15 to 16 inch wheels, how can we change speedo?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JellyBeans, Jun 8, 2018.
  1. Jun 12, 2018 at 2:10 PM
    JMY24
    JMY24 Well-Known Member
    Huntsville AL
    '05 white TRD OR DCSB
    3 inch TOYTEC lift with Bilsteins Total Chaos uniball UCAs BAMF sliders
    This is a very strange thread
  2. Jun 12, 2018 at 3:09 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    You also dont need larger rims to run larger tires. Smaller rims are better in because they give more side wall compared to a larger rim with the same diameter tire
    xxTacocaTxx likes this.
  3. Jun 12, 2018 at 3:09 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    You should of read the spcer on that was in here before getting moved to the tire and wheel section
    JMY24[QUOTED] likes this.
  4. Jul 6, 2018 at 7:56 AM
    Glamisman
    Glamisman Well-Known Member
  5. Jul 7, 2018 at 10:33 AM
    ggmanning
    ggmanning Well-Known Member
    07 FJC, 03 TRD Offroad, 11 TRDPro, 14 Landcruiser
    I just changed the speedo output shaft/gear cog on the transmission. Take yours out, count teeth to figure out which one you have. Figure the percentage difference between the old and new tires say 31/33.... Buy the replacement cog with number of teeth difference to get as close as you can to reflect that percentage. If I remember right my OEM cog was 31 teeth and I bought one with 28 teeth when I went to 33" tires.
  6. Jul 7, 2018 at 11:17 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    he never mentioned what size tire he's putting on. judging by the previous posts he thinks going to a 16" rim is a bigger tire :notsure:
    xxTacocaTxx and Sperrunner like this.
  7. Jul 7, 2018 at 4:27 PM
    JellyBeans
    JellyBeans [OP] Active Member
    '95 4Runner SR 5 4x4
    '98 Tacoma SR 5 4x4
    Actually not, I understand the diff between wheel and tire, just didn’t want to stop you. Found a solution to the question so thank you to everyone for your help
