gas pedal, I can get 18mpg just driving around. I did have to change my plugs and wires to get my milage back to where it was. But with "Winter" gas coming, I'm sure my numbers will drop.
  18. Oct 26, 2023 at 7:24 AM
    Madjik_Man
    Colorado Front Range
    with 31” (or equivalent) tires the speedometer/odometer reads high.
    I’ve found with 32” (or equivalent) tires the speedometer/odometer is damn near spot on.
    To the OP - what is your driving style? Short city stop/go runs? This is an mpg killer for me.
  19. Oct 26, 2023 at 7:34 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    I would look into the alignment.
    Could also look at the thermostat....if its dead in the open position or weak, the truck will run in a rich condition until its warmed up thus wasting a ton of fuel. Make sure coolant isnt flowing before its warmed up.
    Same for the cooling fan...check the clutch.
  20. Oct 26, 2023 at 8:55 AM
    Gen1andDone
    When mine was bone stock, still on factory installed tires, the best I ever got was 21 MPG. That was all highway. TRD 4.10 gears w/manual trans.
