14mpg on 94 octane?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thyces, Jul 23, 2016.
  1. Jul 23, 2016 at 9:39 AM
    jgang
    jgang Well-Known Member
    Are you sure of the amount of fuel you're putting in your tank? To get the calculation right, you need to start with a FULL, topped off tank and then do the same thing when you fill up. It's the only way to know just how much fuel you've used. I'm sure this is intuitively obvious, but it's just one more culprit to eliminate as a cause of your issues.
  2. Jul 23, 2016 at 9:50 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    To add to the above, what is your typical driving, ie all/most city (lots of stop lights/stop & go) or mostly 50-60 mph highway, or 70+ interstate, or mixed city/highway/interstate?
    If you're serious about accuracy, determine your odometer error (gps or 50 miles by mile marker). Do not consider speedometer - it probably is off a different amount compared to odometer.
    Last variable as mentioned above is accurate gallons. If you don't want to fill to the top, you really need to average 4-5 tanks.
  3. Jul 23, 2016 at 9:51 AM
    jgang
    It might. Go to one of the tire size comparators and see what the difference in size your bigger tires are from stock. For instance, my 275's are 5.2% larger than the stockers. If I went 200 miles according to my odometer, my actual miles traveled is 1.052 times the odometer reading or actual 210.4 miles. Obviously, the larger the tire, the greater the difference.
    David K likes this.
  4. Jul 23, 2016 at 10:28 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Urban legends. The gasoline octane rating or 10% ethanol content wont have any measurable impact on mileage for a 2nd gen Tacoma. Doesn't matter what you think you feel while driving, what anyone else says, or the mileage you think you documented. No need for a poll, a call to the Myth Busters, or a 100 tank year round test. Just do the math. Its very easy.
    IronPeak likes this.
  5. Jul 23, 2016 at 10:33 AM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    If I stick to strictly highway and 70mph I get 19.0-19.5mpg with even 85 octane (regular at CO altitudes) and 10% ethanol. Manual trans, 265/65/16 tires.
    However driving around town even 50% of the time that drops to 16.0 mpg pretty quickly.
  6. Jul 23, 2016 at 10:37 AM
    TREED
    TREED Well-Known Member
    JT
    Spring Creek NV
    15 trd taco dc
    885x coils on 5100s. SPC upper a-arms 255/85/16 bighorns, 12k lb reciever mount rear winch,CBI offroad moab bumper,8k lb warn front winch, swaybar delete, spidertrax,icon minipacks, custom dog box, husky liners
    My best is 17mpg. If I drive over 70 it gets 14.
  7. Jul 23, 2016 at 11:16 AM
    Thyces
    Thyces [OP] 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    My google machine has spoken great wisdom with few links. I need to fill up and am going to do so with regular gas and see if I find any difference. My butt dyno has always told me 94 feels better. So I'm going to lie to myself an pretend I have filled up with 94 but use 87. I'll post results when I'm close to finish the tank
  8. Jul 23, 2016 at 11:18 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Yeah I drive mainly city stop and go
  9. Jul 23, 2016 at 2:50 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I did a couple of trials over the years switching from 87 to 91 octane and I don't think I saw any statistically significant difference. Driving style has more to do with fuel economy than any other factor. My FJ1100 (for sale if anyone interested) will get nearly 50mpg if I baby it around, or it'll get 28mpg if I ride it like a typical douche bag crotch rocket power ranger.
  10. Jul 23, 2016 at 3:38 PM
    studunk1
    studunk1 Well-Known Member
    stu
    jeff city, MO
    13 Access Cab sr5
    running boards, bug deflector, window deflectors, tail gate liner, bed mat
    Here is what was said at coffee this morning. If you buy premium fuel and it has an octane rating greater than 91, it contains alcohol. So you might try a couple of tanks of alcohol free premium and see how you do, at 91. In my neighborhood one station sells premium at about 60 cents per gal higher that is alcohol free at 91, the other station sells premium for about 40 cents more, but that has alcohol at 93. (Also there was a big discussion about top tier vs non top tier gas, top tier being much better.....google top tier but what it means generally is the fuel sold at "major" brand stations, at non name brand stations there is often a "top tier" decal on the pump if they are selling top tier gas.)
    Just what are you trying to accomplish? If it is more mpg carefully measure with 87, then 91, then 93 octane and see how you do with 3 or 4 tankfulls each, I fill mine to the auto click off then manually add 3 more click offs. In my 2013 6 cyl at 36,000 miles I get no measurable difference between any of the above, I live in Missouri, but when I travel thru New Mexico and Arizona sometimes the octane is 85, and still no difference......it runs tank after tank on that 3200 mile round trip generally between 19.3 and 22.1, mostly in the upper 20's, lower 21's. I attribute the difference to wind, amount of mountains, use of cruise control, distance between fill ups, load factor, etc. I have found I do better with cruise control off, where I can coast up hills, keeping the engine from downshifting, and accelerate down hills, and run no more than 5 mph over the limit. I still have the original equipment stock 16 inch tires, Dunlop AT20, 245X75X16. For an access cab, 6 cyl, 4 wh. drive, somewhat of a load am very satisifed. Often have a buddy that caravans with me from Tulsa and back in a full size 2011 Chev. Silverado 2 wheel drive V8 with cylinder deactivation that consistently gets less MPG than I, it just pisses him off......
  11. Jul 23, 2016 at 5:08 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You got an issue with you calculator? Or do you never drive over 50?
  12. Jul 23, 2016 at 5:12 PM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    I charted my mileage using Low, Mid and High grade fuel and got the worst mileage with the highest octane fuel. Mid grade saw minimal increase in MPG. I use low strictly. I'm currently running 100% gas. It's 50 cents more per gallon, but gas is low right now so I'll see how it does.
  13. Jul 23, 2016 at 5:22 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Absolutely when the pump clicks off I can put another 2 gallons in no problem bottom line the tank is not full.
  14. Jul 23, 2016 at 5:29 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    100 octane no alcohol is $4.49 gallon at the local air field do you think I should use that?
  15. Jul 23, 2016 at 5:37 PM
    #35
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    In the summer time I get 18 to 20 with 87 dose any one really think I would get enough improvement to make up the difference
    in price?
  16. Jul 23, 2016 at 5:40 PM
    #36
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Ethanol does lower mileage, no myth.
    Automatic vs manual is different.
    4WD is heavier even though we are in 2WD for the test.
    265/75-16 will slow the odometer 5 miles for every 200 shown (ie. add 5 before dividing by the gallons ).
    My 2010 V6 Auto 4WD gets 15-18 on California gas. If I drive slower, I can get up to 20, never more!
  17. Jul 23, 2016 at 5:48 PM
    #37
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    By exactly how much for E10? Show your work. For extra credit demonstrate that the measured difference under real world driving conditions can statistically significant.
  18. Jul 23, 2016 at 6:08 PM
    #38
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Do not use Avgas in your truck.
  19. Jul 23, 2016 at 6:09 PM
    #39
    Tacoma Dave
    Tacoma Dave Long time lurker
    David
    Oakley, CA
    04 xtra cab trd
    2004 trd off road 4X4, 265 75 r16 bfg at, bilstein 5100 all around front at 1in, rear firestone ride rite air bags
    I did the same thing with my tacoma except i went from 87 to 91. I did this for a few tanks and was getting worse mpg with the higher octane. 87 octane was consistently 18-19mpg. 91 octane was 16-17mpg. All same driving style and same driving route.
    I think this has alot to do with that these engines are built specifically for 87 octane. Once you run many many tanks of 87 octane, switching to a 91 octane with different supplements and additives will change the combustion of the fuel. Since 91 is used more specifically for high compression engines to prevent pre-detonation its really unecessary to run 91 in these engines. But then again im not a professional. Hope this helpes.
    David K and MadDaddy like this.
  20. Jul 23, 2016 at 6:12 PM
    #40
    shakerhood
    Southern Ohio
    If memory serves me correct, I recall the first 2 or 3 years of the 4.0 Tacoma requiring the use of Premium Fuel.
