15'' Wheels on a 07?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jakers83, Dec 14, 2013.
  1. Dec 14, 2013 at 9:27 PM
    Jakers83
    Jakers83 [OP] Well-Known Member
    Jake
    Denver
    2.7 base.
    OME lift. Tires and wanting more
    I just bought a set of Michelin m/s2 for everyday driving (265/70/16. I want to get a new set of wheels and tires for wheeling. 15'' wheels and tires are cheap. I was seeing if anyone knew if I could get 15 on my truck
    Thanks,
    Jake
  2. Dec 14, 2013 at 9:32 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    They won't clear the calipers on a 6-lug.
    Many aftermarket 16's won't even clear.
  3. Dec 14, 2013 at 9:56 PM
    FTD
    FTD Well-Known Member
    What he said. Will not work. The only Tacos that can take 15" wheels are the five-lug models.
    Best practice is to use the tire and wheel size your vehicle came with.
  4. Dec 14, 2013 at 9:58 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    I saw a 2nd gen prerunner with 15's a long time ago, had some 2.5 inch wheel spacers.
    No shit the guy also told me he tried to grind down the caliper to get them to fit and ended up having to buy a new one.
  5. Dec 15, 2013 at 9:21 AM
    Jakers83
    Jake
    Denver
    2.7 base.
    Dam ok I did not think going down a inch would make much of a difference. Thanks guys fro the info.
    Do many people on here run 2 sets of wheels? one for everyday and one to wheel with?
  6. Dec 15, 2013 at 5:50 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    It's not uncommon... or summer/winter sets so the nice alloys don't get chewed up by the road salt.
    Keep in mind that when you switch to a backup set of wheels, your TPMS light is going to come on.
  7. Dec 15, 2013 at 9:43 PM
    Jakers83
    Jake
    Denver
    2.7 base.
    Ok well that is a valid point about the tpms. But I really just want a good set of tires and wheels just for wheeling. I would be running low psi so not sure if the light would bug me to much
  8. Dec 15, 2013 at 9:46 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Why?
    Low PSI is good for floatation, but bad for hydroplane resistance.
