15,000 mile maintenance on 3Gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chris Miles, Jun 14, 2017.
  1. Jun 14, 2017 at 1:46 PM
    Chris Miles
    Chris Miles [OP] Well-Known Member
    2016 Toyota Tacoma
    Trailer Hitch Cover - Star Wars Pulp Fiction Boba Fett & Stormtrooper
    Hello TW,
    (I promise I searched threads first)
    My 2016 is due for 15,000 mile maint. It has the AT. I scheduled a spot with the dealer next week.
    My understanding is that they'll check the trans fluid via computer diagnostics as opposed to manually looking at a dip stick. Is this correct? Should I request that they check it manually? TW posters have me all afraid that my transmission will stop functioning?
    Also probably worthy of note, my AT has given me zero problems to date and I live on the hilly-as-hell San Francisco Peninsula.
    Thanks for your time.
  2. Jun 14, 2017 at 1:52 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    no problems with mine. If you really want them to check the fluid, you will have to leave it as it needs to cool down for a proper check.
    Have you checked your vehicle for recalls? There are 2 recalls on the third gen as of today, and you might want to check into this beforehand. Some members have had their vehicles taken by the dealership due to leaking rear differential.
  3. Jun 14, 2017 at 1:53 PM
    Chris Miles
    2016 Toyota Tacoma
    Thanks, and yes, I checked my vin against both recalls. I'm not on either list.
  4. Jun 14, 2017 at 1:54 PM
    Bullnettles
    Bullnettles Well-Known Member
    Jared
    Houston
    2017 OR DCSB
    Also, they HAVE to check it with a computer since Toyota didn't give us a dipstick, because they're dipsticks.
  5. Jun 14, 2017 at 1:59 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Ugh I know I don't have one either
  6. Jun 14, 2017 at 2:04 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    If you are not experiencing problems, why are you wanting them to check it? They won't check it for free. They'll charge you $120+ to perform the procedure and you'll have to leave the truck overnight. I am sympathetic towards your concerns however as many of these new Tacomas are having problems.
  7. Jun 14, 2017 at 2:06 PM
    Bullnettles
    Jared
    Houston
    2017 OR DCSB
    They checked mine for free at my 5K service and in the same day (2 hour procedure), and 15K is still under warranty. Why would they charge?
  8. Jun 14, 2017 at 2:09 PM
    smitty99
    Scottsdale
    They probably just hooked it up to tech stream and told you the "system" shows the transmission fluid is fine. The ACTUAL procedure to check a "sealed" transmission requires the truck is cooled, then heated up to a specific temp range, almost every case I've seen on here where a dealer REALLY checked it required the customer to leave the truck overnight for this reason. There is a 1 to 2 hour process and the dealer charges by the hour. They will not check it just because you ask, because they need to essentially have a warranty type issue to charge and get reimbursed for the time it takes to execute the procedure.
    shakerhood and Garyji like this.
  9. Jun 14, 2017 at 2:12 PM
    Bullnettles
    Jared
    Houston
    2017 OR DCSB
    Hmmm, think there is any way I can get the info on what was done? They fixed other various stuff (including the trans reprogram, had issue with the cold start flare-up), so I told them I wanted the level checked and he said it'd take a while if they did (and said 2 hr.) I also got there at 6:45 AM on a Saturday and they had it until noon.
  10. Jun 14, 2017 at 2:13 PM
    textoy
    textoy Well-Known Member
    Fred
    Texas
    2011 4x4 TRD DC
    Don't complain about not having a tranny dipstick. Porsche doesn't even have an engine dipstick. Unless I've forgotten, the last few Toyotas I've owned didn't have tranny dipsticks either.
  11. Jun 14, 2017 at 2:14 PM
    Bullnettles
    Jared
    Houston
    2017 OR DCSB
    That doesn't make it OK just because others have done it. Mechanical check is always preferred to a sensor that can fail.
    over60 and smitty99 like this.
  12. Jun 14, 2017 at 2:22 PM
    Chris Miles
    2016 Toyota Tacoma
    I didn't realize that there wasn't a dipstick at all. I though it was just something that required a bit more effort than simply getting under the hood.
    I'll just take a xanax or 3 and leave the rest to the dealership.
  13. Jun 14, 2017 at 2:23 PM
    smitty99
    Scottsdale
    No way to really tell now that it's in the past. When the 2016s were noted to be coming LOW on fluid from factory a lot of guys were recommending WATCHING the dealer perform the check to ensure they were actually doing it. We saw some instances of them LYING about actually performing the check and then later the forum members found they actually DID have low fluid!
    over60 and Bullnettles[QUOTED] like this.
  14. Jun 14, 2017 at 2:31 PM
    Clearwater Bill
    Billy
    Largo Florida
    #savethedipsticks #dipsticksmatter
    (my 2.7 has a dipstick :D)
  15. Jun 14, 2017 at 2:36 PM
    textoy
    Fred
    Texas
    2011 4x4 TRD DC
    Might as well get used to it. all manufacturers are making it harder and harder for anyone to do anything to vehicles. Even a simple oil change is a PITA now with the skid plates in the way and the element type filter access.
  16. Jun 14, 2017 at 6:04 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I changed her oil today and enjoyed every minute of my "bonding" with my sweetheart........ She was nice and let me grease her nipples while her fluid was draining ;);)..... Then I blew in her tires and made her happy...!!:) She even let me torque her nuts on her rear end...!!:eek::eek:
    I think she will take me out to British Columbia and back now that I've given her a little luvin'..........:dancingbacon::dancingbacon::dancingbacon:
  17. Jun 14, 2017 at 6:33 PM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    This one. If you aren't experiencing any issues then I wouldn't bother with it. And you wouldn't be giving the dealership a solid reason to do a full check. It takes about 4 hours to cool down and check which they need to justify for a warranty claim. Honestly even if it was a little low, it's too late now and it probably won't matter.
  18. Jun 14, 2017 at 7:04 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    That should be enough time to cool for a proper temp mode atf level check.
    Does your work order have ATF fluid on it?
    You can use Techstream or jumper the obd port to access the temp check mode for a manual check.
    When they use Techstream only and no manual check, they are looking at the thermal degradation count.
  19. Jun 14, 2017 at 7:25 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Yeah expect them to charge you. In fact it may be as cost effective to have it dumped and refilled to the correct level. My service advisor did manually check it for free, but I am pretty sure this is not the norm. Like smitty said, be prepared to have to pay for it.
  20. Jun 15, 2017 at 10:13 AM
    Chris Miles
    2016 Toyota Tacoma
    Thanks for everyone's input.
    I do have a follow up question:
    Is it common to see the AT fluid sensors malfunction?
    While I prefer the dipstick approach, I'll also put my trust into an electronic sensor.
