$15 spare tire carrier
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stockmonester, Sep 20, 2012.
  1. Sep 20, 2012 at 4:58 AM
    Stockmonester
    Stockmonester [OP] Well-Known Member
    Nick
    Rome, Ny
    2019 v6 sr 4x4
    in channel vent visors
    Just finished making a spare tire carrier that slides up and down the rails from 2 6" stainless steel carriage bolts 1/2 diameter, 4 washers, 4 locking nuts, and 2 regular nuts. I'll take some pics when i get home tonight but so far its holding up pretty good. The bolts line up alomst perfect with two holes. After shane didn't wanna help me out I thought up this which i was pretty proud of myself for saving 80-90 bucks.
  2. Sep 20, 2012 at 1:34 PM
    Stockmonester
    Nick
    Rome, Ny
    2019 v6 sr 4x4
  3. Sep 20, 2012 at 1:34 PM
    Stockmonester
    Nick
    Rome, Ny
    2019 v6 sr 4x4
  4. Sep 20, 2012 at 1:34 PM
    Stockmonester
    Nick
    Rome, Ny
    2019 v6 sr 4x4
  5. Sep 20, 2012 at 1:36 PM
    TheGloryFades
    TheGloryFades Well-Known Member
    Seth
    Arizona
    '13 toaster
    Pics don't work for me
  6. Sep 20, 2012 at 1:37 PM
    Manwithoutaplan
    ID
  7. Sep 20, 2012 at 1:38 PM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
  8. Sep 20, 2012 at 1:38 PM
    Aw9d
    Aw9d That one guy
    Yeah man, copy and paste doesn't work to load pic's into forums.
    And your still using AOL? Hole-eeee-shit! :D
  9. Sep 20, 2012 at 1:38 PM
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
  10. Sep 20, 2012 at 1:38 PM
    Stockmonester
    Nick
    Rome, Ny
    2019 v6 sr 4x4
  11. Sep 20, 2012 at 1:40 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    :redxfall:
  12. Sep 20, 2012 at 1:40 PM
    Toy Yoda
    Garrett
    06 DCLB
    wobble baby wobble baby wobble baby wobble
  13. Sep 20, 2012 at 1:41 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    not bad
  14. Sep 20, 2012 at 1:55 PM
    Stockmonester
    Nick
    Rome, Ny
    2019 v6 sr 4x4
    i was thinking bout putting a bar so its spaces it out evenly enough. The size of the tire the bolts are pushing the tire down so its not just sitting their.
  15. Sep 20, 2012 at 1:57 PM
    Toy Yoda
    Garrett
    06 DCLB
    i'd definitely put something to keep the bolts spaced out, one on the track and one up close to the back of the rim
  16. Sep 20, 2012 at 2:32 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Except for the fact he has an 70# missile behind his passengers head that will most likely take flight should an accident occur.
    IMO one side of the bed rail system is not sufficient to secure a tire. Mine is bent like crazy just from normal use.
    Criminal and civil charges can occur should something fly off a vehicle in NY during an accident. God forbid anyone gets hurt or killed the driver can actually be charged with manslaughter or vehicular assault.
    I see guys with spare tires every day mounted on roof racks with a POS ratchet strap holding it in place and they make me cringe.
    Need to remember/take into consideration inertia when putting heavy items on trucks.
  17. Sep 20, 2012 at 2:38 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    ^^ Dead on.
    PM SnwTaco and ask him about his spare setup. He's got a similar spare mount that he paid for and he ripped the sheetmetal of his bedsides just from the weight of the tire moving around in Pismo.
  18. Sep 20, 2012 at 2:44 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    It still has no place on the bedrails, let alone with cheap hardware.
  19. Sep 20, 2012 at 2:49 PM
    Stockmonester
    Nick
    Rome, Ny
    2019 v6 sr 4x4
    I used stainless steel grade 8 bolts so Its not cheap hardware and for around 20 bucks and its easy to change i have basically nothing invested. I might run it flat against the front of the bed since it doesn't block my field of view. I do have a locked up with a pretty thick combo lock. The reason i put it on here was to get feed back negative feed always helps improve the system
  20. Sep 20, 2012 at 2:58 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I think you might have your metals confused.
    If you have stainless bolts, you probably have 18-8 stainless, which is not grade 8. Stainless bolts have a minimum yield strength of 40-90k psi. Grade 8 bolts have a minimum yield strength of 130k psi and are made of a carbon alloy steel.
