15 psi
Discussion in 'Off-Roading & Trails' started by tacotruck93, Apr 1, 2019.
  1. Apr 1, 2019 at 10:59 PM
    tacotruck93
    tacotruck93 [OP] Well-Known Member
    Zach
    Akron,Ohio
    2012 TACOMA TRD OFF ROAD
    Had some fun on Mountain Springs Rd MVIMG_20190330_160737.jpgnear Slade KY
    Trucknorris, Paul631, Matic and 3 others like this.
  2. Apr 3, 2019 at 11:08 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Is that boost or tire pressure? lol
    SR-71A and tacotruck93[OP] like this.
  3. Apr 3, 2019 at 11:23 AM
    tacotruck93
    Zach
    Akron,Ohio
    Tire pressure lol.
  4. Apr 3, 2019 at 11:33 AM
    eon_blue
    Azusa, CA
    Gotta love E rated tires, 15 psi and they still look like they're at 35psi lol. Mine don't really start to show any bulge until I get down to 12.
    tacotruck93[OP] likes this.
  5. Apr 3, 2019 at 11:37 AM
    tacotruck93
    Zach
    Akron,Ohio
    It was actually my first time ever dropping air pressure. Didn't have to use lockers or winch myself out. It was crazy how it just climbed up rock ledges and didn't skip a beat. The only reason it's my first time is I never had anyone to help air back up haha.
  6. Apr 3, 2019 at 11:39 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Nice.
    Grew up in the projects off Arlington Blvd about 40 yrs ago. Lol.
  7. Apr 3, 2019 at 11:43 AM
    eon_blue
    Azusa, CA
    Did you pick up an air compressor? Airing down is a crucial part of offroading, especially on harder trails. You get far better traction with the tires aired down and it's a lot better on your suspension components (not nearly as harsh/rough) and better for the ride quality. I air down even when I do fire roads, just makes the ride so much better. A good air compressor is key to have
    zippsub9 likes this.
  8. Apr 3, 2019 at 11:46 AM
    tacotruck93
    Zach
    Akron,Ohio
    Is there any adverse effect to the sidewall of the tire to run it low for long periods of time? Most of the stuff being off road, road, and gravel roads.
    Matic likes this.
  9. Apr 3, 2019 at 11:49 AM
    Matic
    Tricky Dick
    Easley, SC
    For sure. But probably over a very long time.
  10. Apr 3, 2019 at 11:52 AM
    Matic
    Tricky Dick
    Easley, SC
    Trucknorris likes this.
  11. Apr 3, 2019 at 11:53 AM
    tacotruck93
    Zach
    Akron,Ohio
    Wtf happened there??
  12. Apr 3, 2019 at 11:54 AM
    eon_blue
    Azusa, CA
    As long as your only aired down on the trail you'll be fine, and you don't want to air down too low depending on the surface you're on and the type of tires that you have. Heavier load tires like E rated tires can handle going to lower PSI more than a P or C rated tire can. If you go too low even on an E rated tire, the tire can pop off the rim or blow out the sidewall (more common on C and P rated tires since they have weaker sidewalls). Which is why so many people that do harder trails usually run D or E rated tires, they're a lot stronger overall.
    Running them too low on the street not only kills your handling and MPGs but its also not good for the tire wear, which is why you want to carry an air compressor and be sure to air up once you're done with the trail.
    My rule of thumb with E rated tires is 15 psi for rocky trails, 20 psi for fire roads and 2wd friendly trails, and 10psi for sand dunes. I've never had a tire come off the rim and only ever had one flat, but it happened because the sidewall got rounded on a sharp rock (probably would have punctured it even if it wasn't aired down).
    I have seen others lose a tire off a rim and blow out a sidewall from too low air pressure but both times it was on C rated tires.
  13. Apr 3, 2019 at 11:55 AM
    Matic
    Tricky Dick
    Easley, SC
    Multiple trails and many miles airing down to 15-20 psi.
  14. Apr 3, 2019 at 11:59 AM
    BlackGT99
    BlackGT99 Well-Known Member
    Noel
    2019 VooDoo Blue Tacoma TRD Pro
    Sub 20 is not good. You’ll over heat the tire and cause it to fail. Case in point
    Matic likes this.
  15. Apr 3, 2019 at 12:01 PM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    Right! First trip out on 35” bead locks running 10-12 psi was in Uhwarri in NC and they were amazing. Similarly equipped rigs running 33”s and 18-20 psi had to be winched up hills that mine crawled right up with no issues.
  16. Apr 3, 2019 at 12:01 PM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    13 psi here:eek:
    Paul631 and tacotruck93[OP] like this.
  17. Apr 3, 2019 at 12:04 PM
    HappyGilmore
    Huntsville, AL
    Yes
    thats wild!!
    Matic[QUOTED] likes this.
  18. Apr 3, 2019 at 12:06 PM
    Matic
    Tricky Dick
    Easley, SC
    Ya, C rated tires and I think about 50k miles on them. Sidewall blew out doing about 40mph. About 50% of that damage was due most likely from the rim.
    HappyGilmore[QUOTED] likes this.
  19. Apr 3, 2019 at 12:08 PM
    Matic
    Tricky Dick
    Easley, SC
    It's also a high possibility that the side wall was defective from the get go. Never worried about it to much to have it investigated.
    No blood, no foul.
    HappyGilmore and tacotruck93[OP] like this.
  20. Apr 3, 2019 at 12:11 PM
    HappyGilmore
    Huntsville, AL
    Yes
    Can’t complain too much with 50k on them. What do you mean damage was from the rim?
