15" vs 16"
Discussion in '1st Gen. Tacomas (1995-2004)' started by AlexanderD, Mar 10, 2010.
  1. Mar 10, 2010 at 10:30 AM
    AlexanderD
    AlexanderD [OP] Well-Known Member
    Alex
    whitby Ontario
    03' tacoma 4x4 trd step-side
    looking at getting new rims. the question is should i stick with stock 16" with 4.25" back space or go to a 15" with a little less back space.
    i like the procomp 8069
    is there any advantage to using a 15's over 16's?
    also will they work on my 03 trd?
    will having a little less backspace (4" instead of 4.25) bringing out the rubber out a bit from the frame cause the front end wear items unnecessary stress?
    thanks in advance!
    AlexD
  2. Mar 10, 2010 at 11:47 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    I'd go 15x8 w/ 4" BS.
    15" tires are generally less expensive than 16" tires.
    8" width wheel w/ 4" BS will put it right around in line with the fender flares (since stock wheels are 7" wide with 4.5" BS, the new wheels will be pushed out 1.5")
    Yes, the wider the track width the more wear on the front end. will you notice it? most likely not.
  3. Mar 10, 2010 at 12:56 PM
    AlexanderD
    Alex
    whitby Ontario
    Thanks for the reply!
    what would be the best tire size to put on those rims (15x8 with 4"BS). (by best i really mean largest that won't have any issues with rubbing). likely going with BF AT's
  4. Mar 10, 2010 at 1:17 PM
    Hambone805
    Hambone805 Well-Known Member
    Aaron
    San Diego, California
    2015 4x4 Tacoma TRD
    STOCK :(
    on my 02 with a 3inch lift i have 15x8 rims with 32x12.5 BFG all-terrians. they rubbed a little on full lock but you can solve that with a little trimming of the valence below the bumper and the pinch weld mod. you should be able to run 33s if you have a 3in lift.
  5. Mar 10, 2010 at 1:25 PM
    Tankoma04
    Tankoma04 Member
    SoCal
    04 PreRunner
    3.5 inch Fabtech front lift & 2.5 inch lift rear
    I have 3 inch lift, 16's on 33's Toyo MT's....it rubs a little...if you hit the sand or mudd it will rub on some bumps..but nothing too much
  6. Mar 10, 2010 at 2:52 PM
    AlexanderD
    Alex
    whitby Ontario
    Ok. So I don't have any lift and Its not in the books any time soon.
    went looking for rims today and it seems that 15x8x 4"bs are hard to find.
    the set I did find the rep was adament there would be a clearance issue with the brakes.
    Soo thinking I will stick to 16" rims
    AlexD
  7. Mar 10, 2010 at 6:12 PM
    pmbazus
    pmbazus Well-Known Member
    AZ
    2020 TRD Off Road
    These are ProComp 8069-5883. They are 15x8 with 3.75 BS. They are on sale at 4wheelonline.com. The tires are 32 11.50 15 Kumho KL78 At's. The lift is 2.5 inches. No rub.
  8. Mar 10, 2010 at 6:59 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I just got the 8069's in a 16x8 4" BS.
    I love them!!:)
  9. Mar 10, 2010 at 8:01 PM
    dio1
    dio1 Poor college student
    07 offroad DC SB STOCK
    I have a 3inch lift on my '03 and im running 285/75/16 with stock rims now. im looking at getting some 16x9 AMERICAN RACING ATX ARTILLERY TEFLON wheels with an offset of -12mm and a backspacing of 4.53in. Would there be any problem running these rims and tires together? would they rub or be to wide or anything? Thanks
  10. Mar 11, 2010 at 5:21 AM
    AlexanderD
    Alex
    whitby Ontario
    this looks sweet! very much a fan of these wheels! shipping up here to ontario will kill me though! gunna have to see if any local shops can get pro-comp wheels.
  11. Mar 11, 2010 at 6:06 AM
    pmbazus
    AZ
    2020 TRD Off Road
  12. Mar 11, 2010 at 6:14 AM
    AlexanderD
    Alex
    whitby Ontario
    all the black bits look really good! must have taken a bit of work to get it all done up like that.
    what did you use to get the 2.5" lift?
  13. Mar 11, 2010 at 6:28 AM
    pmbazus
    AZ
    2020 TRD Off Road
    Bilstein 5100's in the front set at highest setting. ToyTec 2 inch shackles in rear.
  14. Mar 11, 2010 at 1:55 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    I love your Taco! :cool:
  15. Mar 12, 2010 at 4:40 AM
    AlexanderD
    Alex
    whitby Ontario
    ordered a set of the 8069's (15x8) and BF all-terrain (31 x 10.50 x 15)
    ill be sure to post some pics when it is all setup.
    thanks for all the help fellas!
    Alex D
  16. Mar 12, 2010 at 11:35 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    yeah ...that tire/wheel combo really makes his taco pop.:D
