15' TRD Pro P0300 / P0302 / P0306 (And sometimes all cyl. Misfire) Nightmare.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hecticweather, Sep 19, 2023.
  1. Sep 19, 2023 at 10:57 PM
    Hecticweather
    Hecticweather [OP] Member
    Truck: 2015 TRD pro Tacoma, 4door 5ft bed. 150k. SAIS removed and Tuned through a guy on here who no longer writes tunes as he works for a company.
    Background: For the past 4 months I have been chasing a misfire sometimes just p0300 and others P0302 and P0306. The lower I get in fuel the more cyl's log misfires. I'm going to keep it short because I could make this very long.
    Symptoms: Truck will start and run fine, hot, cold, it doesn't matter. While driving ~ 60 MPH at 2-2.2k rpms I will (at random) get a CEL and the engine will idle rough as I pull off to the side of the road and read the codes and then clear them. I will turn the truck off and back on and then it runs fine until it happens again. Sometimes 2+ more times in an hour and other times nothing at all. Most of the times it's the P0300, P0302 and P0306 but like the title says sometimes I will get all of them. <<Only Recently have I started to attribute these to fuel level and I think I am correct in that assumption>>
    I replaced (all OEM):
    Plugs
    Coils
    Cam Sensors
    Crank Sensor
    Intake Plenum Gasket
    Throttle Body Gasket
    PCV and Hose
    After I threw all those parts at it I took it to Toyota because I was lost. Toyota did not charge me to look at it for an hour because they couldn't figure out what my problem was it was then I bought all the injectors and replaced them. I thought I had it fixed when at a half tank, actually on my way to replace the oil pan gasket for a man I go to church with and the truck misfired again. P0300, P0302, P0306. I filled it up and continued to his house with no more codes there or the way back which is about an hours worth of driving.
    So now I figured, maybe the fuel pump at half a tank is getting hot and so I bought a new fuel pump and I put it in today. I had to cut off the very rear vent hose the smaller one that's is molded to the nipple it's fit to on the tank because the QD fitting was shot on it and you have to buy a whole new fuel tank to get a new one and so I put fuel line/evap hose on it and used a screw clamp on each end to secure it.
    I lifted the tank back up and poured in all of my siphoned fuel up to just above half a tank and now the truck will not start. I am thinking I damaged the fuel pump relay as I removed it to relieve pressure from the line but with my luck (read above) I don't think it's going to be that easy.
    Fuel Pump is OEM
    All other QD's went back on undamaged.
    Truck cranks fine but will not turn over. I heard others have problems with SAIS shutting down fuel pump is it possible I have to re flash my tune even though I just unplugged the battery and installed a new pump?
    Any help would be greatly appreciated, thank you very much.
  2. Sep 20, 2023 at 5:59 AM
    chueflee
    chueflee Well-Known Member
    Chue
    2013 toyota tacoma TRD offroad extended cab 4x4 v6
    afe intake, urd spec u headers, urd y pipe, 76mm throttle body, kelford camshaft, trd supercharger, urd cam gear, urd thermostat, ucon ems, NST pullies, ipt valve body, stoptech disc brake 323mm front, sos rear disc conversion
    I would get rid of that tune and try going back to stock tune. That sounds like the only thing you did to the truck
    2015WhiteOR likes this.
  3. Sep 20, 2023 at 7:01 AM
    Hecticweather
    Hey Chueflee,
    So for the tune, I have had it on the truck for a year now and never had problems. I can't go back to stock as the SAIS system is completely removed. My theory about all of this from the beginning is that I, not knowing that a fuel pump is cooled by the fuel in the tank, did an Italian tune up on the truck exactly the time this started happening with less than a quarter of a tank and after fill up got these codes about 2 minutes down the road thinking it was bad fuel. I treated it and treated it replaced all of the parts and still nothing which is why I attribute it now to an overheating fuel pump.
    So I replaced that but can't test that as the truck will not start now.
  4. Sep 20, 2023 at 7:05 AM
    chueflee
    Chue
    Whats an italian tune up? Did you change your fuel pump?
  5. Sep 20, 2023 at 7:15 AM
    Hecticweather
    It's an idiom for running the truck a little harder to burn off carbon deposits if it's been babied for a while (mine had).
    I did, I changed my fuel pump yesterday and buttoned everything up and then it wouldn't start. I pulled the Fuel Pump Relay as the Haynes manual says to do in order to release pressure in the fuel system and it was very stubborn as I was pulling it out I had to use a plastic pry bar that I use for body panels. I have a new one on order from Toyota and am praying that I some how messed it up during extraction. But the truck sounds normal it's just not getting fuel (I think) I do not own the special T connection I need to test the fuel pressure in these 2nd gens. I did pull the fuel line under the hood and a little bit of fuel came out but that didn't tell me if it was pressurized enough.
    Toyota will have the relay tomorrow so I will know for sure if I need to look somewhere else but again with my luck it's something way off in the distance that I can't see yet which is why I'm here asking you pros.
  6. Jun 29, 2024 at 7:07 PM
    WaterSleeps
    WaterSleeps New Member
    2017 Toyota Tacoma TRD
    Hi! Have 2017 Tacomo TRD truck is doing same thing. Did you end up find out problem/solution?
  7. Jun 29, 2024 at 7:29 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I believe we ended up determining one of the Oil Control Valves was bad but your 2017 has an entirely different engine so you would be better off asking about your issue in the 3rd gen section
  8. Jun 29, 2024 at 7:53 PM
    Hecticweather
    DM93 is exactly right, and he is the one that guided me through all my troubleshooting. Thank you so much again, every time I start my truck I think about all the help you gave me. I pray you and your family are doing well.
    Dm93 likes this.
  9. Jun 29, 2024 at 9:24 PM
    WaterSleeps
    Thank you so much for reply, ill definitely take a look into the oil valves. Was about to give up on the truck. Thanks again
