'15 SR5 DCSB Wind Noise (SOLVED!!!!)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jerimyr2000, Nov 20, 2015.
  1. Nov 23, 2015 at 5:20 AM
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
    My 2015 makes that noise at high speeds, so i crank up the tunes
  2. Nov 23, 2015 at 5:30 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    I don't let dealers touch my truck to do oil changes, they use the cheapest person they can hire and one screw up [like leaving the filter or drain plug loose] can cost an engine. There are very few things one can do to a vehicles that can cause so much expensive damage so quickly to a vital piece of the truck. [engine]
    Besides, I'm under no time constraints to take parts off or put them back on [skid plates and such] so I can carefully loosen bolts and use anti-seize on the threads when they go back on. I can also touch up any rust spots under the truck at the same time as I'm doing the change and grease Zerk fittings and look for any potential issues. All a dealer will do is run off a sheet that says you need $1000 worth of repairs or maintenance that no one actually bothered to look and see if it was already done. [Nissan was always great for that, when my Z went in for recall work I got a huge list of things that NEEDED to be done ASAP, problem was, every single one had been done within the past 2 months and 1000 miles when it was stored for the winter.]
  3. Nov 23, 2015 at 5:31 AM
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    I sealed behind the mirrors and the wind noise went away
  4. Nov 23, 2015 at 6:16 AM
    rottenpixies
    rottenpixies Well-Known Member
    New York
    2015 DCLB 4X4
    I think this is where my noise comes from, can you please detail how you did this and possibly take pictures to help? I know it would be very helpful, as a lot of people have this issue but no one has posted a fix with good details anyone can follow.
    cosmic stardust likes this.
  5. Nov 23, 2015 at 7:52 AM
    whopper
    wayne
    north carolina
    On going
    I ran a beat of black silicone around the back side of the mirror mounting flange
    I'm at work right now but Wil try to post pic when I get a chance
  6. Nov 23, 2015 at 7:53 AM
    rottenpixies
    New York
    2015 DCLB 4X4
    Thank you!!
  7. Nov 23, 2015 at 8:01 AM
    buzzkill911
    buzzkill911 Desk pilot
    Buzz
    Colorado, USA
    2015 Blue DCLB 4x4 V6
    Wheels, tires, mud flaps, etc.
    I chose not to use the free oil changes because I just applied FF to my truck and didn't want them to wipe any of it off while doing their maintenance. I can imagine a greased up frame is irritating to a shop guy so I just wanted to avoid the whole situation by doing it myself.
    Exactly. Because nothing says 'problem free' like a Mopar product. lol
  8. Nov 23, 2015 at 10:30 AM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I came from a 2012 wrangler when I got the taco, and it was starting to develop problems at 45k. I liked it don't get me wrong but I wouldn't paint Jeeps as reliable especially vs a Tacoma. Hell even look at subarus which are right up there with Toyota and Honda in reliability ratings, if you go to a Subaru forum you see problems too. Most notably their boxer engines burning ridiculous amounts of oil.
    With the jeep the manual trans was quirky from day one, couldn't downshift to 3rd unless you jammed it in and held it there. Reverse had to be jammed in too. My cruise control was starting to go out, I had to hit all the cruise buttons a few times before it would come on. It started making a squeaking noise when driving too.
    If you off road heavily I think there is nothing in this price range better than a Wrangler. I did from time to time but a vast majority of my driving is on road which is why I decided to switch.
    LLS[QUOTED] likes this.
  9. Nov 23, 2015 at 11:43 AM
    LLS
    LLS razorback
    Ark Taco
    hot springs Arkansas
    2015 Tocoma TSS 4x4 dlcb
    Jeeps are not problem free I've had Jeeps for over 35 years. This is my first Toyota been thinking of buying my Wife a 4 runner or something like that. But think I will wait until I see how this goes. As far as having work done at dealerships some are good some really suck just checked the air in my tires 25lbs after they CHECKED them and changed the oil. I would assume the rubber gasket around the doors are leaking because I see air bubbles when I wash it. The clunking I'll let them know about along with the brakes. I think I will trim the mud flaps myself. One thing about a Jeep there is a lot of them and they are always ready and willing to help.
  10. Nov 23, 2015 at 11:47 AM
    LLS
    LLS razorback
    Ark Taco
    What is a tsb number?
  11. Nov 23, 2015 at 11:53 AM
    LLS
    LLS razorback
    Ark Taco
    Trying to take the mud flaps off I see the 3 screws and of course I know how to remove those but what about the 3 push in type rubber stops? Will they have to be replaced or is there a secret trick
  12. Nov 23, 2015 at 11:53 AM
    KingTaco81
    KingTaco81 The guy, behind the guy, behind the guy
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    I get the same kazoo sound at 70+mph on driver side, its worse when its windy. Mine comes from the window, when I get the sound I push outward on the window and sound changes pitch. I also noticed when i have my window half way down it rattles a bit as if its not properly seated.
    LLS likes this.
  13. Nov 23, 2015 at 11:55 AM
    LLS
    LLS razorback
    Ark Taco
    JefferyB I switched to a Toyota truck for 2 reasons room to haul stuff and resale value.
  14. Nov 23, 2015 at 12:10 PM
    JeffreyB
    Jeff
    Room to haul stuff was huge for me too. It is hard to fit a pair of neatly folded socks in a 2 door wrangler if you don't take the back seat out. I had a little trailer for Home Depot runs and whatnot. Wranglers hold resale very well luckily enough so I got out of mine for about a dime a mile, which i figure is about right.
  15. Nov 23, 2015 at 12:44 PM
    #35
    LLS
    LLS razorback
    Ark Taco
    Yep.
  16. Nov 23, 2015 at 12:49 PM
    #36
    LLS
    LLS razorback
    Ark Taco
    Jeep Wranglers and Toyota Tocomas do have the best resale value. I just can't figure out why they don't come already sitting level and the mud flaps at the correct height. Seems like those are the most common complaints from just about everyone on here.
  17. Nov 23, 2015 at 12:54 PM
    #37
    RedRed
    RedRed TACO TUESDAY!!!
    Red
    Lake Norman NC
    15 taco with stuff & things
    1.75" Billy's plus 1/4 spacer on both sides. 1" block in rear. 265/70/17 nitto g2 SCS matte dark bronze 6s
    I'm interested in this too...
    LLS likes this.
  18. Nov 23, 2015 at 12:56 PM
    #38
    LLS
    LLS razorback
    Ark Taco
    My best friend and I both had Jeeps we both traded for tacos without the other nothing. Both white lol.
    JeffreyB and RedRed like this.
  19. Nov 23, 2015 at 1:19 PM
    #39
    TacoDirector
    TacoDirector Member
    Jeff
    Greensboro, NC
    2015 TRD OR 4x4
    I did not replace the plastic pins after I trimmed mine and put the flaps back on. Haven't had a problem.
  20. Nov 23, 2015 at 1:39 PM
    #40
    Mph6779
    Mph6779 Well-Known Member
    2013 Tacoma Baja Series
    OP where in texas are you? I'm in Austin and had the same issues, took it to AutoNation Toyota about a dozen time and they replaced everything and even had a factory rep and still nothing would fix it. I decided to try the weathertech vent shades, it seemed to work for some. It actually did work on 13 Tacoma so it might be worth a try because we both have the exact same noise in the same place... just a thought
