15% Fuel Economy Increase Due to Shifting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dustyroades, Jan 12, 2011.
  1. Jan 12, 2011 at 6:16 PM
    Dustyroades
    Dustyroades [OP] Well-Known Member
    Ontario
    '09 MGM AC 4x4 SR5 2.7L 5spd
    Front Bilstein 5100s at 1.75", rear 1.5" AAL w/ TSB and OME N182s, P265/75R16 Hankook A/Ts
    Hi there TW, long time lurker, first time poster!
    I bought a 4 cyl (4x4) Tacoma for fuel economy but have been a litle disappointed with the 16-17 mpg I have been getting in the winter. I read the fuel economy forums and saw it mentioned that shifting at around 2000 rpm yields increased economy. So I tried it and got 19.3 mpg on my last tank, for a ~15% increase.
    I'm not sure if this is because I tend to avoid the higher engine losses at high rpm, or if shifting so low just forces one to accelerate slowly. In any case the results are encouraging and I'm hoping to get into the low 20's once summer rolls around.
    So if you have a manual Tacoma, give it a try. My only concern is lugging at low rpm... is this something I should be worried about?
  2. Jan 12, 2011 at 6:19 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    you'll get much better in the summer. i usually get 20-21 in the summer with my 3.4 v6 but around winter time i get 13-15. especially with the cold weather up in canada you'll notice a huge change
  3. Jan 12, 2011 at 6:39 PM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Off topic (sorry), but where in Ontario are you?
  4. Jan 12, 2011 at 6:47 PM
    brow
    brow Well-Known Member
    Andy
    Minnesota
    17' MGM DCLB SR5 4x4
    I've got the same configuation truck as you, shifting at 2000 in the summer, 70% freeway driving I get 23.5-24.5 mpg on a continual basis, minnesota winter, and being a wuss and warming my truck up in the morning I'm getting about 19
  5. Jan 12, 2011 at 6:51 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Buy a prius if you are worried about fuel.
  6. Jan 12, 2011 at 6:56 PM
    Dustyroades
    Ontario
    I am in London.
  7. Jan 12, 2011 at 7:00 PM
    Dustyroades
    Ontario
    I wouldn't worry about fuel if I had infinite funds. But since I don't, why not save a few bucks while still having a capable truck?
    But thanks for your input.
  8. Jan 12, 2011 at 7:13 PM
    radioactivemint
    radioactivemint Well-Known Member
    Oregon
    2011 Reg. Cab 4x4
    Those numbers must be due to winter. I've the 4 cyl. 4x4 auto and it averages about 20-21 in winter. It's probably a bit warmer here in Oregon, too. Do you guys use "winter gas" over there? That could also contribute to the problem, from what I've read on these boards.
  9. Jan 12, 2011 at 7:14 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    A little off topic .... as mine in an AT 4 cylinder ...... not exceeding 2000 rpms works wonders. Driving smart works wonders, as well as letting the transmission do its job.
    Around town a little over 21 ..... hovering just below 30 on the highway.
  10. Jan 12, 2011 at 7:21 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    you only get 16-17mpg with a 4 cylinder??? I consistantly go 21-22 with the 4.0l v-6...its 6 speed and I try to max the revs out at 3000 when shifting...high geAR 100kph=about 2100rpm
  11. Jan 13, 2011 at 9:02 AM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Yeah suuuure. A consistent 21-22 with a manual 6cyl 4x4 that is rated 17 mpg by EPA. You might do a LOT of suburban driving (30-50 mph), or miscalculating your mpg. Anyway, it's not like it's a normal mpg number to get, even with my 4 cyl I would only get that during summer
  12. Jan 13, 2011 at 11:17 AM
    kb1jop
    kb1jop Well-Known Member
    Rick
    Springfield, MA
    2010 Barcelona Red 4WD DCSB 6-Speed SR5
    Factory Towing Package Factory Roof Rack OEM Bed Mat Trifecta Tri-Fold Tonneau SeatSaver Custom-Fit Seatcovers WeatherTech Custom-Fit Floor Mats Block Heater: http://www.metrotpn.com/ProductDetails.aspx?CollectionID=13&ProductID=191&SortIndex=9
    From 1st to 2nd at 1500 and the rest at 2000 rpm on the 6-cyl. 6-speed. Really good gas mileage [except when in 4WD, naturally.]
  13. Jan 13, 2011 at 11:35 AM
    Dustyroades
    Ontario
    Really? 1st and 2nd must be closer on the 6 speed. On my 5 speed I tend to shift at 2500 from 1st to 2nd, otherwise rpms drop too much.
  14. Jan 13, 2011 at 11:40 AM
    SmilingMark
    SmilingMark Well-Known Member
    Mark
    Ogden, UT
    2010 Access Cab
    Color matched grill w/ grillcraft. BHLM and Morimoto Mini HID's Debadged.
    Anyone have any recommendations on shift point for the V6 6sp? Still shoot for 2000?
  15. Jan 13, 2011 at 1:08 PM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    My dad lugs the crap out of his 06 tacoma 4cyl 4x4 and it clogged both of his cats, dealer cost.... $700
  16. Jan 13, 2011 at 1:15 PM
    tvbd56
    tvbd56 Epic Member
    Tyler
    Sacramento, Ca
    05 AC Prerunner 6-speed
    k&n air filter, weathertech digital fit, TRD 6-speed gray knob, undercover bed cover, flowmaster american thunder dual exhaust, URD short shifter, 5100's set at .85, Grillcraft, black surround grille(with SJ stripe)
    i shift at 10, 20, 35, 50, 60 MPH
    which if i am correct that's about 2000, 2000, 2250, 2500, 2500 RPM
  17. Jan 13, 2011 at 2:19 PM
    kb1jop
    Rick
    Springfield, MA
    Actually yes. If I'm rolling just a little bit, I can start up in 2nd no problem. No bogging down, no issues at all. I'm not that technical but I can definitely tell the gears on the 6-speed are a lot closer than my previous vehicle which was a 5-speed. Just my $0.02.
