150,000 miles on PCV
Discussion in '2nd Gen. Tacomas (2005-2015)' started by StevieD, Jun 29, 2019.
  1. Jun 29, 2019 at 6:38 PM
    StevieD
    StevieD [OP] Well-Known Member
    Tampa
    2007 tacoma
    Tuned up my 2007 4.0 today. Last tuneup was at 120,000 miles. the Denso plugs looked good. The owners manual says change them so I did. I decide to change my PCV, as I have never checked the valve. The old one definately needed cleaning, but I put the new one in since I had bought it when I bought the plugs. I also cleaned out the old hose and put new spring clamps on. The vehicle looks great and runs like new. The earlier 4.0's had a few issues with the timing chain cover leaking, so I changed out the PCV to hopefully avoid this leak in the future. Just a heads up to those that have the older 4.0. What an amazing engine. Steve.
    koditten and TheDevilYouLove like this.
  2. Jun 29, 2019 at 6:56 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I changed mine at approx 135,000. It still rattled but was dirty. Genuine Toyota replacement was pretty cheap so I feel good about having a new one in there.
    My 4.0 has +140,000 on it and runs as good or better than new. Truly an amazing product!
  3. Jun 29, 2019 at 7:03 PM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    177k on my 2010, runs like a dream, changed the PCV around 100k
  4. Jun 29, 2019 at 7:21 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    I changed my PCV 1 time with a $7 OEM purchased at the dealer at 30k, and the engine now has 103k. PCV swaps are good maintenance, but its probably the lowest priority replacement part as long as the oil is changed between 5k to 7k miles..which helps keep the PCV freely moving.
  5. Jun 30, 2019 at 12:07 AM
    TacoTuesday1
    FL
    is there a part number for the PCV?
    Which DIY did you follow?
  6. Jun 30, 2019 at 4:35 AM
    StevieD
    Tampa
    2007 tacoma
    TT1, the package refers to a Valve Sub-Assy. 12204-31030. I didn't follow a DIY so I can't help you with that part. The process is very much the same as changing a spark plug, with the addition of cleaning the ventilation hose. hope that helps you.
  7. Jun 30, 2019 at 6:12 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Cleaning when hose??
