15'' to 16'' wheel swap? Need Help
Discussion in 'Wheels & Tires' started by tacoma matt, Feb 25, 2010.
  1. Feb 25, 2010 at 12:47 PM
    tacoma matt
    tacoma matt [OP] Member
    South Jersey
    95 Standard cab 4x4, Ultimate lift kit
    k&n, deckplate, throttle body spacer, Toytec ult. lift kit, cust. bumpers front and rear, cust exaust.
    I have a 99 reg cab 4x4 with 15x7 wheels. Just got 2.5'' coilovers w/ billys all around and 2'' aals in the rear. I want to run 32'' tires but dont want to go much wider than 10.5. After researching i found that there is no 32x10.5x15. What i did find is the 265x75x16 close to a 32x10.5x16.
    My question is 'What kind of offset/backspacing would i need to clear all wheel components(calipers, spindle towers, upper ball joint etc...) on a 16x8 wheel and also have minimal rubbing.
    Any knowledge or suggestions would be helpful.
    Thanks Matt:D
  2. Feb 25, 2010 at 12:49 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    A 4" to 4.5" backspacing would do fine...then you can run 265/75/16s. The 16s will fit no problem, you don't have to worry about your calipers and such...
    Check this
    http://www.tacomaworld.com/forum/tirecalc.php
    "32/10.50/15 compared to a 265/75/16"
  3. Feb 25, 2010 at 12:58 PM
    tacoma matt
    South Jersey
    thanks for the info, i dident think the tire would rub, was just a little worried bout the wheel not seating right with incorrect bs of offset.
  4. Feb 27, 2010 at 5:16 PM
    latok65
    latok65 New Member
    super swamper makes a 32/10.50/15
