15.1 Mpg WTF ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dirthawker1313, Oct 19, 2007.
  1. Oct 20, 2007 at 1:52 PM
    Saguaro
    Saguaro Member
    Rancho Palos Verdes, CA
    07 V6 6-spd 4WD Access Cab, TRD Off-Road Package, Super White, Suspension TSB
    I also never punch it. And I usually shift into the next gear at about 2000 rpm. And I drive at a constant speed on the freeway. However, for the first 1000 miles I am still getting just above 15 mpg. I talked to a Toyota mechanic and he said this seems to be the going rate for new 4WD's.
    I also have the a/c on 90 percent of the time since it is still in the 90's here in SoCal. This could be affecting gas mileage.
  2. Oct 20, 2007 at 6:24 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Don't panic, my '06 got the same until the engine broke in around 25,000 miles and then I started getting between 19-21 mpg in the city. It's important to remember that any modifications i.e. lift kits, over size tires, etc. will take mpg into the toilet.
  3. Oct 20, 2007 at 9:39 PM
    gegundez
    gegundez Well-Known Member
    Miami, FL
    07 TRD Prerunner Dcab
    Overpriced stereo and alarm. MBRP Dual Exhaust.
    I saw a news report on doubling gas mileage. Yes 30mpg for our trucks in city driving.:D
    OK I tried the trick a few times on one tank and my MPG went from 18 to 22. I will be more religious about it when the weather gets cooler down here in Miami. Today 90+ in October.
    So here is the trick form the hymilers club.
    Turn off the motor.
    If you see a stop sign ahead or a street light turns yellow, just turn off the motor and coast to a stop. Wait for the light to change, then start and go.
    It works!!! They did a 5 mile test on a Ford Expedition and it jumped from 12 to 20 mpg on a TV news report (20/20, Dateline or something like it).
  4. Oct 21, 2007 at 12:22 PM
    ZonKs
    ZonKs Can speak french in Russian.
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    You dont need to drive like a grandma, but you must be doing something to get that crappy mpg. I would have to work really hard to get 15.1mpg. I get around 17-18 streets/highway. All highway I get around 22mpg. this is with AC on constantly.
  5. Oct 21, 2007 at 12:33 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    my next highway trip this wednesday i'll try to drive all the way under 2k and see how it does there too...its just hard to be under 75mph on I-95...lol...especially when it goes up to 70mph limit in SC
  6. Oct 21, 2007 at 5:45 PM
    CornDog
    CornDog Well-Known Member
    Gallant, Alabama
    2007 SpeedWay Blue Double Cab Tacoma
    12000 lb Milemarker Winch Warn Trans4mer Grille Guard Gear Motorsports Wheels, Pioneer Head Unit w Ipod Interface, 2 Diamond D3 10's in custom box, UWS black tool box. N-fab stepbars, 15% tint, bug deflector,ventvisors, K&N Series 77 Cold air Intake, Hi lift jack mounted, 4D-LED maglite mounted, Lund Grill Screen
    i gotta 6 speed 4.0. im gettin round 20 mostly interstate. 75-80. towards 80 im close to 3 grand on the gauge too. but i did install a turbonator AND thanks 2 the sticky off here removed that 2nd air filter. i found its REALLY easy to get those rpm up too high too. lol
  7. Oct 21, 2007 at 5:49 PM
    The_Hodge
    SC
    eww...a turbonator....i'd do some testing w/ that and see the mileage differences
  8. Oct 21, 2007 at 8:28 PM
    CornDog
    Gallant, Alabama
    its not impressive. but it was free to me to try so i didnt feel like it would HURT my gas mileage. lol i prolly save a couple dollars a day nothin more. anything helps this day n age.
  9. Oct 24, 2007 at 9:27 AM
    Rich Swanner
    Rich Swanner Well-Known Member
    N.California
    2007 Black PreRunner DC V6 SR5 LB
    Leer 100R Shell NXT Tech Wax
    I noticed my MPG had dropped, it got colder and my PSI was 25-26 in my tires. I put them up to 31PSI and went to Carmel . I did 66% Highway and 33% in town and got 21.95MPG average. Before I had 18MPG on the same exact driving ratio. The highway was 65-70MPH.-Rich IMG_7608_edited-1Large1_edited-2_6a3fdb281b9971ae68a16719ae02d85303706644.jpg
  10. May 24, 2009 at 10:24 PM
    TodaGuy
    TodaGuy Well-Known Member
    Oregon
    Almost Murdered 09 Taco
    Revtek 3" spacer in front 1" block w/ 2" AAL in rear. Blacked out grill, debadged (almost all done), Magnaflow muffler, black Konig Countersteer Off Road rims, 285/75/16 Toyo Open Country M/Ts.
    The best I calculated was 21.6 mpg all highway on one tank. I bought a GPS and found out that the speedo on my truck was almost if not 2 mph off reading my speed faster then I was actually going. This means I was racking up millage that I was not actually traveling which means my mpg calc were not correct. I just lifed my truck and put 285's on her and now my speedo is dead on with the GPS and other radars. My last fill up was half highway half stop and go with a mpg of 15.3.
  11. May 24, 2009 at 10:26 PM
    Jazzfan
    Jazzfan Well-Known Member
    Draper, UT
    07 BK-DC TRD Sport 4x4
    6"Lift, 20"Rims 33"Tires, exaust, intake, stereo, etc.
    Wow I'm getting 11-13 MPG.. You all should be happy..
  12. May 24, 2009 at 10:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Are you takeing into account the larger tires? There is about 7.5% size difference, and your ODO will be off that ammount. Add 7.5% to your odo reading, then divide by the gallons, and that should give you a more accurate mpg figure.
  13. May 24, 2009 at 10:58 PM
    tacoholic
    tacoholic Well-Known Member
    East Bay, CA
    For some reason I don't believe that...since it uses the same amount of gas to start it as it does to just let it run for 5 minutes. This is what one of the guys at Ford told me but still it seems quite logical.
    Besides that, all that starting and stopping must be TERRIBLE for the engine.
  14. May 24, 2009 at 11:02 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    Holy Thread revival Batman!
  15. May 24, 2009 at 11:04 PM
    #35
    TodaGuy
    Oregon
    Haha that quote is a little ridiculous..
  16. May 24, 2009 at 11:26 PM
    #36
    Untamed_SS
    Untamed_SS Stayed Up Too Late
    Adam
    Haughton, Louisiana
    08 Speedway Blue Access Cab
    Alpine iDA-X200 Deck, Rockford P3, Infinity 1600 A Amp, Black Badges, "KnightRider Mod", Back-up lights. Painted Engine Cover. TRD QuickShifter & Shift Knob. MAF Calibrator. Doug Thorley LT Headers. Custom Y-Pipe. Flowmaster 50 series. Satoshi Grill
    LOL. No crap man. I was gonna say it myself. :rolleyes:
    TW-ans just love the thread revival. But I guess that is better than making a new thread of the same thing. :cool:
  17. May 24, 2009 at 11:46 PM
    #37
    ccoorreeyy
    ccoorreeyy www.EvolvedFinance.com
    Corey
    Los Angeles (South Bay)
    08 Double Cab 4x4 SR5 Debadged
    BHLM, Revenge Fab Rock-Sliders, BFG TA KO's, N-Fab light bar with 4 Hella 500's, Rear Suspension TSB, TRD Exhaust, CB Radio, 100W Ultra bright headlights, JBL Sound
    I get 15-16, but I'm "a pissed off teenager." I also have lots of stop signs in my area so I'm sure that helps. If I take it on the highway, I get around 20-21 MPG. It just depends on how fast I want to get to my destination (which is usually around 80-85).
    I think that if I were to keep my RPM's below say 2.5K or even 3K (chuckling because I know it wont happen), I would get better gas milage.
  18. May 24, 2009 at 11:49 PM
    #38
    tacoholic
    East Bay, CA
    Keep it under 2K and it could possibly short circuit your mind with mileage.
    It's ok, I'm a pissed off teenager too and I could probably get 18 or so easily. but my freeway speed is higher than yours...you really only hit 80-85 on the freeway? You're not a pissed off teenager, you're only a mildly angered if not just frustrated teenager. :p
  19. May 24, 2009 at 11:50 PM
    #39
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I average 16.5 MPG but Im running 33"s...
  20. May 24, 2009 at 11:58 PM
    #40
    TodaGuy
    Oregon
    What performance mods do you have?
