150,000 mile trouble spots
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoman101, Nov 22, 2009.
  1. Nov 22, 2009 at 6:32 AM
    tacoman101
    tacoman101 [OP] Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    I have a 2001 xtracab tacoma with a 2.7 4 cylinder engine that just hit 150,000 miles. I was just wandering what are some trouble spots mechanically that start to happen when tacoma's get this old. I heard that the 4 cylinder engine in these trucks are pretty much bulletproof, is this true? I take good care of the truck, and run all synthetic oils in it, how many more miles do you guys think I could get out of it?
  2. Nov 22, 2009 at 6:47 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Nobody can answer that question....
    Keep maintaining it properly and diligently and she'll last a long time.
    I think the only real issue is the internal frame rust issue. Are you familar with the frame rust warrantee?
  3. Nov 22, 2009 at 1:48 PM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    I don't know how common it is, but my 01 needed it's waterpump replaced this summer. The engine itself if pretty tough, but the waterpump will wear after a while. if you've never replaced yours, I'd do it now on your terms instead of waiting for it to fail (like I did). When mine failed, it overheated the engine and one of my ignition packs got fried, so I needed to replace both. Also the O2 sensor will eventually fail and need replacing, the rear one I think is pretty easy to do, never tried to do the front one. The only other thing I've ever had a problem with was the rear leaf springs, both sides cracked on my originals and I had to replace. If you get the frame replaced Toyota will give you new leaf springs.
  4. Nov 22, 2009 at 3:18 PM
    tacoman101
    scott
    vermont
    yep im pretty familiar with the rust frame warrenty...so far theres no rust cause its been kept from the salt, but this winter it will see alot of the salt, so some where down the road i might need to get the frame replaced
  5. Nov 22, 2009 at 4:14 PM
    DaytonLax14
    DaytonLax14 Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    mine has over 170,000 and no problems so far.
  6. Nov 14, 2010 at 11:59 PM
    TacoBlitz
    TacoBlitz Well-Known Member
    Jake
    Omaha, Nebraska
    01 DoubleCab SR5 TRD, white
    Topper, Yakima Racks, Yakima Loadwarrior roof basket (lights all around) 20% window tint (all 4 doors), Spectre ProFab Air Intake System, Black grille, Rino Lined rocker panels, rear bumper and flares Suspension: New OME 881 coils and OME 5 leaf rear springs, Blilstein shocks and struts, Daystar Greasable lift shackels Extended rear brake line
    Are they still honoring that recall? Or is it to late?
  7. Nov 15, 2010 at 5:32 AM
    edcal
    edcal Well-Known Member
    Ed
    Long Beach, CA
    02 PreRunner
    Icon Coil Overs/AAL, Bilstein 5100's, 285/75/16's on MT Classic Locks, 4runner Hood Scoop Mod, Yakima Roof Rack w/BVG Roof Basket, Alpine iDA-X100 Head Unit, iCom V8000 w/Comet SBB25 Antenna, Dual LED Dust Lights, DeChromed, DeBadged, small cosmetic mods like Clear Corner Lights, Painted Tail Lights, Mesh Grille, Tinted Windows & LineX Bed
    reason why they call 4 cylinder tacoma motors bulletproof is because they have timing chains instead of belts. pretty much never have to change a timing chain.
  8. Nov 15, 2010 at 5:37 AM
    Janster
    Jandy
    Lancaster, PA
    It's a 15 year warrantee
  9. Nov 15, 2010 at 7:49 AM
    JBear
    JBear Spiral Out... Keep Going!
    Orange County, CA
    2003 Extra Cab 5 spd 4x4 TRD Off-Road
    2" suspension lift with King Coilovers up front. Standard Bilsteins on rear with a Fabtech 1.5" AAL. Leer 100XL Shell.
    Yah, I have just slightly over 150k and my leafs are pretty much shot now. Replacing with the Wheeler 5 pack when I do my lift.
  10. Nov 15, 2010 at 6:54 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    I'd say look out for most things that are neglected for any car around 150k miles. IMO those things are
    1. ALL of the fluids on the truck have been changed regularly. And i mean ALL of them. Power steering, Brake fluid, ATF, MTF, all of the grease fittings have been greased on the vehicle (they tend to hide), etc.
    2. Suspension. Shocks (any car with original shocks after 150k need to be replaced), leaf springs, bushings, ball joints, tie rod ends, etc.
  11. Nov 15, 2010 at 7:13 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    I upgraded everything on mine (regardless of the miles, just because I wanted to wheel it), but my new truck had a bad throw-out bearing when I bought it with 148k on the clock.
  12. Nov 15, 2010 at 7:27 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    ive got the 3.4l with 174,500 on her and she runs like new.
  13. Nov 15, 2010 at 8:57 PM
    TacoBlitz
    Jake
    Omaha, Nebraska
    Thanks
  14. Nov 15, 2010 at 8:59 PM
    TacoBlitz
    Jake
    Omaha, Nebraska
    Mines got over 190,000 and I still have all the confidence in the world in it, thinking about sea-foaming it just in case though
  15. Nov 15, 2010 at 8:59 PM
    2gtacoma
    2gtacoma Well-Known Member
    Daniel
    H-town
    05 -PreRunner sr5
    URD Maf Cal, Airaid intake, Gibson exhaust, Urd short shifter,Trd shift knob, 2.25 lift,Satoshi grill, Trex eyelids
    my dads 98 4x4 has 200k + and just recently changed the timing belt and water pump oil pump on his 3.4 just take care of the simple things and you wont have problems.
